Question about Sharp LC52SB55U LCD TV
Sound stopped working on analog channels only
All our analog channels lost their sound. Video is fine. Digital channels are still okay. TV is a few weeks old and all was okay up until now.
  • xxtaylor79xx Feb 10, 2009
    ok I have a Sylvania dvd/vhs combo tv (6724FDF) and i have the same problem I can't get the darn SAP off and not most of my channels aren't working what can i do...I don't have the remote
  • 108 Answers
Make sure the SAP feature is turn off in the TV.
Posted on Jan 11, 2009
Sharp TV model LC-20AV1U - I need to reset it so I can get it to recognize my over air antenna after cutting cable TV
Hi Loretta,
The reason you aren't getting any channels to work on this TV is because it has an analog tuner. Now a days most channels are being broadcast in digital format and the TV needs to have a digital tuner.
In order to get the antenna to work on this TV, you will need to have an OTA converter that will receive the digital channels and send the signal in analog format to your LC_20AV1U.
Let me know if you require further assistance..
Feb 23, 2017 | Sharp Televison & Video
No TV broadcast picture. Is this a tuner problem?
yes it does seem to be a tuner problem , I also wonder what happens when you use the auto channel finder and tuner usually found in the set up section of the menu ? As well as was your TV working before and receiving input via the antennae but has now stopped working in this regard ? I also noted that attaching an analog to digital converter box worked fine , so your TV is capable of receiving a signal via that method , dose the converter box use your antennae input jack or a video jack to send the converted signal into your TV ? if it is using your antennae jack then it may not be a tuner problem .
Jul 19, 2014 | Sony Grand Wega Kdf-50we655 50-inch Lcd...
No digital channels after running auto search
Same thing with my vizio vx37l tv. Did you fix the problem bpakja? If so please let me know how.
Sep 30, 2009 | Vizio VX37L Television
Digital Visio 42" LCD TV stopped receiving digital TV
Check all your connections in the back, if they're all good replace the main board in the tv.
Aug 22, 2009 | Televison & Video
Connecting a toshiba sd-v392 to an old analog tv
Make sure your menu settings are correct audio outputs may have a setting for digital or analog sound output check that these are set up to analog or stereo output .Also try hooking the sound up direct to a stereo system or amp to be sure you have output! Also you may not be able to get your sound thru the convertor box!! Because the convertor is a reciever of digital signals not a line amp. for audio !! Hope this helps11 AAAAAAAAAAAAAE!!!! Swampratt200 ! Out!!
Jul 21, 2009 | Toshiba SD-V392 DVD Player/VCR
DVD Player Only Produces Snow After Power Outage. Halp!
Sounds like your TV has lost the DVD channel. Turn off TV and make sure the DVD player is connected to TV and is playing a DVD. Now put you TV on and press the SOURCE or AV button on your TV remote until you can see the DVD channel. In older TVs you may need select channel and tune it manually using the TV setup.
Jul 10, 2009 | Insignia Digital-to-Analog Converter for...
Digital - Weak or no signal digital coax when hdmi dvd player on
if u have placed your DVD next to your tv ... just maintain distance between then and check out
Apr 01, 2009 | Samsung LE40R74BDX 40 in. LCD Television
No sound when watching freeview on Samsung 32" LCD TV
I`ve got the same problem, sound with analog but not digital?
Dec 12, 2007 | Televison & Video
Sharp LC52SB55U LCD TV Logo
147 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
