Question about Toys
Trying to find an ElPower EP 680 Solid Gel Battery (6 volt 8 ampere) for a 1978 Highway 2100 Traffic Patrol child's motor cycle - G10068 B or D?? Trying to fix for our grandson.
Matel or Fisher price does not have this battery or replacement.
  • 308 Answers
SOURCE: i have a fisher price smart cycle and can not find
The smart cycle, according to fisher price, uses 4 d cell batteries, no 9v
Posted on Jul 21, 2009
  • 10865 Answers
SOURCE: I need to replace a pedal on my grandson's Fisher
Hi. No problem. Here is the link to order direct from Fisher Price
https://store.mattel.com/CatalogBrowser.aspx?cmd=local&cat=140&sec=9123
J.
Posted on Jul 12, 2010
cragsmg2005
SOURCE: Please Please Please! I have
http://www.amazon.com/Volt-Nitro-700mAh-Battery-Charger/dp/B00002SU0V
Here you can buy that battery for your grandson and let his dino roar!
Posted on Mar 02, 2011
SOURCE: Changing the battery on the
TRY this PDF http://www.fisher-price.com/inst_sheets/R9703b-0920.pdf
Posted on May 18, 2011
Testimonial: "Thank you ! Very helpful !!! "
Ironfist109
  • 3018 Answers
SOURCE: I need a replacement for
Regards, Tony
Posted on May 20, 2011
Okay, I'm working on a scooter for my nephew that originally came with (2) 12 volt 12Ah batteries minus the charger. and I know I need to replace them with (2) batteries of the same 12 volts and lets
not exact, to charge apropiate needs 10% more than nominal voltage. if not, will not charge the batteries.
And the charger its very important because you can over charge the battery.An example,if you have a 12 Amps Batteries each one if you put it in series will be 24 Volts.at parallel conection will be 12 volts but the double of Amps.
At serial connection will be 12 Volts the amps will be the same but the volts will be 24.
The charger at 12 Volts must be 13.8-14.5 DC Volts and divide the Amps in Hours.
The charger at 24 Volts must be 26-28 Volts. to charge well.
The charger for 12 amps batt example must charge 2 amps per hour at 6 hours = 12 Amps.(2 Amps Charger by 6 Hours Charging= 12 Amps.(Fully Charged.
3 Amperes Charger needs 4 Hours to charge 12 amps Batt.
5 Amperes Charger needs 2 Hours charging an a quarter
All of this is at DC Current.
Luck.
Oct 18, 2014 | UPG 12V 12Ah Electra Scoot-N-Go 88615...
Can i replace the AGM batteries in my Bombardier class e, with deep cycle batteries?
A deep cycle battery for personal mobility equipment would be how to look into this. The AGM is a type of deep cycle battery. A gel battery is what was more common before AGM came along. Gel batteries tend to hold up a touch more than AGM.
Oct 12, 2014 | Health & Beauty
It does not seem to be charging the batteries. 12 volt lights work good for about 2 days then go dim until I put a charger on the batteries and bring them back into working order. The battery connect...
The Parallax 7155 converter should not require battery support for any 12 volt load amperage that is less than the maximum amperage capacity of the converter. A standard RV incandescent 12 volt lamp draws about 1.5 amperes for each bulb. With the battery disconnected and other 12 volt loads off, turn on lamps (not fixtures) and calculate the number of bulbs which can be turned on. If you run out of lamps, turn on vent fans etc. The idea here is to try to get to 55 amperes of DC load if possible without going over 55 amperes. At a sustained DC load of about 25-30 amperes or higher, the fans should cycle on continuously after about 5 -10 minutes. Lamp brightness should be normal and the measured voltage from the converter should be above 13 volts if under 55 amps of DC load. If the voltage drops with only a few lamps on, a converter issue would be likely.
Diagnostic tests an RV technician should make would be to:
1. Disconnect the battery system.
2. With the converter system powered on, measure the DC amperage with a DC ammeter capable of reading at least 60 amperes DC from the blue lead at the DC fuse panel terminal VCC.
