Hi. I have a bauknecht dishwasher GSFH 1660 EX! There is no LCD-display, but a lamp who are suppose to be on when the machine are working and off when finish. But now it blinks 2 times and pauses before it blinks two times again. Does not help to pull out the plug and then put it back in. Help if someone know what the code of two blinks means. Best regards tom
2 Suggested Answers
ArnelM
  • 183 Answers
SOURCE: Green light comes on then goes right back off.
The TV indicates an error code 22 (short circuit protection). Check 2 STK392-570 convergence IC for shorts and 5amps pico fuse for open. I usually replace both STK's.
Posted on Dec 26, 2009
Bauknecht GSFH 1492 lights up but will not start. The 6 hour delay light is on but I can't click it away. Have tried unplugging it. Is there any other way to reset the machine?
A bit long winded but if you set for , say a rinse, leave it on and see if the timer runs out if you don't know how to reset it.
May 25, 2017 | Washing Machines
Dishwasher stops after a couple of minutes and F4 shows on the display
the F4 problem in the Dishwasher is common, and the solution is often to replace the Water Indicator unit. This is because the light-action microswitch attached to the unit often loses its spring.
Replacement is HERE if required.
Also, dismantle the sensor unit to get all the "gunk" out. There can be a carpet of white goo covering the rubber diaphragm, get the thing out of the machine though the front bottom inspection cover.
May 08, 2010 | Bauknecht 24 in. GSF8971 Built-in...
Hi, on my WAE8987 Washing machine, the fault code 'F07' keeps coming up, can anyone help please? thanks
Bauknecht are built by Whirlpool.
F7 on Whirlpool means flow meter failure.
Check water inlet, check the pressure switch, and check the sump filter at the bottom of the dishwasher.
To reset try turning on the power and holding the start button and the + and - buttons at the same time.
Dec 01, 2009 | Bauknecht Dishwashers
Hi my Bauknecht GSI 5411 dishwasher seems to starting ok but then it stops after a couple of minutes. have checked the water supply tap as well as the filter and they seem to be ok. Please help
Set the machine to the end of the drying cycle, when it has finished, try pouring boiling water into the machine about a kettle full there is a sump level control beneath the removable filter (where all the **** gathers) if this has fat deposits on it this type of problem can occur.
Nov 05, 2009 | Bauknecht 24 in. GSX7551 Built-in...
My Bauknecht dishwasher stopped working
Check all your breakers. Remove the wall plug, count to 20 and plug it back in and count to 5. This will reset it.
Jul 17, 2017 | Bauknecht 24 in. GSFP3988 Built-in...
Bauknecht GF7199 F7 light has come on
F7 error indicates a fault with the water flow meter .
Check the sump filter at the bottom of the dishwasher, then close the door and turn on the power. then hold the start button with the + and - buttons under the LCD display, until the drain pump starts. This should then reset the dishwasher.
Hope this helps .
Mar 06, 2009 | Bauknecht Dishwashers
Bauchnecht GSF 5343 dishwasher
I used to work for Bauknecht years ago.
I dont remember that machine, but it could be an indication that your salt dispencer needs refilling.
May 04, 2008 | Dishwashers
Bauknecht GSX4756 dishwasher
I have this problem frequetly - it's an easy one to fix! Just press the programme button which changes the programme setting you want (on my built-in GSX4756 it's the last button on the right) and keep it pressed in until the beeping stops. Then start it again (will probably be on the rinse programme if it's like mine).
Feb 08, 2007 | Bauknecht 24 in. GSFP3988 Built-in...
Televison & Video Logo
179 people viewed this question
Top Televison & Video Experts
Electro Med Services...
