Question about Casio Watches
Casio pro trek model 2894 display says "recov"
  • 5 Answers
SOURCE: Casio pro-trek PRG-60T Buttons no longer activate anything.
Is the battery indicator on L (Low). If so only timekeeping will work. Check out the manual which tells you that.
Try sticking the watch in a window to charge it till the battery indicator gets to H (may take up to 10 days for a very run down battery). If that doesn't work it send it to Casio for a battery change. Cost of change just over 20GBP sterling.
Posted on Feb 19, 2009
escapement
  • 2334 Answers
SOURCE: reset casio pro trek prg 80l after discharge of
You can find details here: http://world.casio.com/wat/download/en/manual/
Rate me, plz.
Posted on Jan 10, 2010
SOURCE: casio PRO TREK error 'OP EN'
The problems is very simple: On the back cover (inside) is a little Cu metal Part. This part is glued to back cover using a poor glue (rubbered glue) and, in time, is moving from original position. You must put back this parts to original positin ( a little hole inside of back cover) and glue using a good glue. When the back cover is mounted , this part must have a ferm contact with two springs from mechanism (sensor for back cover open). If beatwin this springs isn't a electric short (using Cu metal parts) the internal mechanism of watch "see" the back cover is open and show "OPEN" on screen!
Posted on Apr 02, 2010
Testimonial: "Simple .... once you know ! (as most things) The "obvious" question is: How did you figure it out ? But THANKS !!"
  • 10 Answers
SOURCE: Casio pro trek prg-80T model 2894 display says "open"
May need a battery replacement. My solar atomic watch battery died after 3 months. Casio said the battery was not covered by the warranty. Check this YouTube video for the battery replacement process:
http://www.youtube.com/watch?v=ogCz2vjUKVg
Posted on Jul 14, 2010
kerguney
  • 577 Answers
SOURCE: Change time on a pro trek casio
you need to look at the user manual that
you can download a soft version of the user manual on below link. .when you open the link just write the 4 digits code on the back side and click searched on the URL below
Hope this helps! Take care and please Remember to rate/vote and
give me 4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
CASIO Watch User Manual Archives
Use this page to download a copy of CASIO watch manuals in PDF format.
To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
Posted on Oct 09, 2011
Pro trek 3500 compass only going up 300 degrees. Doesn't reach 360 north???
THe PRO-TREK watch compass is very sensitive to nearby Iron (eg. cars, fridges, steamships, artillary canons, battering rams, guillotines, etc) and anything wearable or embedded in your body. I had to calibrate mine in the middle of a baseball field.
Aug 09, 2017 | Casio Digital Compass Twin Sensor Sport...
How can i get water out between 2 glasses on casio pro trek 2894
Hi Dirk
Bad one having water inside your Protrek or any watch for that matter-mechanical or electronic.
It means one of your seals has failed most likely the back one.
Look carefully at the back seal, if you squeeze the back plate, and the main case between your thumb and index finger you may notice a slight movement (use x10 magnification) That microscopic gap is enough to flood your watch and the deeper you use it the bigger the flood. The problem is the case, it is made of cheap nasty plastic and over time it deforms and the rubber seal contracts. Any slight over tightening of the screws, pulls the plastic thread out and stops the back plate making a good seal between the back plate and the rubber seal in the groove of the main case. For the price one would be excused for expecting that these Casio watches had a better quality case, even better a screw on back plate (like a proper 100m depth watch) rather than the individual 4 screws at each corner and a prayer. There are ways of fixing the screw threads but it never lasts....
To get the moisture out, just remove the backplate and discard the batteries. The sooner this is done the better the chances of success. Leave the watch open, face down in a warm place, preferably loosely covered by a glass bowl to stop dirt getting inside. After few hours check if the water is gone. If on inspection of all the contacts they do not exhibit any rust or white chalky deposits. Replace the new batteries and reset the watch by shortening the reset pins. If all seems ok and you have a proper display and all funtions works. You may purchase a new seal from Casio or simply clean the existing one with a little blu-tak to remove the dirt and run A LITTLE!! bead of vaseline along the rubber top to aid the seal.
I will not use the watch under water anymore and chances are that it will be downhill for the watch from now on, sorry.
I hope this helps
Jan 25, 2017 | Casio Watches
My casio pro trek 2894 is frozen it shows op en ontop and when i press the setting button it resets time to 12h00
Hi
Have you checked that all buttons when pressed come in and out easily?
Sometimes the little spindles that press the contacts inside the watch do not come out completely and remain "pressed" even if the button appears to be "out"
Clean the watch, with particular attention to the buttons area so they can move easily in and out. If this does not do the trick, open the watch with great care not to damage the threads on the plastic case and visiually inspect if the buttons travel easily in and out and that all springs if fitted are sound. Remove and replace the batteries with new ones (DO NOT use bargain batteries from that "auction site")
and reset the watch.Try again, if ok carefully clean the back seal apply a little vaseline to the top of the seal and close the case. DO NOT over tighten the screws as this will damage the plastic thread and the watch will not seal properly and will be likely to flood with moisture. Good luck
How do I set the alarm on a men's Casio Pro Trek digital atomic watch pq635?
Get in touch with Casio support: http://www.casio.com/support
May 08, 2015 | Casio Watches
Casio PRO TREK error 'OP EN' Display frozen with the above msg. None of the buttons - except the light - works. Whats wrong .. battery charge shows FULL
Mar 22, 2010 | Casio Watches
I have a casio watch what has a moon and tide phase graoh but no instructions
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CASIO watch manuals. Rate me, please
Mar 08, 2010 | Casio Pro Trek Tide Moon Graph Titanium...
Send it into repairs and they will send you an estimate on what it would cost to fix it. Give them a call at 800-706-2534 option 2.
Feb 19, 2008 | Casio Triple Sensor Pathfinder PRG60-1AV...
Watches Logo
171 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Jimmy Accardi
Are you a Casio Watch Expert? Answer questions, earn points and help others
