Question about Sanyo Microwave Microwave Oven
How do change light bulb in sanyo em-g4753 - Sanyo Microwave Microwave Oven
MicrowaveSvc
  • 9098 Answers
SOURCE: Change light bulb in Sanyo Microwave EMS6786V
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
If you don't have your instructions, please reply back with your brand and model number.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Oct 20, 2008
SOURCE: EM-G4753
I did a google search for the service manual and found one from Sanyo support. From that I was able to figure out how to open the unit safely, and find the fuses and safety switches to check. I found a loose wire plugged onto the main interlock switch (don't know how it worked all this time for how loose it was...). Re-attached it, and now it works fine.
WARNING! There can be very hi voltages on the inside of the uwave so you really need to be careful and know what you are doing! Also, you need a special bit to remove a couple of the cover screws.
Posted on Apr 15, 2009
Kewyn
  • 103 Answers
SOURCE: how do i change bulb in sanyo microwave EM-SL30N
Make sure it is unplugged. Yes you must take the cover off and you will see the bulb. Gain access to it and replace it. Do not interfere with anything else.
Posted on Nov 09, 2009
fieldy14
  • 456 Answers
SOURCE: replace light bulb on SANYO EM-U1000W Compact
PLESE BEFORE YOU DO ANYTHING RFER TO A GUI HOW TO DISCHARGE A HIGH VOLTAGE CAPACITOR OR SEEK THE HELP OF A MICROWAVE TECHNICIAN. As for changing the bulb, if you remove the case you will be able to locate the bulb, and merely a case or removing ad replacing with a new one. Good luck.
Posted on Nov 16, 2009
  • 8909 Answers
SOURCE: can i make a cake in sanyo EM G4753?
Yes. Follow the cooking instructions supplied.
Posted on Dec 23, 2010
I have a Sanyo microwave oven EM-S8586W/V and I need to replace the light bulb. Where is the bulb located please?
small screw bulb e14 type for fridges. its behind the screw plate next to were the holes are on the side of the microwave right side. usually 3 wat
May 18, 2018 | Sanyo Microwave Ovens
User manual of intructions for Sanyo Microwave 900W EMG4753S
First of all, thank you very much for choosing FIXYA today for your online technical support needs.
Here is a direct link to the ONLINE USER'S MANUAL for that model:
http://uk.sanyo.com/AssetBrowser/Technical%20Database/Instruction%20Manuals/Microwave%20Ovens/EM-G4753.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and blue highlighted text just above.
This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents, although many computers already have this type of utility pre-installed.
You can download this free at WWW.ADOBE.COM if necessary. Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
I truly hope that was helpful to you.
Good luck and take care.
Joe.
Nov 28, 2011 | Microwave Ovens
My Sanyo microwave oven (model: EM-G4753) isn't heating my food. Everything else works, the fan, the lights. The microwave turns and sounds like everything is working but the food won't get hot. It is only...
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
YOUR SAFETY IS PARAMOUNT
This is a job for a professional but if you are safety clued up, here's instruction.
Make sure the !!!!any capacitors are discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 or moving coil meter on high resistance range for short circuit, (DVM's won't show the fault!), the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Feb 24, 2011 | Sanyo Microwave Microwave Oven
Can i make a cake in sanyo EM G4753?
Dec 23, 2010 | Sanyo EM-S5002W Microwave Oven
How to replace light
there is either a panel on back of unit you can remove and light bulb is there, if not you will need to remove case to change bulb.
Nov 25, 2009 | Sanyo EM-S5002W Microwave Oven
Replace light bulb on SANYO EM-U1000W Compact Microwave Oven
Nov 16, 2009 | Sanyo Microwave Ovens
How do i change bulb in sanyo microwave EM-SL30N What do i do must i take the cover off what is the easy way please.
Nov 09, 2009 | Sanyo EM-Z2100GS Microwave Oven
EM-G4753
Apr 14, 2009 | Sanyo EM-P410W Microwave Oven
Changing Microwave bulb
Remove lid, you'll probably need a pozi drive screw driver and a tamper proof torx drive.
The bulb is located near the front.
Mar 15, 2009 | Microwave Ovens
REPLACING LIGHT BULB
i have a cookwork microwave the light stoped working
Sep 16, 2008 | Microwave Ovens
Sanyo Microwave Microwave Oven Logo
55 people viewed this question
Top Sanyo Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
robert landry
Are you a Sanyo Microwave Oven Expert? Answer questions, earn points and help others