3. Measure the DC voltage at terminal VCC and DC ground.
4. Record both readings.
At any DC load amperage less than 55 amps, the voltage should be above 13.0-13.2 volts DC. This method should take out all guesswork and confirm a DC converter section issue or not.
Nov 04, 2013 | Parallax Power Supply Parallax 7100 Series...
Source coil
the formula P=EX I will guide you to use the next formulas:
2. Voltage and Turns in Coil:
Voltage (p) x Turns (s) = Voltage (s) x Turns (p)
or Ep x Ts = Es x Ip
A. Ep = Es x Ip
Ts
B. Ts = Es x Tp
Ep
C. Tp = Ep x Ts
Es
D. Es = Ep x Ts
Tp
3. Amperes and Turns in Coil:
Amperes (p) x Turns (p) = Amperes (s) x Turns (s)
or Ip x Tp = Is x Ts
A. Ip = Is x Ts
Tp
B. Tp = Is x Ts
Ip
C. Ts = Ip x Tp
Is
D. Is = Ip x Tp
Ts
God bless you
Jul 01, 2012 | Cars & Trucks
Number of turns of honda tmx 155 source coil
using the formula P= E x I will guide you to use the next formulas:
A. Ep = Es x Ip
Ts
B. Ts = Es x Tp
Ep
C. Tp = Ep x Ts
Es
D. Es = Ep x Ts
Tp
A. Ip = Is x Ts
Tp
B. Tp = Is x Ts
Ip
C. Ts = Ip x Tp
Is
D. Is = Ip x Tp
Ts
God bless you
How can I get the F/A -18 Precision Strike Fighter keyboard reference guide
Aileron Left Keypad 4
Aileron Right Keypad 6
Elevator Down Keypad 8
Elevator Up Keypad 5
Rudder Left <
Rudder Center /
Rudder Right >
Increase Thrust =
Decrease Thrust -
Afterburner Backspace
Brake Space
Gear G
Flap F
Hook H
Dump Fuel Shift D
Refuel Shift F
Service (refuel/arm) Shift S
Eject Shift E
Damage Display D
Engine Display E
HUD Options
HUD Altimeter Toggle Ctrl A
HUD Brightness Ctrl B
HUD Clutter Reject Ctrl C
NAVIGATION
Autopilot Toggle A
Autopilot Mode Shift A
Waypoint Cycle W
TACAN Cycle T
ILS Toggle L
Moving Map/Scale M
Nav./HSI Scale N
RADAR
AA/AG Toggle R
Sub-mode Cycle Q
Standby B
IFF Interrogate I
Range Decrease Tab
Range Increase Shift Tab
ACM Cycle Shift R
AACQ Cycle Shift Q
Silent Mode Ctrl R
Radar Target
Designate/Cycle \
Undesignate/TDC Stow Shift \
TDC Up Shift Arrow Up
TDC Down Shift Arrow Down
TDC Left Shift Arrow Left
TDC Right Shift Arrow Right
Radar Scan Volume
Decrease Azimuth Z
Decrease Elevation X
Increase Azimuth Shift Z
Increase Elevation Shift X
WEAPONS
Stores Display S
Cycle AA [
Cycle AG ]
CCIP/Auto Toggle Shift ]
Jettison Station J
Release Flare '
Release Chaff ;
ECM Toggle C
Designate/Release Enter
Electro-Optical
E-O Weapon Cycle O
E-O Target Cycle Ctrl \
HARM
HARM Select U
HARM Target Cycle Ctrl \
SIMULATION
Pause Flight P
Exit Flight Shift Esc
Fast-time Toggle Ctrl F
Warp-time Toggle Ctrl W
Earlier TOD Ctrl E
Later TOD Ctrl L
Night/Day (+6 hr) Ctrl N
Joystick Program Ctrl J
Hide Instruments Ctrl I
RADIO MESSAGING
Ground Control Shift G
Control Tower Shift T
Flight Ops Shift O
Approach Control Shift C
Landing Signal Officer Shift L
WINGMAN COMMANDS
F1: Wingman flies to your 4 o'clock position.
F2: Engage/protect my air target.
F3: Resume your mission objectives.
F4: RTB or Return To Base. I use this only when my wingman is low on fuel (he will call "Bingo" when he has just enough fuel left to return to base).
