Question about Car Audio & Video
03 chev silverado radio on but no sound
Factory radio - turn on+ all displays + functions buttons seem to work
but no sound from speakers.
i shut off truck at work -8 hours later start up + no sound
displays light up- vol. display goes up/down -tuner finds station
scanner scans -etc. but no sound!!!
got any ideas? thanks...
  • 379 Answers
Studying the radio schematics , i'm seeing a radio amp fuse under the hood ,in the main fuse box under hood , 30 amp , check that for starters , if the amp was out you would only lose sound , would like to get a fix ya vote , comment back because i have other thoughts on your schematics , and do you know if its the base model or premium sound , with or without cd ? , thanks .
Posted on Jan 11, 2009
Getting no sound from speakers on my Cambridge i765 tabletop radio/cd player with ipod dock.
Hi Linda,
Here's a link to the manual to start with.
I see that pressing the snooze button operates the mute function and I presume that pressing Play or the Snooze button turns it off.
Could be that the button is stuck or damaged.
It could be a loose connection or a cold solder joint on one of the circuit boards as well.
I don't know how old your radio is but sometimes capacitors and other components just wear out.
You could take it to a repair shop and they can give you a good idea what the problem is.
Apr 22, 2015 | Audio Players & Recorders
I have a 03 hummer h2 with a Bose sound system. The speakers won't work. The radio is on it changes channels but the volume does not work on the radio or on the steering wheel. Neither the CD funtion,...
It could be a bad amp. Those come with a factory amp usally right behind the radio. Hopefully you can find a used one from a scrap yard. Click Here to search in your area.
Jun 12, 2011 | 2003 Hummer H2
03 silverado radio worked this morning.started it in afternoon no sound but display lights up.
No solution but same problem. However mine intermittent. It will come on and run the passenger side speakers and then shut off. All panel displays are on. Next day same thing. I think it has something to do with weather. When it is below 30 deg it doesn't work. When it gets 45 deg and up it works somewhat. It sounds like a bad circuit board connection.
Sep 09, 2010 | 2003 Chevrolet Silverado 1500
I am replacing the radio in my '97 chev silverado truck with a after market radio. It comes with a different wiring plug with 12 wires and the present one has 15 and basically the color coded wires do not...
easy fix is to go to a car audio retailer such as best buy an pick up a wire harness adaptor they generally cost 10 to 15 bucks this will save you the hassle of tracing down the wires however general wires are red-power black-ground blue remote amp turn on eight of the wires are for the front and rear speakers thier colors are paired an example would be solid green and then green with a black line these two wires are for one speaker +/- connections you can connect on speaker one at a time and then use the balance and fader control on the radio to check which wire are for front/rear and left/right speakers the factory radio has extra wires which usally control power antena,and dimmer switch for when you turn the headlights on
Jul 16, 2010 | Buck Honda Prelude 1999 Car Stereo/radio...
Hummer H2 speakers not working
Check if any mute function is not activated.
Oct 18, 2017 | 2003 Hummer H2
L322 reg02 radio display not workin no sound on tv or sat nav. visual display working on sat nav and tv but no sound. seems as if there is no power to left hand side of unit. righthand buttons working but...
solved the problem after speaking to the main dealers, disconnected battery for fifteen minutes then reconnected which rebooted system. Range rover say just like your home computer its got glitches so rebooting works, common problem in cold weather.
Jan 13, 2010 | Car Audio & Video
More than likely with a 2003, the speakers that cut out are in the door or doors. Do they cut out of both speakers?
If they cut out of one, then you may have an intermittent speaker ( the wire to the cone becomes partially connected)
If both speakers turn off at the same time and you hear NOTHING on all speakers, then you more than likely have an intermittent connection on the radio itself and probably replacement is probably cheaper than fixing the radio.
One more thing
Factory radios sometimes have an amplifier in them. Sounds funny but they call the Radio in the dash the Head Unit and the amplifier is buried in the dash. You could have a bad amplifier or a loose power connection to it, but that is very unlikely.
Hope this helps.
Mar 02, 2009 | 2003 Chevrolet Silverado 1500
My van radio runs on 2 different fuses- both in the fuse box under the dash. One runs the lights the other the sound. Hope this helps.
Jan 11, 2009 | 2003 Chevrolet Silverado 1500
No sound coming from deck
check the remote wire(the blue with white) is it giving 12 volts to the factory amp? some ford have amps that needs to turn on when the radio turns on.
Mar 17, 2008 | Alpine CDA-7863 CD Player
No sound
Check your remote turn-on lead connection - you may have a factory amplified system which isn't getting turned on, which would explain the no sound.
Jan 08, 2008 | Pioneer DEH-P6800MP CD Player
Car Audio & Video Logo
355 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
