Question about Crosley CR248 Turntable
Playing the cd's produced on my jvc stereo system
The first lp that I copied, I played on my jvc... I was happy. Then I copied two other lps and neither will play on my jvc - as far as I know, I took the same steps as the first. All three will play on my computer - I have not tried them on any other player.
  • Juanita Coutee Jun 07, 2007
    Sorry - the lps were copied on a Crosley CR248....
  • 515 Answers
If you took the same steps, then obviously, it should work the same. However, there are many factors that could cause it to not play. You can try a different CD-R burning program. Also, some stand alone CD players do not play CDR's. So make sure your CD player can handle this. Also make sure your not burning an MP3 CD or similar. Make sure you also close the disc when it is done, and leave a 2 second gap between each song. Lastly, try burning at a slower speed - such as 4x - believe it or not, burning at a higher speed does affect your CD's playing options, especially on older CD players. Hope this helps! - Justin DJPROAUDIO
Posted on Sep 02, 2007
I just recently bought a new turntable, and when it plays my LPs, the LPs sound somewhat slower than the original. Does the slowness have to do with the belt of the turntable? Is there anyway I can fi
If the 45's play OK then your belt might not be fitted in the right place. If they are both slow, then either the belt is slack or the drive is faulty.
Dec 09, 2012 | Audio Players & Recorders
How to switch from sp to lp mode when playing back?
Did you try setting the rec mode to SP in the playback menu?
a54f98a.jpg This is from the D250 manual.
Dec 18, 2007 | JVC GR-D250 Mini DV Digital Camcorder
My Jensen JTA 450 is playing LPs too slow even though 33RPM is already set. The songs are slower than usual. Please help me.
The record that you are trying to play maybe a 45rpm recording. Some 45's were released in album size recordings.
Jun 20, 2012 | Audio Players & Recorders
My jvc home stereo won;t play
It is the fuse, or the power transformer that in some cases has a built in thermal fuse in place of the regular fuse.
Mar 10, 2012 | JVC MX-GA77 CD Shelf System
VINYL PLAYER SLOWS WHEN I STACK A COUPLE OF LPS sounds funny play fine with just 1
The labels on the LP's stick up higher than the vinyl. These slip on each other when you stack LPs.
One LP sits directly on the turntable mat and has enough friction to turn.
The only solution I can think of is to put something 'tacky' on the labels but this might be detrimental to the label.
Dec 16, 2010 | Audio Players & Recorders
I have a cdx 52000 stereo and every time i try to play my cd player i get an error 04 message
are they copied cd's....some sony cd players won't play pirated cd's as they are record producers.
Jul 21, 2010 | Sony XPLOD CDX-GT200 CD Player
I recorded a video using sony hd100n in dv format,when i capture it using jvc minidv camcorder(jvc GR-DVL820u) the the capturing is not good specialy the audio.what is the posible solution?
May be you recorded it on LP, LP recording are sensitive to interchangeability issues or it could beyour JVC's LP heads are weak. If you have an idea on how to adjust pole base, try to adjust supply side on your JVC(left side pole base) while playing and observe the sound while adjusting it. Be careful not to touch parts at the sorroundings,pay a lot of attention while doing this. If you do not have background in this field, let the pro do the job. Good luck
Mar 02, 2010 | JVC GR-D850 Mini DV Camcorder
Play Ipod thru JVC CD car stereo using RCA cable?
JVC KD-S731R does not have the option of connecting an ipod. The RCA ports on the rear of the unit are a Line-Out. These RCA's only OUTPUT sound. Not an INPUT RCA that you require. The only other method of using an ipod with this stereo is to purchase an FM-Modulator to connect the ipod. Once purchased, you must connect the antenna wire coming from the vehicle to the module, then you must connect the antenna wire coming from the module to the stereo. The other wire will be connected to either a jack or a ipod specific plug depending on the type of modulator used.
Dec 08, 2009 | JVC Car Audio & Video
VCR LP/EP compatibility
Vdumitre -
No, not usually. If you've recorded a tape at LP and put it another machine that doesn't have LP, it usually won't play properly. Some machines that have only SP/EP will do this, but they are got scarce as more manufacturers dropped the LP speed. Your best bet is to buy an older one from a thrift shop or a garage sale, making sure that it will play LP. Then, copy your older LP tapes to SP or EP (Run the OUT from the LP unit to the IN on the SP/EP unit, and choose "record from line in", "aux", or "rear input").
Thanks,
videoman7
Aug 05, 2009 | Sony Televison & Video
Jvc kd-sx770 car stereo--radio works, but cd player doesn't
Hello beeswing70,
The player is recognizing that a CD has been inserted but is not able to read it.
Sometimes the lens assembly becomes contaminated and obscures the laser. I'd try using a commercial "lens cleaning CD" two or three times and then try a CD again. These lens cleaning CD's are widely available. If cleaning does not help, the player need professional service.
Hope this helps.
May 25, 2009 | JVC KD-SX770 CD Player
Crosley CR248 Turntable Logo
132 people viewed this question
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
