Question about GE Spacemaker JVM1640SJ Microwave Oven
GE microwave JNM1541 keypad
The Time cook button and buttons 1 and 2 ( for express cook ) do not work. Neither does the Clock button. Everything else is functioning.
  • 140 Answers
SOURCE: Ge microwave model JVM1190WY buttons work but does not cook
The problem you are having with your microwave is a common one. Not heating is a problem that can be caused by three things. I'll list the most common solution first, the magnetron that actually does the heating is what is making that noise and has gone bad. It is possible for you to also have a bad high voltage diode that has opened up, solution two, or solution three is the high voltage capacitor is not working properly as well. From my experience with microwaves I am positive that it is your magnetron that is bad. If you are not do it yourselfer you'll need to take it to a repair shop to replace. However, if you know how to use a screwdriver and can unplug a couple of wires with spade terminals on them, then you can take it off yourself, find another one and replace it the same way you took it off. The magnetron sits behind the control panel of your microwave but on top. It has cooling fins on it and has 2 terminals maybe three depending and make and model that plug into it. It has 4 screws that are easy to get to that actually holds it in place. If you do not have a good local source like an electronic parts supply place then you can find the right magnetron at www.mwoparts.com. Be sure you always unplug the microwave before touching or trying to take the he cover off and then when you take the magnetron off also.Good luck and God bless.
Posted on Feb 11, 2009
MicrowaveSvc
  • 9085 Answers
SOURCE: recently bought a ge over
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If you still have trouble, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
GE Customer Service is here.
Posted on Sep 01, 2008
MicrowaveSvc
  • 9085 Answers
SOURCE: GE spacemaker XL1400, Model number JVM1430WA 001
OOPS!
I meant to post that as a solution, not a clarification request, so it came out as one big blob paragraph (Thanks, FiyXa!)
Here it is again, but in readable form:
You have a failing membrane keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
It is part number WB27X10171 and while GE sells it for a whopping $115.50, you can get it for $90.58 here.
You can also find helpful exploded view diagrams via that link.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you would like to have us do this repair for you, we do that for $39.95 plus part costs, in this case
$90.58 plus $8.95 shipping for a total of $139.48.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Posted on Jul 25, 2009
MicrowaveSvc
  • 9085 Answers
SOURCE: The keypad buttons do not work
> model JVM1640WJ03
The keypad is part number WB27X10721 MEMBRANE KEY PANEL available for $37.09 here (it's $61.50 from GE!).
First of all, you should check the end of the keypad strip for rough white, gray, or green deposits that can sometime interfere with conductivity.
Then disconnect the strip as shown in the photo below and use a soft pencil eraser to gently clean both sides of the end, then reinsert it and try it again.
If that doesn't fix it, and you don't notice any rough white, gray, or green deposits on the circuit board (moisture or mineral deposits) or grease, then your keypad is bad.
d:%5cele%5crepair%5cmicrowave%5cge_hotpoint%5cmini_manual_behind_grille_small.jpgdee77f7.jpg
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
If you would like to have us do this repair for you, we do that for $39.95 plus part costs.
prototech@usa.net
Posted on Jul 26, 2009
jtd866
  • 71 Answers
SOURCE: GE microwave will not heat, everything else works, any ideas?
Hi! the problem you have stated indicates that the magnetron its not functioning, check for busted fuse.
Posted on Sep 16, 2009
GE Microwave keypad partially working
On some models you can order just the membrane keypad. It's more work, but it's cheaper.
On other models, you have to order the control panel frame which comes with a new keypad already on it.
A YouTube video showing how to remove a typical over the range control panel assembly in under 5 minutes, is here.
Some connectors have a lock.
You can order GE parts from Sears hereimage-4235112-10659157 and the site should have helpful exploded views.
Nov 30, 2012 | Microwave Ovens
Ge microwave je2160sf03
From the description one of the door switches is defective, or a more serious problem has developed.
Jun 02, 2012 | GE Spacemaker Over-the-Range Microwave
GE Microwave Model: JVM1540DN1BB Keypad appears to work... but Microwave doesn't work
The problem is more than likely in the microprocessor control board, sometimes a bad relay, or poor solder points.
Mar 11, 2012 | Microwave Ovens
My microwave GE model # JVM1440WH04 spacemaker has no heat coming out of it. My husband heated microwave lasagna in it last, everything works except for the heat, any solutions?
Push the microwave door tightly closed. The computer will not start cooking until the door is closed for safety reasons. Some models of microwave will give a warning on the screen if the door is open.
Ensure you have programmed a heat setting, entered a cooking time and pressed the "Start" button on the microwave's keypad. Check that the microwave is not set to "Defrost" mode.
Unplug the microwave and wait for one minute. This measure will reset the microwave's internal computer if it has frozen or scrambled. Plug the microwave back in and try again.
Ensure the keypad lock mode is inactive. Most microwave ovens have a lockout feature that prevents children from starting the microwave while unsupervised. Lockout mode is usually deactivated by holding down the button that bears a padlock symbol
Oct 05, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE sensor microwave oven. Tried to heat food and sensor eror came on. Everything is running even the timer but no sound but the timer is running. Cant this be reset pls help
HELLO.
This is the solution to reset your microwave.
1 Pressing the clock button will display the time. You can also use this to know what time it is while cooking.
1. Set the clock by pressing the "Clock" button.
2. Turning the dial on the GE sensor microwave oven will display the hour of the day. Once you have found the correct hour, press the dial in.
3. Again, turn the dial to set the minutes of the day. When this is completed, you will need to press the dial in again on the GE sensor microwave oven.
4. When the time and minutes are set, turn the dial again for a.m. or p.m. Then you will need to press the dial in to save the settings.
5. Press the "Start" button to allow the clock to begin on the GE sensor microwave oven.
Thanks.
Sep 18, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
How do you set the power level? The model number is: JVM1730DM1WW The serial number is: MM901698B
Assuming your touch pad is working properly, press Time Cook (for cooking) or Time Defrost (for defrosting) and then type in the length of time that you want the microwave to operate. Then press Power Level and type in a number from 1-10. Finally press Start. Depending on the GE microwave, the Power Level button may be above 2 or to the left of 0. (I've seen both keypad designs depending on when and where the microwave was manufactured.) If you press Power Level before setting the cooking time, the unit will reset when you press Time Cook or Time Defrost.
GE has the manuals for some of their microwaves on their site. See http://www.geappliances.com/service_and_support/literature/ and enter the model number in the search engine.
I hope this helps.
Mar 02, 2011 | GE Microwave Ovens
Keypad number buttons not working on ge spacesaver microwave - auto program buttoms work?
Very angry. Fairly new, little-used Spacesaver Microwave [3][Clock][Surface Light] buttons now do not work. We never even press [3], just [1] and [2] to warm sandwiches.
Unplugged for an hour. Still not working. Everything else works. We never use anything else. Bad solder joint in circuit board or keypad?
Thank you.
Aug 28, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
All the buttons on the appliance won't work except for one
sounds like a bad key panel i think if you replace it will be ok
Jul 24, 2009 | GE JES1231 Microwave Oven
OOPS!
prototech@usa.net
Jul 21, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Recently bought a ge over the range microwave oven on 04/17/2008 now the express cook, the timer defrost buttons don't work. everything else works
Aug 28, 2008 | GE Microwave Ovens
GE Spacemaker JVM1640SJ Microwave Oven Logo
52 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
