Question about Xerox WorkCenter Office Equipment & Supplies
Please problems with code U2 FOR XEROX WORKCENTRE 5020
U2 CODE APPART
  • 2072 Answers
SOURCE: Using Xerox Workcentre 385 with Mac OS X 10.5
I went to the Xerox site and there is not a driver listed for a Mac platform for that product.
Wish I had a better answer for you.
Posted on Jan 27, 2008
  • 2072 Answers
SOURCE: xerox 390 error code 1
> Support & Drivers > WorkCentre 390 Laser All-in-One Support > Search Results > How To Clear a Fuser Error Message Solution: Perform a RAM Clear bttn_print.gifMake Printable bttn_email.gifEmail this page elem_1_spacer.gif Performing a RAM Clear will restore all of the WorkCentre's settings to the factory defaults. It will also clear all faxes in memory, Speed Dials, One-Touch Buttons, Group Speed Dials, your System ID, and any other stored information.
NOTE: If you are able to print, it is a good idea to print out your Phone Book before performing the RAM Clear, to assist you in reprogramming your Speed Dials and One-Touch Buttons. It is also recommended to print out your System Data List to assist you in reprogramming your system settings. If you are not sure how to print your Phone Book or System Data List, refer to Related Items at the bottom of this page.
To perform a RAM Clear:
  1. Press the [Menu] button on the Control Panel.
  2. Press the [#] key, then press 1934.
  3. NOTE: These buttons should be pressed quickly. If not successful, try varying the speed you are pressing the buttons.
  4. When this step is successful, the bottom right-hand corner of the LCD Display will read 'TECH'.
  5. NOTE: If you are unable to access Tech Mode, please refer to Related Items at the bottom of this page.
  6. Press the [Menu] button to start navigating the menu.
  7. Press the [Up] or [Down] arrow button until the LCD Display reads 'Memory Clear', then press [Select] button.
  8. The LCD Display will read 'US and Canada'.
  9. Press the [Start] button to clear memory.
Posted on Jan 19, 2008
namizhka
  • 148 Answers
SOURCE: Installation of a Xerox workcentre pro 412
download the driver on the link here ABOVE.
Posted on Sep 16, 2008
SOURCE: Is there a Mac workaround driver for the Xerox WorkCentre PE16
Recently I had to configure a 17" Aluminum PowerBook and a Xerox Workcentre PE 16. That multifunction laser monochrome printer is not supported by MacOS X, but I tried all the same.... and no glue for that, until I went on the Samsung webpage and noticed their SCX-4216F printer. This machine is the same as the PE 16.
So I downloaded the lastest drivers from Samsung's download centre (drivers for Tiger too), installed the drivers on the PowerBook (running 10.3.4), connected the printer and when I selected the printer ... tada! It automatically selected the Samsung driver, so I clicked on OK and started printing. Everything was OK!
But it doesn't end here: even the Lexmark X215 MPF has the same chassis as the Xerox and Samsung. Yet, on Lexmark's website there are no Mac OS X drivers, but Samsung's drivers work just the same. I hope this hint will help others...
Posted on Jan 26, 2009
  • 111 Answers
SOURCE: Error code 39,003,40;61256 on a xerox workcentre
Here is the easy solution to fix the issue :
Click on the link and follow instructions to fix the issue.
http://www.pchell.com/hardware/cd_drive_error_code_39.shtml
Posted on Apr 01, 2010
XEROX WorkCentre 5020 given error code u2
That error signifies a carriage fault with the ccd scanner under the platen glass. Check connections of flexible cable and verify that the carriage moves left to right upon start up. If connections are okay you either have a defective IIT Carriage or IIT Carriage Sensor.
Apr 27, 2016 | Xerox Office Equipment & Supplies
U2 code for xerox work center 5020
U2-1 Carriage Module Fail
Maybe you can find more information in the service manual. About error codes go to page 20
Apr 16, 2014 | Xerox Office Equipment & Supplies
Xerox workcentre 5020/Dn c1 error
i have one xerox 5020 machine, there is display showing C1 error code in first tray and C3 error code in bypass tray .if open and close the machine will be idle and ready to cpoy. there is no paper pick up in both trays. please help to resolve the problem.
Dec 17, 2012 | Office Equipment & Supplies
How to reset NVM in xerox workcentre 5020
how to set xerox work center 5020 sound problem
Jul 11, 2012 | Xerox Office Equipment & Supplies
I have a xerox 423 with au3-5 error.whats up?
i have a xerox 423 with u2-3 error code whats that
Dec 07, 2010 | Xerox WorkCentre Pro 423 Copier
Xerox wc pro 423 u2-3 problem
my Copise Xerox work center pro 423 are showing on display this error (U4-2) how i can clear this error please please tell me any body if knows
Nov 16, 2010 | Xerox WorkCentre Pro 423 Copier
My Xerox Workcentre-5020 machine showing U4 error. How can I solve this problem ?
@basanta711, Press 0 for 5 seconds then press green (start) then 50, green, 20 green, 0, green then on/Off the printer........... problem is solved
Nov 07, 2010 | Cell Phones
My machine shows a U4 code
U4 code refers to a fuser heat failure, you'll probable find the fuser roll is stone cold .Possible cause is open circuit heater or overheat thermostat popped.Either way you will need to pull out the fuser unit and check continuity of the components
May 29, 2008 | Xerox WorkCentre Pro 423 Copier
109 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