Tactical pre-merge setup:
F5: "Bracket left" or flies to your left side (9 o'clock).
F6: "Bracket right" or flies to your right side (3 o'clock).
F7: "Split High" or flies at your right at a higher level.
F8: "Split Low" or flies at your left at a lower level.
Admin commands:
F9: Echelon. Parade position at your 4 o'clock.
F10: Trail. At your six o'clock.
F11: Combat spread.
F12: Lead. In front of you.
VIEWS
Cockpit Views
Forward 1
Look Down 2
External View 3
Selected Target 4
My Aircraft 5
Padlock Target 6
Padlock Nearest 7
Padlock Wingman 8
In-flight Weapon Toggle 9
Radar Target Toggle 0
VIEW MODIFIERS
Look Left Arrow Left
Look Up Arrow Up
Look Right Arrow Right
Look Back Arrow Down
Optical Zoom In Home
Optical Zoom Out End
Move Camera In Page Up
Move Camera Out Page Down
Multiplayer Chat Shift '
AA: Air-to-Air
AMRAAM: Advanced Medium-Range Air-to-Air Missile
AS: Air-to-Surface
HARM: High-speed Anti-Radiation Missile
HD: High-Drag
LD: Low-Drag
LGB: Laser Guided Bomb
STORES DESCRIPTION
AIM-9M Sidewinder (190 lbs.) Short-range infrared-guided (heat-seeking) AA missile
AIM-9Mx2 Sidewinder (380 lbs.) Short-range infrared-guided (heat-seeking) AA missile
AIM-120 AMRAAM (350 lbs.) Advanced medium-range radar-guided AA missile
AGM-65B Maverick (645 lbs.) Electro-optically guided AS missile
AGM-88 HARM (790 lbs.) High-speed anti-radiation radar-homing AS missile
AGM-62 Walleye (1250 lbs.) Electro-optically guided gliding AS missile
MK-82 LGB (600 lbs.) Laser-guided general-purpose light bomb
MK-83 LGB (1100 lbs.) Laser-guided general-purpose medium bomb
MK-84 LGB (2100 lbs.) Laser-guided general-purpose heavy bomb
MK-82 LDx2 Slick (1040 lbs.) Free-fall general-purpose low-drag light bomb
MK-83 LDx2 Slick (2130 lbs.) Free-fall general-purpose low-drag medium bomb
MK-84 LD Slick (1980 lbs.) Free-fall general-purpose low-drag heavy bomb
MK-82 HDx2 Snakeye (1160 lbs.) Free-fall general-purpose high-drag light bomb
CBU-59B Cluster (490 lbs.) Free-fall anti-personnel and munitions bomb
B-57 Nuke (650 lbs.) Free-fall tactical thermonuclear bomb
BLU-107B Durandal (483 lbs.) Rocket-powered anti-runway bomb
EXT FUEL (2500 lbs.) Disposable fuel tank
FLIR (350 lbs.) Forward looking infrared pod / Electro-optical targeting device
RECOMMENDED LOADOUTS
Mission Type
Station=>Store
Patrol
1/9=>AIM-9M, 2/8=>(Empty), 3/7=>(Empty), 4/6=>(Empty), 5=>(Empty)
Medium Range CAP (Combat Air Patrol)
1/9=>AIM-9M, 2/8=>AIM-120, 3/7=>(Empty), 4/6=>AIM-120, 5=>EXT FUEL
Short Range CAP (Combat Air Patrol)
1/9=>AIM-9M, 2/8=>AIM-9Mx2, 3/7=>(Empty), 4/6=>AIM-120, 5=>(Empty)
Escort
1/9=>AIM-9M, 2/8=>AGM-88, 3/7=>EXT FUEL, 4/6=>AIM-120, 5=>EXT FUEL
Intercept
1/9=>AIM-9M, 2/8=>AIM-120, 3/7=>EXT FUEL, 4/6=>AIM-120, 5=>(Empty)
Ferry
1/9=>AIM-9M, 2/8=>(Empty), 3/7=>EXT FUEL, 4/6=>(Empty), 5=>EXT FUEL
CAS (Close Air Support)
1/9=>AIM-9M, 2/8=>AGM-65B, 3/7=>AGM-88, 4/6=>(Empty), 5=>CBU-59B
SEAD (Suppress Enemy Air Defenses)
1/9=>AIM-9M, 2/8=>AGM-88, 3/7=>AGM-88, 4/6=>AIM-120, 5=>EXT FUEL
Light Free-Fall Strike
1/9=>AIM-9M, 2/8=>MK-82 LDx2, 3/7=>(Empty), 4/6=>(Empty), 5=>EXT FUEL
Heavy Laser-Guided (Precision) Strike
1/9=>AIM-9M, 2/8=>MK-84 LGB, 3/7=>MK-84 LGB, 4/6=>(Empty), 5=>EXT FUEL
Heavy Free-Fall Strike
