Question about Danby DWM5500W Front Load Washer
Door handle broke off. Where can I find a replacement part?
The handle on my front loader broke off and I would like to find out where I can find a replacement part. Any suggestions?
  • Anonymous Feb 10, 2008
    mine broke as well.  the plastic handle broke at the point where the screws attach it to the machine.  The screws are still there by the handle is off.
  • Anonymous Dec 28, 2008
    Mine, too. Door has broken entirely off at the joint where the hinge connects to the machine. I tried calling their 800 number, left message but got no response.
    Sergeant:
  • 236 Answers
Try any local domestic appliance store or try the manufacturers/appliance web sites. either should be able to assist you.
Posted on Jun 07, 2007
Replace door handle
You must be talking about the door handle itself. The rod connects the door handle to the door latch. The plastic clip when snapped onto the rod will keep the rod from coming out of the hole in the door handle where it attaches. Is it the handle that is broke or the clip?
May 23, 2013 | Chrysler 300M Cars & Trucks
Broke handle off of siemens TOP WD1200 champion, the settings are all in chinese and my clothes are locked inside. help?
This is a common and easily fixed problem. The door should NOT be opened after the wash is completed. You have to wait for AT LEAST 2 minutes to try the door, do not use force. There is a built in mechanism for most front loaders to delay the door opening, so be patient.
If you have used force you have already damaged the door lock, so replace. You are lucky if the door can be opened after the lock sign goes off - otherwise you just have to change the door lock.
Click if helped.
Mar 30, 2013 | Siemens Washing Machines
Broke the door handle on malber wd 1000? Do they sell the handle or door?
Sorry to see this 16 months too late.
You can find Malber Distribution Corp online, or call them at 516-323-5299. Tell them Mike, in DC, says hi.
Oct 30, 2012 | Malber WD1000 Front Load Washer/Dryer
Driver side exterior door handle broke. just one arm broke off the handle, so its still half on but i can't open my door from the out side. can i use the back door handle to replace the front one? also...
This iis very coomon, the part of the handle that broke is the part that releases the latch, you will need to replace the handle, the inside door panel needs to be removed to replace the handle, some of these are revited on and you will need to drill out revits from the outside and disconnect the linkage from the inside, hope this is helpful.
Dec 25, 2010 | 1996 Pontiac Bonneville SE CA Value
How do I stop my Kenmore front loader from leaking around the door. I have a Kenmore HE 2plus front loader
If this is a Kenmore FRONT LOADER you need to remove the lower toe panel directly below the door to inspect the cabinet interior for the source of your leak. The following link explains:
http://www.fixya.com/support/r3576656-washer_leak__front_loader
The most common source of leaks on a front loader is the rubber door bellow. The bellow can develop cracks, rips or tears with age and needs to replaced. The following link explains how:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
If you have any questions about this repair, please let me know so that I may be able to provide you with better assistance. I hope this helps you.
Jan 31, 2010 | Kenmore HE2 Plus Front Load Washer
Maytag 1275 front loader. plastic inside part of door handle snapped. can I remove the door handle and get a replacement. liz
Hi Liz, I to have the same problem, a design fault! It was $35AU for the part, I have replaced it but the door can't close properly. Still working on it. Joan
Sep 30, 2009 | Maytag Neptune FAV6800A Top Load Washer
Pulled the handle to early to open the 7kg front loader washing machine and broke the handle. Cant open the door now and wet clothes are the washer. What can i do to fix this up?
To manually unlock the door lock system:
1. Unplug the power cord from the outlet.
2. Remove the front lower kick panel.
3. Reach up along the inside of the front panel and locate the bottom of the door latch assembly.
4. Located on the bottom of the door latch assembly is a tear-drop shaped tab.
5. Gently pull the tab down about quarter inch or until a click is heard.
6. The door may now be opened
Or pull out your dispenser tray, along the rear edge you will find a cord, pull this like above. Depends on your model.
Try these sites for spares:
RepairClinic.com espares.co.uk
AppliancePartsPros.com
mcminone.com
Apr 02, 2009 | Samsung WF337AA Front Load Washer
My washing machine works most of the time but sometimes i need to push the door really hard a few times to get the cycle to start. Today it broke down half way through cycle, got it going again then the...
Hi
Seems like the door switch is failing, or failed.
wpecially if a front loader, the door has to be closed, and register on the circuit as closed before the machine will start.
they are cheap and easy to replace, most of the time, but cant give instructions for an unknown whirlpool other than
take front panel off
replace door switch
replace front panel
Sep 21, 2008 | Whirlpool Washing Machines
Danby DWM5500W Front Load Washer Logo
201 people viewed this question
Top Danby Washing Machines Experts
shaun taylor
Samyfam
Samyfam
Mike
Are you a Danby Washing Machine Expert? Answer questions, earn points and help others
