Question about Neff B1641 Single circotherm super Stainless Steel Electric Oven
The oven is not working at all. We have checked external fuses and wiring.
We have been having trouble with main function switch.There was a loud pop,
3 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: Neff Oven
It appears that the timer has gone faulty, possibly because of a short in the bulb holder, which probably explains why there is no display and the main oven not working. the top will still work as it is not controlled by the timer.
the solution hear would to be fit a new timer.
Posted on Nov 26, 2008
barkencoa
  • 3463 Answers
SOURCE: switch oven on within 3 mintues the fuses blow main fuse box
I suspect the fan oven element has failed, this is located at the rear of the inner oven compartment behind a removeable cover
It is probably breaking down as the element gets hotter.
Posted on Feb 28, 2010
Oven not working front lights for main switch and thermostat and internal light not coming on oven wont heat only fan is coming on oven 1 year and a few months old
Check if a overtemp fuse has beem avtivated. You will need a multimeter. Check for burned wires on function switch and thermostat. And check functionswitch for burn marks. Function switch = main switch
Feb 13, 2016 | Ovens
Beko built in double oven alarm after power outage
Switch oven on using the function knob (first knob on left hand side)then press and hold(for 3 to 5 seconds) the left top button right next to the display screen this should give you a chance to set the current time on the oven after setting the current time switch oven off at function knob and on agian problem should be solved
Jul 05, 2015 | Ovens
What happened- i was using the stovetop and the oven and i heard a loud pop?
Good Morning Friend,
I understand you were using the stovetop and oven on your Electrolux range. You heard a loud pop, and are wondering what happened. I suggest contacting your local authorized dealer for further assistance. They have been trained on your appliance and should be able diagnose your appliance and determine what cause that loud pop.
-Best Regards-
WP
Jul 06, 2014 | Electrolux Ovens
The oven made a loud pop sound as it was running and shut down all functions. Power supply breaker did not trip and power cord does not show short to ground.
By "all functions" I am assuming you mean that nothing works on top or in the oven. If there is no life at all I would begin by removing the back cover (after unplugging it) and doing a visual check to see if a wire has burnt or become disconnected. Look for any signs of black burn marks near or around electrical connections. If the top of the stove works but not the oven I would test both upper and lower elements for continuity.
Aug 09, 2011 | Ovens
I had the oven on and I heard a loud popping noise, now the stove doesn't work (eg. the letter Fy1 comes up , the stove makes beeping noises, the stove door locks and unlocks etc.) The model # is...
rwere
Hello, and sorry to read about your problem.
Sounds like you have a general main board failure,
I suggest you call a service company
I tried to help you. Please help me and vote/rate my response thanks.
Dec 24, 2010 | Frigidaire Ovens
Frigidaire gallery stove, oven not working,
Morison,
The same thing happened to me about a week ago. I was preheating our electric oven, heard a very loud bang/pop. Checked and the oven had PF (power failure) I went downstairs and the breaker was tripped. Came back upstairs and to look at stove, the burners are working fine so I continued to preheat oven after a half an hour the oven was only slightly warm. Did you ever find out what was wrong?
May 04, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Electric Dbl Wall Oven-loud popping noise at end of self clean
Bill ,i dont suspect the control unit is the problem im going back to the loud pop you heard I would say the pop you heard was one of the elemants blowing and that the reason the the breaker tripped if you say the clock,timer and light functon are ok it more so points to an elemant in most cases when an elemant blows it breaks the circuit .but the other componants also work when you reset the breaker i think in this case bill i would call a electrician it needs testing,sorry i could not help this time bill,but do not hesatate to contact me if i can help you again.adrian
Feb 02, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Smeg oven problem
The pop would usually mean a busted fuse. Turn off the oven, disconnect completely from the power supply and then take it apart. See if you can find any toasted fuse or roasted wires. Also the reason for tripping the mains off is due to the fact that the oven is draining more power than it should. I would recommend a thorough inspection of the oven by an electrician..
Jun 18, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Neff B1641 Single circotherm super Stainless Steel Electric Oven Logo
19 people viewed this question
Top Neff Ovens Experts
ashburton
Hjalmer Lamminen
Hjalmer Lamminen
Samyfam
Samyfam
Are you a Neff Oven Expert? Answer questions, earn points and help others
