Question about Toshiba E-Studio 3511 Color Copier
I need to how what ERROR C010 in a Toshiba e-452
3 Suggested Answers
  • 628 Answers
SOURCE: my Toshiba e-studio 3511 gives me a C010 error,
C010 indicates main motor abnormality.
U need to perform output check 03-101(ON)/151(OFF) to off the main motor. If main motor not running under output test, probably u need to replace it.
If motor working, u might need change the LGC board.
Posted on Jun 24, 2009
  • 628 Answers
SOURCE: que significa el error C010 en toshiba est 280
C010 indicates main motor is abnormal.
Is the main motor working? (Perform the output check in the test mode: 03-101/151)
If main motor working, check the feeder's clutch, whether it is hard.
Posted on Oct 24, 2010
ERROR CODE C010 OF TOSHIBA ESTUDIO230
Main motor is not rotating normally. May need to check and clean the belt drive system.
Jul 13, 2016 | Toshiba Office Equipment & Supplies
C030 error in toshiba 205 copier
Toshiba 205 model only have C010 and C040 error cords only, there is no C030 reeor cord. pls check this
Jun 09, 2016 | Toshiba Office Equipment & Supplies
Call service c010
Hi and welcome to FixYa.C010 is a motor drive failure or abnormality. Check for a major paper jam in the drum area or any problems with belts or rollers AFTER your remove the drum. Look for any foreign objects in the belts or plastic gearing. The C101 code usually will appear right after the unit reaches operating temps. After checking for any jams and re-installing the drum. Use your manual and perform the motor output test. 03-101 (Motor on) / 151 (motor off) If the motor runs during this test you may need to change the LGC board. You will see this response for almost every Toshiba C010 error here at FixYa.
Thanks for choosing FixYa,
Aug 12, 2012 | Toshiba E-STUDIO 450 Copier
TOSHIBA E-STUDIO 452 showing error code C440 problem solutions
How con i INCREASE , color of copy in toshiba 452
please sent to my add the GUIDE code toshiba 452
oolmii@yahoo.com
Aug 12, 2012 | Toshiba Estudio 200L Copier
C010
Hi and welcome to FixYa. I am Kelly. C010 is a motor drive failure or abnormality. Check for a major paper jam in the drum area or any problems with belts or rollers AFTER your remove the drum. Look for any foreign objects in the belts or plastic gearing. The C101 code usually will appear right after the unit reaches operating temps. After checking for any jams and re-installing the drum. Use your manual and perform the motor output test. 03-101 (Motor on) / 151 (motor off) If the motor runs during this test you may need to change the LGC board. You will see this response for almost every Toshiba C010 error here at FixYa.
Kelly
Nov 04, 2010 | Toshiba E-STUDIO 450 Copier
Que significa el error C010 en toshiba est 280 por favor alguien se lo sabe, gracias i.b
Oct 23, 2010 | Toshiba e-Studio 350 Copier
Estudio350 with error c010, checked the fuser, drum unit , dev unit, all are turning freely, error comes on as soon as fuser comes to full temp
Hi
Error C010 indicates main motor fault. Please check the main motor. If main motor not running under output test, then you'll need to replace it. If motor working, u might need change the LGC board. Take the drum unit out and check inside for any irregularties in drive system belts.
Hope this helps...
Daniel
Sep 30, 2010 | Toshiba E-Studio 3511 Color Copier
My Toshiba e-studio 3511 gives me a C010 error, what does that mean??
Jun 24, 2009 | Toshiba E-Studio 3511 Color Copier
Toshiba E-Studio 3511 Color Copier Logo
88 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
Branko Djurdjevic
Branko Djurdjevic
CheckitRight
CheckitRight
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
