Heating problem the heater in the central heating is not getting turn on but the fresh air and cooling i can still turn on
  • 70 Answers
The tstat sounds like it is not connecting the white and red terminals which is usually the heat cycle if it is a gas furnace if so to check I take tstat cover off and jump white terminal to red terminal this is the standard heat position the unit should fire the heat cycle if not a gas funace let me know what type of unit you have hope this helps
Posted on Jan 11, 2009
Honeywell thermostat blows cold air on heat
Thermostats don't actually blow anything, the heating system might though. Check the breakers for your heat system, then call a heating specialist. They're really not that expensive.
Oct 06, 2014 | Honeywell Heat/Cool Thermostat
Every time we put on the central heating our water runs cold
What kind of water heater do you have?
In any case, it sound like a plumber should check out system.
Do you have indirect heater that gets heat from central heating boiler?
Most indirect/boiler combo heaters have control that is set to heat the water first.
If water is not getting heated, then the control needs repair.
Do you have gas water heater with gas central heating?
The central heater may be drawing so much gas from meter, that other gas appliances are unable to function. larger gas meter or gas line may be needed.
Or if furnace and water heater vent on same chimney, the backflow from central heat could be affecting burner on water heater especially if water heater has electronic sensor that stop combustion if air quality is bad. Venting problems can lead to CO poisoning, and are a serious matter.
Nov 18, 2010 | Water Heaters
The cold air return is bringing cold air into the house
The Cold Air Return is really the Return Air. The Purpose of the Return
air duct is to pull the cooled or heated air back to the furnace. It then
filters the air before getting cooled or heated again.
This is what controls the thermostat, which starts and stops the unit. In
the end this is how your air stays conditioned. In some states it is
required by law that a 4-6inch fresh air vent be tied into the return air
duct. Everytime the furnace fan comes on, it pulls in fresh air from
the outdoors.
Feb 10, 2010 | Dayton Gas Furnace Heater
Central heat won't turn off instantly.
yes it is normal. the blower continues to run after the heat turns off to cool the system down.
Nov 25, 2009 | Heating & Cooling
High Electrical bill - Appears to be heatpump problem.
Sound like there are running on emergency heat which is elrctric.Have the system checked out buy a local heating and cooling company. Have they checked the filter and changed them.
Jan 14, 2009 | Honeywell Electronic Programmable...
The heater in my central heating is not getting turn on but the fresh air and cooling is getting turn on
Check the pilot light.Older standing pilot systems use thermocouples to verify the pilot is burning before the gas valve opens.If the pilot wont stay lit replace the thermocouple.
Newer systems light the pilot.On a call for heat the igniter lights the pilot. When the heat is verified the gas valve opens . Some systems use an circuit board with flashing led lights to help troubleshooting.
Jan 11, 2009 | Heating & Cooling
Central air and heating, not cooling
Need to have checked out by a diagnostic ac man.
Aug 08, 2008 | Haier Energy Star ESA3183 Air Conditioner
Central honeywell air conditioner
Sounds like it may have lost power. Check the breaker and the fuse at the furnace. If they are all in the on position and working then it sounds like you may need a technician. If the display is blank on the thermostat you may also want to replace the batteries.
Jun 12, 2008 | Honeywell Electronic Programmable...
Heating & Cooling Logo
81 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
