Question about Brother HL-2170W Laser Printer
How do I change the fonts in my brother hl2270dw
For some reason my hlbrother2270dw printer has started printing in large print format how can I change the fonts
  • 624 Answers
SOURCE: brother Hl-2040 laser printer
Fonts and sizes are typically controlled by the application you are using. Are you sure you are increasing the font size? I've had some users confused by the zoom feature which is more like a magnifying lens. It just makes thing larger for viewing purposes and does not affect the print size. To change the actual font size of a document already created you would first highlight the text in the document. In Word (other applications are similar) you would then select Format from the main menu bar, then select Font. In the next box that appears you would click on the Font tab, and then in the Size field select a larger font size. After that click on OK and you should see your font size change. Let us know if that was your problem or not.
Posted on Aug 02, 2007
SOURCE: can't change the font style & size on my Brother PT-65 Label make
In case you've forgotten how to change the text size, hold down 'Code' and '& Size' key to display the current setting. While still holding the Code button, push and release the '&' key to change the size.
To reset, I would try removing the batteries for a few minutes before reinstalling them.
Just two guesses.
Posted on Jan 07, 2009
SOURCE: my brother DCP 150C is not printing colours properly blue is noth
My Brother MFC665CW is not printing properly black ink
Posted on Apr 08, 2009
  • 55 Answers
SOURCE: Brother MFC-490CW Won't Print
If you have installed something since yesterday you might want to use system restore. the program might be causing the flaw. If not dont worry. You will need to uninstall the printer from your printer page and reinstall it. depending if it is a networked printer or a usb connected. If networked all you have to do is follow the install wizard. but if it is a usb you will have to go to the company's website and download a printer driver. after that it should work. dont forget to restart your computer. sometimes that can help too.
Posted on Jun 30, 2009
  • 7993 Answers
SOURCE: Brother MFC-210C USB Printer is not printing Troubleshooting
You try to solve that problem by following the instruction the machine gave you. Here is the link to the manual.
http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&c=us&lang=en&prod=mfc210c_all&type2=5&flang=English&dlid=
Hope it helps.
Posted on Aug 30, 2009
Our printer doesn't want to print double t or f together (tt, ff, ti). What is the cause of this and how do we fix it?
This will probably be a Font or Driver issue. Most likely a font. Try a different font such as Times New Roman or Arial just to make sure. If it prints fine then change your default font on whatever document you are printing. If it still does not do this on these two fonts then it may be driver related. Update your driver with the latest one from Brother to see if that cures the problem.
Oct 10, 2014 | Brother HL-6050DN Laser Printer
Adjusting Font Size
You can't increase the font size with your printer. It does not have that option. You need to increase the size from source of which you are getting the data from before you print
Example: if you wanted to print a word document, you would go to the taskbar on the top and change the font settings prior to printing.
Or do this
Open up the what you want to print
Left click and highlight either part or the whole area you want printed
Right click the highlighted area and click print preview
Change the box "As laid out on screen" to "As selected on screen" doing this will let you print all or part depending on what is highlighted
In the box Shrink to fit, change it to increase or reduce the size font that you want to use
Click print, and go to Page Range, and make sure you add a dot to SELECT
Click print
Hope It's resolve all Your Printer Problem,
Or
Still having Problem Then follow Us ForBrother Printer Support
Feb 14, 2014 | Brother Office Equipment & Supplies
False 'Cannot Print' Warning on Brother HL2270 DW
Hi, as one comment mentioned, you should try configuring the sleep timer, I had the same problem and that did the trick. Those Brother printers can be painful to deal with sometimes :) Btw, if you need the service manual, you can find one here - Brother HL-2270DW manual
Jan 25, 2013 | Brother HL2270DW HL-2270DW Compact...
I just changed the tape and the printer is printing small font
okay when you first start the machine up it tells you what sizes its going to print in you can change that by using F=1 orF+2 font type and font size hope this helps
Feb 03, 2010 | Brother PT-1000 Thermal Label Printer
How can i get this printer to print larger letters
Usually, the size of the letters depend on how large you have them in your document. Open your document, highlight the letters you wish to change (or the entire document if you want to change everything) and from the menu bar at the top of the screen, (Usually under "Format") you will find a "Font" selection. Increase the size of the font by selecting a larger number. This will change it on your screen as well as when the printer prints it. You may have to save the changes before printing.
May 14, 2009 | Lexmark C533DN InkJet Printer
Can't change the font style & size on my Brother PT-65 Label make
Just two guesses.
Jan 04, 2009 | Brother BRTPT65 PT-65 Label Maker Printer
Font size-printing
Hello Christina,
There are two sections to look into. 1) Device Settings. 2) Printing Preferences.
Between the two, I confident that you can find the solutions.
Aug 06, 2008 | Brother MultiFunction Center MFC-440CN...
Installing or sending a font to Brother printer
you need to use a PS or post script driver in order to print this file.
the reason why you are getting a courrier font is that that driver is not supported by PS
download the latest PS driver of your particular model this should work perfectly
Mar 27, 2008 | Brother MFC-8460N All-In-One Printer
Print out is too small
To resolve this, try the following actions:
* Check the default fonts within Microsoft Windows.
* Select your entire document and set it to a larger font.
* Make sure all your fonts are loaded properly.
* Change the resolution to quick print at 600 dpi. To do so:
1. Click Start, Settings, Printers.
2. Right click the Lexmark printer icon and choose Properties.
3. Choose the Document/Quality tab and set the resolution to 600 dpi quick print/draft.
* Change the Spool Data Format to RAW. To do this:
3. Select the Details tab and click Spool Settings.
4. In the Spool Settings screen, set the Spool Data Format to RAW.
5. Click OK and then Apply.
Nov 19, 2007 | Lexmark X2350 All-In-One InkJet Printer
Brother Hl-2040 laser printer
Aug 02, 2007 | Brother HL-2040 Laser Printer
Brother HL-2170W Laser Printer Logo
98 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
