Question about Dell W5001C 50 in. Plasma HDTV
3 year old large screen Dell plasma. For the past 3 days an error
Message "weak signal" appears constantly at upper left of screen in blue on a black background. The weak signal on blue is about 2 '' x 4 " while the black background is about 6 ''x 9 '' The picture is otherwise good with no evidence of a weak signal. I unplugged the cable box and the weak signal sign remained. Is this a sign that this TV is about to have a major failure and need replacing?
  • besicarl Jan 11, 2009
    3 year old Dell plasma tv. "weak signal" sign appears constantly at upper left of screen. "weak signal" sign is on blue background over a larger black background. Otherwise picture is ok. Assuming that the problem is probably the powerboard and the lack of trained hi tech tv tecks in this area, would it be more economical to replace the tv (given the drop in price over the past 3 years) vs. the costs of parts and labor to replace the powerboard?
    Novelist:
  • 115 Answers
Some of the answers I've read make sense, but why don't you start with the obvious first: I strongly recommend calling your cable or satellite company to make sure that you don't actually have "a weak signal" first before you go paying for tv repair, etc.
Does it not make sense that this 'warning feature' was programmed into your tv because weak signals are common - not because of an electronic problem?
There's no use spending lot's of money if the real problem can be solved with a $10 signal booster or re-aiming a satellite dish. Good luck!
Posted on Jan 11, 2009
  • 55 Answers
Have you by any chance changed or added a tv in another room about the same time this showed up? I have a dell plasma hooked up to my cable and had the same problem when I added another tv in my daughters room. I installed a signal booster and the problem went away. Obviously if nothing has changed elsewhere in the house, this can't be the problem.
  • 141 Answers
YOu are correct in the assumption that the power board is approaching failure. Given the fact that the unit is a few years old and there has been mass changes in the components. The cost to obtain an new powerboard vs a new tv is a given. New TV wins at this stage of the game.
  • 108 Answers
What are you suinf for your signal? Cable, satellite or Antenna
    Genius:
  • 2,035 Answers
Try to reset :
Reset the original factory defaults. Press Menu on the remote
control, select Setup, and then select Factory Reset.
Then check if it stills as the weak signal on the screen...
Good luck...
  • 124 Answers
Some plasma tv over time if left on a image gets buened into the screen and will remain for a long period of time your tv could have been on while you were away and the image got burned into the screen just try to play some action movies or fast paced movies on the screen to see if issue still remains i hope this helps you
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 448 Answers
For all my experience on t.v.
YOU GUESSED IT. I have one that showed dominant colors in the corners. Did a simulated deguazing on the front. Cleared it up but the screen just went to the next stage of break. Live chat and I'l tell you how to do it. If you found this helpful, please post as such.
    Genius:
  • 1,550 Answers
Yes it tends to be failure of the power board . It is major failure and you need to replace the board . You need a technican to do this .
I have a Sharp Aquos LC-70SQ15U that is about 3 years out of purchase.
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Sep 28, 2017 | Sharp Televison & Video
Tv went black no sound either. TV only five years old,is there anything i can do? Thanks James
Cannot offer solution but my mine has also gone bad.  At first a black shadow appeared on the left side of the screen.  Took it to the authorized service center.  they kept it a few days, said nothing could be done.  Used it anyway for the next 5 years when suddenly it went black (or sometimes blue) after working perfectly for the first 5 minutes. A sharp rap next to the right speaker fixed it a few times, but no more.  Good luck.
Bill
kepner13@olympus.net
Jul 18, 2011 | Maxent MX5020 50 in. Plasma Television
A black _ in the upper left hand corner (size of underscore)
It is what we call a "Shatted Pixel" and you can fix it by flashing your screen
Dec 22, 2009 | Dell Computers & Internet
TV turning on and off
Air 2 is the source it's looking at for a signal - - where is the signal plugged into? and are you able to change the input or source to look at another?
Bill
Nov 29, 2007 | Akai PDP-5016H 50 in. HD-Ready Plasma...
TH-50PX60U picture problem
Try to replace the Logic Scan board on the upper left side of your tv. The part no. is printed on the board and you can order it from Panasonic's Website. Also check the Service Manual for the part description and part no.
Oct 17, 2007 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Apex 32" TV - Blue Screen & Channels keeping running/changing
blue screen indicares that there is a problem in blue cathode circuit. please check 1 blue video output supply. 2 blue video ckt defective 3 signal from chroma ic to blue cathode missing. 4 loose connector 5 crt base loose. 6 chroma ic defective. I think sound will be ok .
Sep 22, 2007 | Apex Digital PF3230 32" TV
Blue shading problem
2 months old? I'd call the dealer..it's under warentee. You have a problem that will not get better.
Jul 14, 2007 | Samsung PS42P4AX 42 in. HD-Ready Plasma...
Dell W5001C 50 in. Plasma HDTV Logo
43 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
