Question about Poulan P3416 16Inch 34cc 2Cycle Gas Powered Chain Saw
Replaced all fuel lines and pickup fuel filter. but won't stay running without choke.
  • 21 Answers
Take the carburetor off and clean it and check and replace any air filters you may have. Can't say that this will fix it ,but it is a starting point for you. Hope it works and good luck.
Posted on Dec 01, 2012
My chainsaw won't run without full choke on and
Fuel starvation, start by replacing the fuel filter in the tank, check the fuel hoses for leaks up to the carb.
May 22, 2013 | Garden
New filter new fuel pump won't stay running
Well your engine has a carb, so it could be dirt in the carb, or a vac leak, or several other possible causes.
Does the choke close when the engine is first started ? Have you checked the fuel line to see if the pump is providing gas ?
Apr 25, 2013 | 1987 Dodge Raider
2001 Shadow Sabre, Won't idle with choke off unless giving it some throttle.
Hi, Rickgilbreat and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Vacuum line from the petcock to intake manifold cracked.
5. Float needle and seat sticking.
6. Float level too low.
7. Carburetor bowl vent line clogged/blocked/pinched.
8. Idle adjusting screw set too low.
9. Air/fuel mixture screw set too lean.
10. Idle port, transfer ports, slow air jet clogged.
11. Slow fuel jet clogged.
12. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on the blue links below. Good luck and have a wonderful day.
Starts but won stay running unless with choke Discussion
Won idle without choke
Honda shadow vt1100 Owners Workshop Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda VT1100C2 Owner Manual Page 3
Aug 23, 2012 | 2001 Honda VT 1100 C2 Shadow Sabre
Crafsman 25cc weedwacker won't stay running
You probably have a bad hose or a bad hose connection that is sucking mostly air instead of delivering full fuel to the carburetor!
Apr 19, 2017 | Craftsman 25cc Gas Line Trimmer
'07 klr 650 won't run without choke on
Hi, Lance and the usual suspects are:
Won run without choke
KLR won idle without choke backfires on decel
Kawasaki KLR650 Service Manual
OEM Parts for Kawasaki
Kawasaki KLR650 Owner Manual
Jul 01, 2017 | 2007 kawasaki KLR 650
Yamaha royal star xvz 1300 won't idle without choke
Hi, Anonymous and the usual suspects are:
4. Float needle and seat sticking.
5. Float level too low.
6. Carburetor bowl vent line clogged/blocked/pinched.
7. Idle adjusting screw set too low.
8. Air/fuel mixture screw set too lean.
9. Idle port, transfer ports, slow air jet clogged.
10. Slow fuel jet clogged.
11. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on the links below. Good luck and have a nice day.
2003 Star 1100 Custom won idle without choke aftermarket exhaust
Oakys Garage Carb clean Pilot Jet clogged Won run without Choke Carbs 101
https://www.tradebit.com/filedetail.php/243740175-1996-2001-yamaha-royal-star-xvz13a-service-manual
http://www.starmotorcycles.com/assets/service/manuals/1998/Lit-11626-11-17_320.pdf
OEM parts for Yamaha
Jan 01, 2012 | 1996 Yamaha Royal Star XVZ 1300 A
Engine surges won't run with out choke and then it stalls
If the engine surges and won't run without choke it is starving for fuel. Best place to start is the fuel filter. After the fuel filter, pull the fuel line off of the carburetor and place a container under the fuel line to catch the fuel. Crank the engine over and watch for the amount of fuel being pumped through the line. There should be a good stream of fuel with each pulse from the pump. Chances are the pump diaphragm is getting weak and it cannot keep enough fuel in the carb to run proper. Check those items and let me know if it helps, Daniel.
Sep 29, 2011 | John Deere 24HP VTwin Hydrostatic 48"...
2002 honda shadow spirit won't idle without choke on and misfires and backfires run awful. plugs have oil residue on all 4.
Hi, Tjenkins2017 and the usual suspects are:
Need Help Bike won run choke in
Oct 25, 2010 | 2002 Honda VT 1100 C Shadow Spirit
1992 Honda CB 750 Nighthawk will not idle without choke
Hi, Emeraldcp and the usual suspects are:
13. Faulty auto choke or wiring connection.
For more information about your issue and valuable "Free" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Bike won Run without Choke
Honda Nighthawk CB 750 1991 Service Manual
https://www.partsfish.com/page/oem-parts-for-honda
Honda CB750F2 Owner Manual
Sep 26, 2010 | 1992 Honda CB 750 Nighthawk
Poulan P3416 16Inch 34cc 2Cycle Gas Powered Chain Saw Logo
312 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
