How to change a blown fuse in a onkyo model number ht r580
2 Suggested Answers
SOURCE: Blown Fuse, needs fix'n
Regarding the last answe, how do you know if it is slow blow or fast blow?
Posted on Jan 21, 2008
There was a power outage and now my onkyo ht-r580 won't turn on
Hello, I am sorry about your issue. Please try unplugging the receiver for one hour. If it does not turn on the receiver would need to be serviced or traded in. There could have been a surge when the power came back and it may have damaged the receiver.. Thank you, Onkyo USA
Apr 11, 2017 | Onkyo Audio Players & Recorders
What rca outputs should be used to connect an Onkyo RT 560 receiver's tuner to a Sonos system?
Hi Dennis, could you confirm the model number? Is it an HT-R560?
Nov 08, 2016 | Onkyo Audio Players & Recorders
We have "HT R670" and "HT R360" A/V Receivers with questions regarding Universal Remotes and Android Apps.
The Onkyo App will not work with the HT-R670. This receiver is part of the HT-S6200 Home Theater package and is not network compatible. You might be able to use the Logitech Harmony Hub and app or another remote control app paired with an IR repeater pointing at the receiver. Some universal remotes may support changing the inputs on the receiver. However, I don't know of any specific model that will work. The Logitech Harmony remotes are probably the most likely to support the Input button; it may take programming a specific button to match the receiver's Input function. If you need a replacement for the original remote, one source is https://www.amazon.com/OEM-Onkyo-Remote-Control-HT-S6200/dp/B0137R62H2 . The manual for the HT-S6200 is available here: http://www.intl.onkyo.com/downloads/manuals/pdf/ht-s6200_manual_e.pdf .
I can't find an Onkyo HT-R360 listed even as part of home theater system. There is an Onkyo HT-RC360. The manual for that is http://redirect.onkyousa.com/redirect_service.cfm?type=own_manuals&file=SN29400649_HT-RC360_En_web.pdf . While this model has a network connection, it is not compatible with the Onkyo app either.
I wish that I had better news for you.
Nov 11, 2017 | Audio Players & Recorders
I have 2 onkyo home theater systems, one is an older ht-r8230 with an skw-8230 powered subwoofer & the other system is a ht-r420 with s powered skw-420 sub. all i did was change the rooms the 2 systems...
It's possible that you have accidentally switched off the sub-woofer outputs on the receivers. Onkyo have a speaker set up test. You should run that and see if the speakers are on and that a signal is getting through to them.
May 28, 2017 | Onkyo SKW-110 Subwoofer
Onkyo HT-S6100. Receiver says NO SIGNAL and so
I have the same exact unit and same exact problem. Any luck yet?
Oct 16, 2009 | Onkyo Audio Players & Recorders
Power will not stay on
Activated protection circuitry means that the amplifier is seeing conditions it does not like and is shutting down the power to prevent further damage.
Either you have a short in your speaker wires, in your speakers, or a blown amplifier.
Disconnect both speakers and turn on the amplifier. Does it still give the error message? If it does, your amp is blown. If it does not, carefully inspect your speaker wires and their connection. Make sure all looks good and reconnect the speakers and try it again. Still get the error message? You likely have a problem in your speaker cabinet(s).
Apr 21, 2009 | Onkyo HTR500 Receiver
Onkyo ht-r500
I found the manual sometime back...try 3Xdouble-u dot eserviceinfo dot com
Aug 06, 2008 | Onkyo HTR500 Receiver
You CAN open the unit (keep in mind that even unpluged there is still voltage runing through the system, so.... dont fry) and you will notice, if the face of the unit is towards you you will see on the left hand side a power supply board, the fuse is on that board, and it is a tube fuse, 125V 8A. Most stores do not carry the 125V version anymore, but will carry a 250V. This is okay to use where the voltage is not the main purpose of the fuse.
Oct 19, 2007 | Onkyo HTR500 Receiver
98 people viewed this question
 Grubhead
Grubhead