1/9=>AIM-9M, 2/8=>MK-83 LDx2, 3/7=>MK-83 LDx2, 4/6=>(Empty), 5=>EXT FUEL
Deep Interdiction Strike
1/9=>AIM-9M, 2/8=>MK-84 LGB, 3/7=>EXT FUEL, 4/6=>(Empty), 5=>EXT FUEL
Nuclear Strike
1/9=>AIM-9M, 2/8=>B-57, 3/7=>EXT FUEL, 4/6=>(Empty), 5=>EXT FUEL
Anti-Runway
1/9=>AIM-9M, 2/8=>MK-82 HDx2, 3/7=>BLU-107B, 4/6=>(Empty), 5=>MK-82 HDx2
Anti-Tank
1/9=>AIM-9M, 2/8=>AGM-65B, 3/7=>AGM-65B, 4/6=>(Empty), 5=>(Empty)
Jan 26, 2012 | Xicat Interactive F/A -18 Precision Strike...
How do I replace the battery?
to replace the batteries in your Go-Go you need to remove the battery case from the scooter and turn it upside down . as you use an AGM gel battery you will not spill any thing i change mine out every 400 charge cycle as they are good for about that long. on the bottom of the case you will find 8 screws you need to take out to open the case you will need a 6 to 8 inch long Philips screw driver for this. after you remove all the screws you need to turn the box up right and remove the top.inside you will find 2 batteries. you will need to replace both batteries to ensure the full 24 volt to power the scooter. yes you use any AGM gel battery.i get mine at batteries plus as it cost about half the price.
carefully using 2 wrenches loosen and remove the small bolts and nuts holding the cables leads to the batteries' terminals, there should be 2 black and 2 red. now either draw how they attached to the positive and negative terminals or mark them in some manner.The batteries have two velcro strips on the bottom of each battery. remove the strips and place in the same position on the new batteries now place the new batteries in the box and press down firmly to seat the velcro, attach the cable leads to the proper terminal, replace the top and turn box upside down and replace the screws. now the batteries are ready to charge up so you can do as i do... race like at speed demon around in circles... happy scooting
Aug 29, 2011 | Pride Go-Go Elite Traveller Plus HD...
What is the power of an electric motor in proportion to the voltage
power measured in watts is a direct proportion of voltage and amperes. one horsepower equals 746 watts. if a motor is dual wound having two 120 volt windings and is paralleled wired it will run on 120 volts at a certain amount of amperes. if that same motor is series wired for 240 volts the amount of amperes necessary for it to run will be one half of the 120 volt rating. as voltage goes up, amperage decreases by one half.
Oct 13, 2009 | Electrical Supplies
I am looking at the same problem/solution
Ok, Heres the deal. A gel cell battery is 7.2 Ampere hrs, so to get 14,4 Ampere hours you would need two batteries connected in parallel. A F&P machine such as mine consumes around 60 Watts of power. Using Ohms law we get W= IxE or Watts = volts X amps[or amperes = watts / volts] so that a 60 Watt machine has a current draw of 60/110< =0.55A so that a 14.4 A/hr battery will run this machine for around 20hrs (allowing a residual charge of 25%)
Jun 23, 2009 | Duracell Standby Power Plug 400 Watt...
Toys Logo
101 people viewed this question
Top Toys Experts
Tom Chichester
Are you a Toy Expert? Answer questions, earn points and help others
