Question about NetGear WGR614 Wireless Router
How do I change frequency on router - NetGear WGR614 Wireless Router
    Sergeant:
  • 236 Answers
This router is only capable of using the 2.4 Ghz range. If you are experiencing interference on your wireless network you may want to try to change the wireless channel. If you have other devices in the location that uses the 2.4 Ghz range you may want to research to see if they also have the option to change to another channel as well.
Posted on Dec 17, 2012
We are unable to use a baby monitor and WIFI at the same time, how can we change the frequency
Unfortunately in electronics frequencies often interfere. As for a solution, check inside the baby moniter usually in battery compartment for a switch. Another solution is to change the routers settings from 802.11n to 802.11b/g this will however reduce speed. Hope this helps
Oct 20, 2012 | 3Com OfficeConnect Wireless Router
My phone is interferring with my wireless internet
Wireless G operates at 2.4Ghz. Your wireless phone most likely uses this same 2.4Ghz frequency. If your phone has the option to change the frequency - then I would do that to see if it helps. If your phone will not let you change frequency, then you may need to purchase a new phone that doesn't operate in the 2.4Ghz range.
Nov 14, 2011 | Trendware TRENDnet TEW-432BRP 54Mbps...
Getting disconnected
Need more INFO... getting disconnected from what ??? the LAN (Local Aria Network) or the WAN (Wide Aria Network) ???, in other words do you loose network connectivity or internet connectivity ???, is it trough wired or wireless connection ???, if it's wired LAN connectivity, check/change the cable from the router to the computer, if it's wired WAN connectivity, check/change the cable from the router to the ISP's modem, if it's trough wireless check for RFI (Radio Frequency Interference) or EMI (electromagnetic interference) move the unit away from any electrical device or radio transmitters, change the frequency of the unit to an other frequency than the default one, etc...
Feb 09, 2011 | Computers & Internet
How do I change the frequency of my router
Here are the steps to change frequency:
1. Open a web browser and type the IP address of the router into the navigation bar. For most routers, the IP address is 192.168.1.1.
2. Enter your username and password into the prompt. This is the administration password to access the router's console.
3. Click the "Wireless" tab. Select "Basic Wireless Settings." This opens a window with a "Channel" section. This section is where frequency settings are changed.
4. Select channel 1, 6 or 11. These channels provide the clearest signal since they do not overlap other channels. Click the "Save" button and close the browser window.
5. Reboot the wireless computers. A change in frequency drops wireless devices from the network. The computers need to be rebooted to find new network settings.
Nov 08, 2010 | Computers & Internet
Can I change channel/frequency to get a stronger signal between the PC and the Belkin54g router? If so, how?
Hi i go your issue .......
You can change the channel and the frequency to get a better signal range ......
To promote this please follow the following steps
Step 1: Connected modem>>router>>computer
Step 2: Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3: Towards the left corner click channel and ssid under wireless
Step 4: on the left under wireless click channel and SSID
Step 5 :Change the Wireless channel to 6 and also you can change the frequency there
Step 6 : Change the SSID to a different name ( no Spaces )
Step 7 : Click apply changes
Step 8 : Now Scan and connect to this network ( Wireless )
If problem still presists please contact 24/7 belkin technical support 1800-2235546
Thanks with regards priya
Oct 06, 2010 | Belkin (F5D7230-4) Router (587009)
Everytime the phone rings my wireless connection goes away. I am also unable to secure this network. the model number is f5d8235 4
Your phone is using the same frequency as the wireless router (2.4GHz). It would be very difficult to prevent this unless you change:
1. Phone to corded system.
2. Change phone to cordless DECT (5.8GHz) system
3. Change network router from "G" series to "N" series.
Sep 25, 2009 | Computers & Internet
How do i change my channel frequency on my trendnet router
Go to http://192.168.1.1/ click the Wireless tab, change the channel and you are done. But I doubt it will make a big difference. Unless you have an a/b/g router you are pretty much stuck to the same frequency band...
Aug 29, 2009 | Trendnet TEW-633GR Wireless Router
How do i change the channel frequency on my router
or go through the link to download the manual for it.
www.trendnet.com/download_manager/default.asp?iFile=11379
Aug 29, 2009 | Trendware TRENDnet TEW-432BRP 54Mbps...
Lose internet connection when phone is in use
Your cordless and wireless mode is running on same frequency.
You can do couple of things...use the wireless mode in b instead of g in the router.
Else use a different cordless phone which runs in 5.8 or 6.0 frequency.
Hope this helps.
-Pankaj
Mar 26, 2009 | Belkin (54G F5D7230UK4) Wireless Router
Actiontec Frequency
You can change the wireless frequency of the router, default is 9, check page 55 of your owner's manual (which is on your installation CD) Are you using the telephone portion of the router? There are NO settings in your wireless router or any consumer router to prevent what you are experiencing. BUT... Approximately 3 ticks a second equates to an 180hz signal. 180hz is a multiple of 60hz which is your powerline frequency. I'm suggesting that it is a noisy power feedback problem, since likely both the wireless router power transformer and the stereo power are on the same circuit. Touching the antenna changes the circuit output impedance which affects the signal. Your solution lies in one of the below, your choice: 1) Buy different speakers 2) Plug router into a different power outlet as far away from the stereo outlet as possible 3) Simply stretch the router as far away from the speakers as possible and live with the faint background ticking. 4) Buy a different router. ZT3000 "Beta tester of "0"s and "1's"
Aug 19, 2007 | Actiontec (GT704WG) Router
NetGear WGR614 Wireless Router Logo
76 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
