Question about Whitehaus Kitchen Single Handle Faucet with Spray ....
Whitehaus kitchen single handle faucet o-ring
2 Suggested Answers
txpipelayer
  • 20 Answers
SOURCE: Kitchen faucet-Whitehaus brushed nickel #
John, there should be a parts diagram online. You will need to order the correct orings and install them using plumbers grease for lubrication.
Posted on Sep 16, 2010
How to replace 0 ring on a Delta (brizo) single handle Kitchen faucet model # 61600 SS170?
TAKE IT APART. LOOK FOR SMALL SET (ALLEN) NUT/BOLT OR REGULAR NUT/BOLT YOU CAN TAKE OFF THEN TAKE OFF HANDLE AND REPLACE THE O RING.
Oct 08, 2014 | Delta Plumbing
My delta faucet 172-sswf waterfall single handle kitchen faucet is leaking at the handle or lever how do I repair it?
i forget what the piece is called exactly but if you go to home depot or lowes or where ever and give them the type style and brand of your faucet and tell them what it's doing they will set you up with the new part. it's sort of a core type piece with rubber o-rings on it
Jul 13, 2012 | Delta Faucet Delta 172-SSWF Waterfall...
Single handle shower/bath faucet is dripping. Want
I can fix this.
What is the last thing you did before this problem started?
Jan 13, 2011 | Delta Faucet Delta 172-SSWF Waterfall...
I have replaced the cartridge on my single faucet single handle moen kitchen tap, but water still leaks out under the central area that holds the cartridge. Is there a schematic that shows where and what...
did you replace the spout, -o- ring's. they would cause a leak to show up there as well.no need to pull cartridge again,just handle,and then pull up spout and that is it. there should be a small packet of lube w/ -o- ring kit,lube up around shaft and new -o- ring's.available at any good hrd ware store
Apr 19, 2010 | Moen 7310 Legend Single-Handle Kitchen...
I have a Moen Single Handle kitchen faucet, it's leaking at the base and below the neck (where is swivels for the faucet to move side to side). How do I fix it?
Replace the "O" rings that are behind the spout portion. You will have to remove the top of the faucet and pull up on the spout section. There will be a couple of "O" rings there. It is best to have Moen send the parts to you as locating the proper size "O" rings can be difficult.
Mar 29, 2010 | Moen 7840 Camerist Single-Handle Kitchen...
I have a single handed Kohler Vinnata kitchen faucet that is leaking from the handle. Cartridge has been replaced and hasn't stopped leak. What now?
turn off water remove handle and check retaining nut remove cartridge and check o-rings for damage or replace replace and tighten cartridge check for leak
Nov 04, 2009 | Moen 7437 Chateau Single Hole Kitchen...
Push button on sprayer cracked. Where can I purchase a sprayer only?
yes you can,just make sure you take it with you. Not all replacements will fit.you must have the same connector end. they come in a clip style and a screw type. make sure you know what it is you have,one or other before you purchase.
Jul 13, 2009 | Whitehaus Kitchen Single Handle Faucet...
Adjusting single leaver faucet handle
The little wrench tightens the tension ring that fits on the inside of the retaining nut right under the handle. You fit the little "arms" in the notches.
Apr 06, 2009 | Delta Model 172: Waterfall Single Handle...
Hot and cold water trickles from faucet--seems nearly clogged.
The debre from turning off the valves comes through the lines and clogs up,usually the aireator,the screen at the end of the faucet. Take aireator off ,,colena and reassemble. If that does not work,disconnect the  lines at the shurtoff agaoun and look for hte obstructions for the aireator back to the shurtoffs.
Apr 06, 2009 | Whitehaus Kitchen Single Handle Faucet...
Whitehaus Kitchen Single Handle Faucet with Spray .... Logo
Top Whitehaus Plumbing Experts
Paul Carew
Tom Chichester
Are you a Whitehaus Plumbing Expert? Answer questions, earn points and help others
