Question about GE 27938 Cordless Phone
Blown Resistor When I plug the base into the wall socket, and then put my handset on the base, the charging light does not come on and the phone will not work. I took the phone apart and have deduced that the problem could be a resistor that has melted. It is so bad that I cannot ascertain what size of resistor that it is(can't tell color code). It is resistor # 110. If anyone could tell me what size of resistor that is, it would be great.
  • Matt Sheldon Jun 07, 2007
    I have not tried your suggestion, but I am fairly sure that it will not work as I have removed the resistor in order to try to read the color code. I have tested the resistor with a meter and it is fried, so badly that I can't even tell the color code.
  • 883 Answers
Because the phone will not work, first prove that it can. Try this: remove the battery and charge it. Read the voltage on the battery label. Read the voltage on the charger label. If the numbers match, then connect 2 wires to the battery from the charger (use tape) with positive terminals on one wire and negatives the other. after charge...about 2 hours, does the phone work?
Posted on Jun 07, 2007
HOW DO I REMOVE A CORDLESS PHONE AND SET UP A NEW ONE?
disconnect the base phone at the wall socket and put the new base phone line into the wall socket
follow the user directions that came with the new phone to set it up
Oct 19, 2015 | Uniden DECT 6.0 Cordless Telephone...
How do I get a dial tone?
Is the base station plugged into the phone jack on the wall?
May 17, 2014 | Swissvoice Epure Full Eco Cordless...
Panasonic phone says check tel line
Check cable conections from phone box on wall to base unit, make sure that the conectors are fully inserted. If possible plug a different phone into box to make sure that line is working. Hope this helps
Jun 08, 2017 | Lands Phones
My phone is model #CS6328-3. Base is saying
unplug a/c cord from wall for the base... remove all batteries from handsets ley sit for 10- 15 mins then plug base back in put battery in one handset at a time return handset to base let charge, then reset base station and handset to same settings...
Nov 30, 2017 | Lands Phones
My new phones will not take a charge
Lets start from scratch. Make sure your wall outlet has power. Plug in a working electrical device such as a lamp, radio or vacuum cleaner. It the wall socket works, plug the base back i the socket and make sure it isnt loose or falls out of the socket. Then make sure the other end of the cord is securely plugged into the base. Also make sure the battery in the handset is sucurely and ?correctly in place and the handset is also surcurely in the crade(base) so the metal contacts of the handset are touching the base metal contacts. U may have to let the phone fully charge overnight for 8 hrs while your sleeping without trying to use it. If this doesnt work, u may need new replacement batteries or a battery pack(whichever your phone has) by taking the origional battery to your local electronic store.
Jul 09, 2011 | Uniden DECT 6.0 Cordless Phone
How do we complete a basic set up for Plantronic CS70 VT head piece?
Plug in powerpack to the base unit.
Unplug the handset with the curly cord from the phone and place both aside.
A short cord connects between the Handset socket on the PHONE and the PHONE socket on the BASE UNIT.(socket is near the power socket)
the HANDSET and curly cord plugs into the socket near the front of the base unit- it's the one that's extreemly hard to plug in!
Charge for 12 hours before use
Call someone and get them to stay on the phone while you turn the rotary knob (may need a screwdriver) on the side- keep turning it until you can hear each other
look for orange light as you hang it up to indicate that it's chaging
Done!
Good Luck!
Jan 13, 2010 | Plantronics CS70 Wireless Headset
After charging a Uniden 2180-2 DECT 6.0, the base stope showing anything on its display. As for the other handset, their display report " searching" since they can' t connect to the base. What is goin
Reset Procedure for Cordless Phones
Question:
What is the general reset procedure for cordless phones?
Answer:
1. Disconnect Battery from handset(s)
2. Disconnect Phone Cord from wall jack
3. Disconnect Phone cord from base unit
4. Disconnect AC adapter from wall outlet
5. Allow to sit for 30 min
6. Reconnect Phone Cord to base
7. Reconnect Phone cord to wall jack
8. Reconnect AC Adapter to wall outlet
9. Reconnect Battery to hanset until you click or feel the plug snap into place
10. Re-Register Handset by placing on main base in most instances
May 05, 2009 | Lands Phones
My phone is dead
Question:
Answer:
10. Re-Register Handset by placing on main base in most instances.
<KEYWORDS="RESET, call,? can?t tone, dial no flashing, unavailable, range, of out working, not up, messed>
May 05, 2009 | Uniden Cordless Phone
Second set does not work
I had this problem - just found the solution. The two charging stands aren't the same. One is a base (that plugs into the wall) and the other a charging cradle. I think that each handset needs to be placed in the base to "register" it.
So, here's what I did: place the unregistered handset in the base & both should work.
Jun 26, 2008 | GE 25952 Cordless Phone
Blown Resistor 2
tell me how large it is (physical dimensions) and I will get you close to its value.
Jun 09, 2007 | GE 27938 Cordless Phone
GE 27938 Cordless Phone Logo
90 people viewed this question
Top GE Lands Phones Experts
Dudeman321
Marvin
Marvin
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
