Question about Konica Minolta bizhub 250 All-In-One Laser Printer
Our bizhub-250 receives a C2557, need help with service mode
Yesterday I changed the drum and developer unit of the machine. The very last step involved performing an ATDC adjustment. For instructions I was refered to another manual which said I needed to go into Tech. Rep. Mode ((I believe that this may be the same as the service mode that people are refering to when discussing a C2557). For that I was refered to the service manual, which wasn't available anywhere. I decided to go right ahead and test the printer anyway, at which point I received a malfunctions-error C2557 and realized my error. If anyone knows where I can find a copy of the service manual or can tell me how to go into Tech. Rep. Mode or service mode I would be more than appreciative.
  • 1 more comment
  • DMenscha Jan 27, 2009
    My machine says
    TEL
    FAX
    C-2557
  • bengumay Feb 04, 2009
    atdc c2557 how to reset this problem, pls help
  • Anonymous Mar 28, 2014
    tech rep mode
  • 210 Answers
Utility/Counter -> Details -> [STOP][0][0][STOP][0][1]
Go to counter and clear the life of the developer and drums and then run F8 from functions.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
Posted on Sep 03, 2009
  • ozzie espinoza
    ozzie espinoza May 15, 2014
    This only works for the older models new models completeley different.
I have the same problem with error code c 037 ( Konika Minolta Bizhaub 350 )
Posted on May 19, 2011
    Problem Solver:
  • 5 Answers
You need to replace the drum and developer, then reset the drum and developer counters and f-8 the developer this is all done in the tech rep mode
Posted on Aug 26, 2009
  • 1 more comment
  • ejcm40 Aug 26, 2009
    1. press the Utlility/Counter key
    2. touch [check Details]
    3. press the following keys in this order
    stop-0-0-stop-0-1
    4. enter the eight-digit code
    00000000 then touch end
    this puts you in the tech rep mode screen
  • John La Jul 19, 2012
    Is this the same method to enter the tech mode for the NEC IT2530D?
  • haseeb iqbal Apr 29, 2013
    toner problem 2557 error tcr ad
I have the same problem with error code c-2557
Posted on Apr 06, 2010
I have the same problem with error code c-2557 in Konica Minolta C353 laser color printer/copier. Please provide the solution. I have switched it off 3-4 times and on after 10 mins but still have the same problems.
Posted on Jan 06, 2010
    Problem Solver:
  • 5 Answers
C2557 is ATDC sensor failture, first check the level history in service mode,
press utility/counter, stop-0-0-stop-0-1, press the password, "00000000"
and the press level history, normally, atdc sensor have around 5.0%-7.0%,
if less or more than the presentase, the machine will appear code C2557.
1. change the adtc sensor gain.
in the service mode, press tech.rep.choice-printer-atdc sensor gain, set the value around 0-255, with the persentase 5.0%-7.0%
2. if the panel warning please exchange pc drum, print dirty, blur or dirty better ur change the drum, developer and transfer roller one go.
before u change the drum, developer and transfer roller, make sure u reset the counter,
in service mode, press counter-special parts counter, select the pc life and the press key c. select maintenance counter and reset also.
after u change the spare parts, do f8 quickly, in service mode
press function-F8, the machine will automaticly run and adjust atdc sensor.
if all already finish, off the machine and wait 10 second and the on again.
i hope this can help u solve ur problem,
regards, ^^,
Posted on Oct 11, 2012
Konica minolta bizhub 215 giving error c2558
C2558
Abnormally high toner density detected TCR sensor board
- The T/C ratios detected by the TCR sensor board (TCRSB) are above the threshold for the detection of abnormally high T/C ratio for three successive times.
- The connector between MFPB to TCRSB is disconnected.
Error Codes Konica Minolta bizhub 215
Mar 07, 2015 | Konica Minolta Office Equipment & Supplies
C2557 code bizhub 250
The ATDC sensor on the drum imaging unit is bad or the developer is bad. Recommend replacing drum imaging unit with new developer.
Aug 09, 2011 | Konica Minolta bizhub C250 All-In-One...
On my bizhub 250 copier, there is a message stating " Please change PC Drum" My question is, How do I change PC Drum?
This is a service technician performed function. The PC Drum unit is changed by removing the whole imaging unit and then removing the drum section and changing it out. At the same time the developer needs to be cleaned from the developing unit and replaced with fresh developer. The drum counter is then reset using the service mode and then the new developer must be calibrated using the F8 mode. So in this machine's case, this is just not a pull out the old unit and plug in a new one.
If you find the "right" service guy, he can come in and reset the drum counter and do the f8 without changing either the drum or the developer. This can sometimes get twice the life out of the unit. Copy quality can degrade a bit towards the end of the second cycle.
If you just reset it your looking at around $100. If you do everything that is called for then the cost is more like $350.
Good Luck and Thank You for using Fixya.
WheatlandServices
Jan 20, 2011 | Minolta bizhub 250 Black and White Copier
We have Konica Minolta Bizhub 250 What does error C2557 mean
Error code c2557 means "Auto Toner Density Control sensor abnormality" (ATDC)
Sep 20, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
The massege is code c2557 that message what's mean
c2557 means your machine is having problem with its ATDC SENSOR.
Oct 18, 2009 | Konica Minolta bizhub 180 All-In-One...
Error c2557 konica minolta 250/NEC IT2530
Reset it, start it with the right door open, go to service mode, clear the counters for drum and developer and go to functions menu. Close the right door and start immediately the F8 function. It should work.
Jul 31, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Konica/Minolta biz 350 C2557 after replacing DV unit and drum F8
tha minolta di3510 developer unit looks the same as the unit for the konica minolta bizhub 350 but the toner sensor in the minolta unit uses a different voltage range for the toner sensor and it will throw this code make sure you have the correct unit for this machine also you can try this
go back into tech rep mode and change these settings:
select tech rep choice mode
select printer tab
select atdc sensor gain
set the value to about 165
then back all the way out to the ready screen and power the machine off then back on and replenish toner in the user management screen.
Apr 22, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
hi,
open and close front door cover to reset error.
If it persists you have to execute (TCR Toner SUPPLY)
Tell me if you need to execute it.
Bye.
Mar 05, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
BizHub 250 Malfunction Code C2557 - HELP!
I can even reach the "service mode".
The screen shows the error (c2557) and I can not access to anyother function.
Nov 11, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Konica Minolta bizhub 250 All-In-One Laser Printer Logo
8,320 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
