Question about Acu-Rite Measuring Tools & Sensors
Acu-rite model-00754w2-rx outside temp does not read
  • 17 Answers
SOURCE: my acu-rite wireless thermometer model #00604RX
Double check the batteries and the direction in which they are installed. If there is one backwards in the sending unit that is outside, it will not send a signal. Also, there is typically one battery in the indoor unit that is responsible for receiving the signal from the outdoor unit. If all of the batteries are in correctly except that battery, you will see the display, but will not get the data transmitted from the outside sending unit.
Posted on Oct 21, 2010
SOURCE: My acu-rite keeps beeping even after a battery
I cut the wire that leads to the annoying noisemaker. Carefully remove the rear cover to expose the circuit board (the rear cover is connected to the circuit board so pull them apart carefully). Locate the noisemaker, mine was round and connected to the back cover with black and red wires. Cut the black and red wires and replace the rear cover. NOTE: If you use the alarm feature, it won't work anymore. I read on the Acurite site that the reason it beeps is because of interference with the wireless signal. They suggest not using one of your wireless devices. If you are like me, that isn't a good option.
Posted on Dec 01, 2010
SOURCE: I need instructions for my Model 00972 Acu-Rite
flashes continuously the time and the outside timp
Posted on Jan 09, 2011
SOURCE: I need a manual for
Here you go. May not stay up forever. http://www.weatherconnection.com/manuals/00592W.pdf
Posted on Feb 03, 2011
SOURCE: How do I reset the time on my acu-rite model #
Hold the Time button until the hour blinks. When it does, use + or - to adjust. When correct, press Time again. This will cause the minute to blink - use the same buttons to adjust. When finished, press Time again.
Posted on Nov 04, 2011
Model 00822A2. Why doesn't inside unit show outside temperature?
If you tried removing and replacing batteries, you should bear in mind that all batteries should be removed to "reset" the station then batteries should be installed in the outside sender first and time allowed for it to begin transmitting temperature. Next, batteries should be installed in the receiver and you should begin to read outside temperature.
Nov 24, 2015 | Acu-Rite Measuring Tools & Sensors
I have an Acurite 822-RX thermometer that shows HH as the outdoor temp, even after replacing the batteries in both the base and remote units. How can it be fixed or reset?
HH means it is showing the high temperature you (most likely accidentally) set with the MAX MIN / + button, which is easy to do when setting the clock. Just press that button again until the reading appears.
Jan 15, 2011 | Acu-Rite Acurite Wireless Weather...
I put new batteries into both units, the indoor unit and outdoor unit, now it is not able to read the outdoor temperature. What needs to be done?
I'm having the same problem and can't find an answer. Seems this also happened with another model we had - planned obsolescence? It was working fine, flashing due to low battery. Now, nothing from outside. Annoying.
Oct 16, 2010 | Acu-Rite AcuRite IndoorOutdoor Wireless...
Acurite 1097-rx will not display outside temp or humidity. new batteries. Inside functions normal.
I had same problem. Take all batteries out of both units. Put the batteries in the remote sensor FIRST. Then put batteries in the main unit. Within five minutes, they will link up. Problem solved!
Feb 23, 2010 | Acu-Rite Audio Players & Recorders
Our new model #00592W1 includes a low temperature adaptor that plugs into the wireless sensor. Is it necessary to use this?
I found this on another Acu-Rite manual: In case temperatures fall below -4F, bring the wireless sensor indoors and use the included low temperature adaptor by routing the wire out through a soft seal opening such as a window or door. (That way the Wireless sensor is protected indoors in extreme temperatures. Low temp adaptor is used outside to observe temperature.)
Dec 12, 2009 | Acu-Rite Audio Players & Recorders
How to set the time on Acu-Rite model 13100 clock?
How do reset time on model 13003 ?? It reads 12:15 and the Time is 11:27 Clark page plaza@cox.net
Mar 08, 2009 | Acu-Rite Magnum-80181 Clock Radio
Measuring Tools & Sensors Logo
209 people viewed this question
Top Acu-Rite Measuring Tools & Sensors Experts
windryder
Level 1 Expert
Kazim ERGUNEY
Kazim ERGUNEY
Are you an Acu-Rite Measuring Tool and Sensor Expert? Answer questions, earn points and help others
