Question about Gateway MX7120 Notebook
Restore Disk I need a restore disk for the MX7120. Can someone help me.
    New Friend:
  • 3 Answers
@Milind: NOT the correct answer! I am looking as well and this site is bogus.
Posted on Jan 29, 2013
    Guru:
  • 829 Answers
Hi Download from the below link .
http://drivers.softpedia.com/get/NETWORK-CARD/OTHER-NETWORK-CARDS/Gateway-Broadcom-Network-Driver-3100641.shtml
Posted on Jan 11, 2009
How to repair a satellite toshiba p205-s7806 disk error
Toshiba won't sell you a Factory disk? ODD? If it's a HDD failure or a hardware failure, a Restore/Recovery will not help. If you have Restore turned on, restore to a date before this issue. If you have a Factory Recovery Partition, you can do a System Recovery, keep in mind ALL your data will be lost. You can find a Restore/Recovery procedure here: http://www.ehow.com/how_8012461_toshiba-p205-recovery.html
Apr 19, 2013 | Computers & Internet
Will not start
A brand name and model with operating system would be nice so someone could be precise. ?
Restoring your laptop to factory settings can take up to an hour to perform, depending upon the type of laptop and operating system on your machine. Prior to performing a system recovery, you should remove any external peripherals, such as ExpressCards, PC Cards, and USB-connected printers and hard drives. Turn on the laptop. Press the "F8" key until the "Advanced Boot Options" screen appears. Select "Repair Your Computer" using the arrow keys. Press the "Enter" key. Choose your "Language," then "Next." Login with an administrator-level username and password. Click "OK. Select "Dell Factory Image Restore," then "Next." Tick the check box next to "Yes, reformat hard drive and restore system software to factory condition." Click "Next." Click on "Finish" after the computer has concluded the factory restoration. b> Restore on an HP b> Insert the HP recovery disk. Restart the computer, and press the "F11" key. Press the "F" key to "reinstall factory settings." If your computer's operating system is damaged, you may only see "perform a full system recovery" as an option. In this case, press "R." Insert any disks if prompted by the restoration program. Otherwise, permit the computer to restart as needed. b> Restore Via Disks (Generic) b> Insert the "Recovery Disk" or "System Recovery Disk." If you have more than one disk, make sure you insert "Disk 1" or "Part 1." Press any key to boot from CD if prompted to do so. Choose a "Full System Restore," "Restore Factory Settings," or another option worded similarly. Confirm that you want to perform the restoration. Press "Next," "Yes," or "OK," as needed. Press "Finish" or "Restart" when prompted by the computer. Hope this helps.
Dec 10, 2012 | Computers & Internet
How to restore original windows on a toshiba satellite a105-s4184
I have toshiba laptop satalite with 2 operation windows 2000 and HP windows running thus slowing the system down consiradably. Idealy would like to delete the windows 2000 professinal. Please help
Sep 26, 2011 | Computers & Internet
Restoration problem
How often are restore points created?
Restore points are created automatically every day, and just before significant system events, such as the installation of a program or device driver. You can also create a restore point manually.
How much hard disk space does System Restore require?
To store restore points, you need at least 300 megabytes (MB) of free space on each hard disk that has System Protection turned on. System Restore might use up to 15 percent of the space on each disk. As the amount of space fills up with restore points, System Restore will delete older restore points to make room for new ones.
How long are restore points saved?
Restore points are saved until the hard disk space System Restore reserves is filled up. As new restore points are created, old ones are deleted. If you turn off System Protection (the feature that creates restore points) on a disk, all restore points are deleted from that disk. When you turn System Protection back on, new restore points are created.
The restore point is a built in utility by microsoft, you can't have the option to configure the settings!!!
Jul 15, 2010 | Microsoft Windows XP Professional
I have a hp pavilion dv4000 laptop but dont have restore disk
The hard disk has died, replace it and reinstall windows using someone's else disk and your key.
Mar 28, 2010 | HP Pavilion dv4000 Notebook
Need help on getting a reboot disk?
If you mean a restore disk, you will have to contact the manufacturer and purchase the restore disk. restore disk will restore your computer back to factory settings (brand new out of the box) I do not know what a reboot disk is. I hope this helps.
Oct 27, 2009 | Dell OptiPlex GX150 PC Desktop
I want to restore my a25-3072 laptop back to factory specs.
ok first things first I believe you mean "XP tablet edition" instead of "Desktop Management Interface"
  • A Tablet edition just means laptop version of and operating system. Laptops need different operating systems, than desktops, to function correctly.
Second even if you are using a Tablet edition of XP you can't use it from another computer.
  • When ever you use a restore disk specifically designed for another computer you will get the error message you described.
  • You will need to find the original restore disk for that laptop, or you will need to find a new Tablet version of Windows XP.
Once you install a new version you should stop getting that error message. But it has to be brand new. Please rate me I want to know if I was of any help.
May 09, 2009 | Toshiba Satellite A25-S3072 Notebook
Need to help to clean my recovery H disk is coming almost full.
A hard drive is usually partitoned, one hard drive will show up as two. The recovery drive should not be messed with. Don't add files , nor delete files from that drive.
Jan 17, 2009 | E-Machines eMachines Desktop PC
Need System Restore Disk/Software
the system disk are usually on a partition on the hard drive.
if you didnt make a copy of the HARD drive or made a cd from the images on the hard drive, gateway wont help.
you could buy a cd from them
some gateway have a special boot directory to boot from
try looking for that.
Jun 18, 2008 | Computers & Internet
Factory Settings Restore for my Laptop
you can actually make a system restore disk, through the help panel. click on the start button click on help , type in system restore disk, and follow those instructions.
got backup for your E machine?
Feb 17, 2008 | Computers & Internet
Gateway MX7120 Notebook Logo
128 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
