Question about Sony DCR-TRV 460 Digital 8 Mini Camcorder Pal system
Hi 8 / 8mm distorted playback
Sony Digital DCR TRV460 camcorder playbacks tapes with distortion of video and audio. Video has vertical lines running through playback and there is sometimes jumping of video segments. Some of these tapes were originally recorded in this device. What needs to be done to the camcorder to fix the problem.
  • lestermcfest Mar 07, 2009
    i have exactly the same issue...do you know if there is another way to download the hi8 cassette video to dvd or video cassette?
5 Suggested Answers
SOURCE: Playback is choppy
I had this problem very recently. In fact I borrowed camcorders from my friends too and after short periods, they too started having the same problem. Essentially, it looks like there is some choppiness every second or so - like there is noise in the audio and video. After a lot of looking around, I finally found a suggestion posted that ACTUALLY WORKED on all 3 camcorders:
I placed an empty tape in the camcorder and recorded a few seconds into it. Then I removed that tape and tried to play the previous tapes that were showing the choppiness. No problems any more. Everything works fine.
What I still do not understand is why 3 camcorders (all DCR-TRV103s) all showed the same problem (with different tapes by the way). And since I still have lots of tapes to copy, I need to know why this problem is happening so I can minimize its occurrence while I complete the copying process.
People have suggested that my tapes are old and may be offering resistance to the camcorder. So I have ordered a rewinder to spin the tapes a bit before trying again. The two possibilities suggested around this was (1) some mechanical switching took place which got reset when recording; and (2) something got corrupted in the software that manages the playback buffer and that software was rebooted when it went to recording mode.
So while this will hopefully answer your question, I'm also looking for explanations for why this happened to me on 3 different camcorders.
Posted on Mar 18, 2008
philipp
  • 217 Answers
SOURCE: Sony Camcorder playback problem
mechanical alignment! try to record for a minute and playback the result on another player/recorder, not on your camera, if the playback is not okay then your camera needs alignment, you need pro fix. You said that you've done manual cleaning already, maybe you dis aligned the mechanical parts accidentally, applying too much force on the mechanical parts of your small unit tends to bend, dislocate or move these parts out of alignment. defective videohead will never playback good video, and you said that it seems to correct only a few minutes of playback.
Posted on Sep 14, 2007
ctf1800
  • 4402 Answers
SOURCE: Sony Handycam DCR-IP7E Micro MV Digital Camcord
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
Posted on Jan 28, 2008
SOURCE: Problems with playback of HI8 tapes...
What's happening is that the tape in the cassette is being chewed on one side by the camera's tape transporting mechanism during playback, hence the distorted image and sound. The mechanism might be damaged (misalignment) or just dirty. Try not to play other tapes on this unit because they will become permanently damaged. The best way is to find another camcorder (if cleaning does not help). Note that some old cassettes of long recording time will exhibit this behavior more often because of thinner tape used.
Posted on Jun 21, 2008
quang123
  • 107 Answers
SOURCE: Hi8 Playback Compatibility with Digital* Camcorders
I believe all Sony model DCR-TRV2XX and 3XX would play Hi 8 and ST8
Such as DCR-TRV265, DCR-TRV285 DCR-TRV340, DCR-TRV355
I hope that give you some ideas
Posted on Dec 04, 2008
Hi, I have a sony tvr 140E. When I try to play back a tape that was recorded from another digital 8 camcorder I get blue screen. when I play back a tape recorded on my camcorder plays fine. Any...
This smacks of the same problem that the old VCR's used to have. One of you are out of sync. The tape records on a portion of the tape in a sort of straight line track. Think of it as your track is down 1/16" from the top. The other camera tracks it's video down 1/8" instead. That's why in playback it can't read it. The only cure is a realignment. Nimsgame
Feb 19, 2011 | Sony Handycam DCR-TRV460 Digital Camcorder
Sony dcr-trv25 when playing back tapes sound goes on and off pic sometimes distorted tried cleanig with tape still doing same thing I dropped camera from a standing position (3ft) nothing broke thats when...
Yes sounds as though the audio playback head had become misaligned by the drop... You will have to get it back in position again. Thats a job and a half though, really only something that can be done by a tech?
Feb 17, 2010 | Sony Handycam DCR-TRV25 Mini DV Digital...
How to fix choppy audio on Sony DCR-TRV 460 camcorder. Video is ok.
I had problems with playback on mine, and solved the problem by giving it a good tap on the hand strap side of the camcorder.
Hope this helps.
Jason
Dec 31, 2009 | Sony Handycam DCR-TRV460 Digital Camcorder
Sony DCR-TRV460 not playing back, blue screen
Follow this procedure to troubleshoot if a blue screen is displayed when attempting to playback video from the camcorder.
  1. Stop the tape.
  2. Ensure the tape has been rewound to the beginning of the video recording.
  3. Play the tape.
  4. If the issue is not resolved, stop the tape and remove it from the camcorder.
  5. Clean the video heads of the camcorder using a dry head cleaning cassette.IMPORTANT: Follow the instructions for use provided with the head cleaning cassette. It may be necessary to use the head cleaning cassette more than once per session.
  6. Reinsert the tape into the camcorder.
  7. Play the tape.
  8. If the issue is not resolved, stop the tape and remove it from the camcorder.
  9. Insert a different tape with video footage into the camcorder.
  10. Ensure the tape has been rewound to the beginning of the video recording.
  11. Play the tape.
NOTES:
  • If a blue screen is still displayed, then the camcorder may require service .
  • If the tape plays back correctly, then the first tape may be faulty or there is a problem with the video recording.
Aug 13, 2009 | Sony Handycam DCR-TRV460 Digital Camcorder
Distorted sound on playback, samsung mini dv camcorder.
Try a DV tape cleaner first. If that doesn't work, see what it would take to get the audio heads realigned. Any camera store can do that for you.
Dec 18, 2008 | Samsung SC-D67 Mini DV Digital Camcorder
Distorted picture when looking through view finder or lcd screen
the video playback is sampled off the video out and independently processed sorta like a TV signal to project on the lcd screen.
horizontal lines means you lost sync circuit and needs troubleshooting. Hopefully maybe a bad connection with a ribbon cable for the ICs and components are hard to change and jammed tight. I would order a video board.
May 14, 2008 | Sony Handycam DCR-TRV460 Digital Camcorder
Playback problems started suddenly
I had the same problem. I fixed it by gently dropping the camcorder on the carpeted floor. I know it sounds silly, but it really works. I've had to do it twice, and it worked both times. I hope it works for you.
Jan 08, 2008 | Sony Handycam DCR-TRV460 Digital Camcorder
Dec 06, 2007 | Video Cameras
Sony handicam trv skips playback like in slow motion?
you need a computer with at least 1.5 ghz and 1 gig of ram anything less will cause recording to pc problems
Oct 26, 2007 | Sony Handycam DCR-TRV280 Digital Camcorder
Sony DCR-TRV 460 Digital 8 Mini Camcorder Pal system Logo
167 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
sonic boom...
sonic boom...
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
