Question about Samsung Televison & Video
Dvd playing blue picture
Cannot get colour picture playing dvds normal tv ok colour new 50inch plasma
Connections are ok but dvds keep playing no colour but blue
  • johnfortrees Jan 11, 2009
    still not working done what you said thank you
  • 133 Answers
If it is hooked up with componant, thats the red blue green cables for video, and red white for audio, then you probabily eather dont have the red pluged all the way in, or you have the red audio, and red video---reversed, make sure to check them on the dvd player, and on the tv, if there correct, try using the composit input, that is the yellow red and white
Posted on Jan 11, 2009
HDMI quit working with store bought DVDs
so you have to update a new firmware and then it will be ok
Dec 20, 2007 | Toshiba 52HMX84 52" Rear Projection...
My Plasma 42PD580DTA
I assume your DVD is coming up in colour when you plug it into a standard scart connector? Have you tried using a different S-Video cable because this sound symptomatic of a dodgy lead?
Check the SCART end of your lead for any bent or broken pins.
Failing that if the problem lies with the TV itself I'd really recommend having a pro look at it. Plasma's are expensive and opening it up if you don't know what you are doing is a bad idea.
Dec 02, 2007 | Hitachi 55HDT51 55 in. HD-Ready Plasma...
Cannott get a picture on my tv from my DVD/VHS COMBO
Your DVD player should be connected to either the Yellow White Red connections on your TV set (same color to same color -- dvd OUT to tv IN )
OR it should be connected using the RF cables and connected inline AFTER the Direct TV Box....the box would block the DVD; and possibly the Direct TV Master box would apply 19 Volts to the DVD modulator....destroying the modulator.
Always OUTput to INput on the connections...
Also try with a new set of connections. make sure all the ports are ok.
Hope It's resolve all Problem,
Or
Still having Problem Then follow Us For
Tech support
Feb 07, 2014 | Televison & Video
Our new Toshiba SDV398KC2 will not play a DVD. It is like it is on the wrong channel. It shows the DVD playing with the counter but does not show it on the TV. Can you help?
I've seen this behavior before.
For this model, I *think* that you need to use the component connections/input in order to view the DVDs. If VCR shows ok when using the cable, but not the DVD (and it seems to work since it goes up as if playing), try to connect the component (blue/green/red connectors) and it should work.
Don't forget to switch input on your TV to component.
P.S. If you have HDMI on both this dvd/vcr & your TV, it should work with that too.
Nov 18, 2010 | Toshiba SD-3980 DVD Player
Dvd player only plays in b&w, and connectors dont seem to match up with tv
Go into the player's setup menu and make sure it's set for the kind of connection you're actually using (component, S-video, composite). Also make sure the connections are pushed "all-the-way-in" Lose connections can cause B&W picture.
Sep 09, 2007 | Televison & Video
DVD playback no playback
Sounds like the scart lead is not in straight. Scart connectors have the audio pins at one end, and the video pins at the other. If the lead isn't in straight then you often get sound and no picture and vice versa.
Check the connection by pushing the scart lead in securely. (Both DVD and TV end of the lead)
Failing that could be a dodgy lead.
Mar 17, 2008 | Philips DVDR3380/05 DVD Recorder
Will not play hd dvds
cuse it aint hd dvd ready or blue ray ready ok al it is is a upconvertoing player makes reg dvd look good ok
Feb 02, 2008 | LGDVB418 DVD Player
Picture only shows in black & white when playing DVD
Same problem with an older JVC player. One end of the S-video cable was loose. Pushed in in tight and everything ok again. Cheap fix if it works for you.
Dec 21, 2007 | Televison & Video
Open Questions:
Televison & Video Logo
685 people viewed this question
Henry  Thomas
Henry Thomas
