Question about Pioneer DVR-3100 DVD DVD Recorder
Pioneer dvd recorder dvr 310
I went into the menu options and accidently set the remote to the 2 setting. what this did was make my remote not work anymore, is there any way to reset this to default without the remote???
  • 934 Answers
I've seen this problem somewhere before, ran across it on a service call or something and I just can't remember where.. Just getting old I guess.. You should have a "Return" button on the remote. Press it and the "2"... That should allow you to access the unit again. What you've done basically is set the unit up as unit 2 and you could have as many as 3 identical units all operating from the same remote. So, Pioneer, in their infinite wisdom decided to make three specific designation points and allow you to switch the remote to access each one without disturbing the rest... If this doesn't solve the problem you might try calling Pioneer support, 800-421-1404 and they should clearly be able to help. Good Luck Bill
Posted on Jun 07, 2007
My dvr had a timing issue and said to check the IB? or BI? so I went to the setup and seen the IB menue,.. it was on DR-1 and I clicked on DR-2 and now I can't do anything using the reomote. It only works...
Go to the menu button on your dvr look closely it wil tell you what button to use. Once there go back to setup and undo what you did. After this go into the menu where it says restore to factory settings and restore it to the factory settings. This will resolve your problem.
Aug 18, 2010 | Toshiba RD-XS52 DVD Recorder
Resetting the Recorder to Factory Settings
1. Make sure that the recorder is on
2. Press and hold the STOP button and STANDBY/ON button.
The recorder turns off with all settings reset.
Try this and let me know if it works.
Mar 27, 2008 | Pioneer DVR-3100 DVD DVD Recorder
Is there a cable that allows us to plug a laptop computor into the Pioneer DVD recorder DVR-310 for Recording and playback ? Also our recorder has trouble recording to discs, seems to be hit and miss if we...
yes, and also you can hook laptop to tv, mine is hooked to a 9 foot projector screen, call 4 free 3363926682 depends on what inputs u want conect 2 for cable suggestion God Bless
Apr 15, 2010 | Pioneer DVR-310S DVD Recorder
Pioneer DVR-225 Set Up Code?
I believe it is one of these three:
021, 013 or 048
Mar 07, 2010 | Pioneer DVR-225 DVD Recorder
Can not get my sony dvd to get off of dvd1 and it is now locked u
Go to your DVR and manually turn the DVR off. Press the STOP button for
two or three seconds. The DVR COMMAND MODE setting will display in the
DVR window. (DVD1, DVD2 or DVD3)
Set the remote to the COMMAND MODE setting that was diaplayed by depressing
both the remote ENTER key and the desired number key (1, 2 or 3) and holding
them both at the same time for 3 seconds.
You can now use the remote to set the DVR to the desired COMMAND MODE.
To do this depress SYSTEM MENU on the remote and go to SETTINGS and then
COMMAND MODE. Select either DVD1, DVD2 or DVD3. Once you delect a setting
that is different from what was set, your remote will stop working again.
Reset your remote to the desired COMMAND MODE by depressing the remote ENTER
key and the desired number key (1, 2 or 3) and holding them both at the same
time for 3 seconds. The remote should now control the DVR.
Nov 14, 2008 | Televison & Video
Remote control
I called a Tech @ Panasonic and he told me to point and hold the "OK" button and the number 2 for about 10 seconds. Then I pressed the power button for the DVD recorder and it worked.
Jan 30, 2008 | Pioneer DVR-530H-S DVD Player/HDD Recorder
PioneerDVR-225 recorder
A lot of the functionality you are wanting is tied to the remote that you have misplaced. You can go to the Pioneer support site and order a new remote, though it is like $30.
As for wiring options to record, it depends on the inputs and outputs that are available on your television.
- Ideally, connect VCR to TV input "1", connect DVR output to TV input "2", and conect TV output to DVR. This will help you avoid any copy protection issues you run into, but not all TV sets have both audio and video output.
- If you don't have TV outputs, connect VCR out to DVR in, and then DVR out to TV in. This will definitely work, but you will have to have the DVR turned on to watch a VCR tape.
Nov 24, 2007 | Pioneer DVR-225 DVD Recorder
Pioneer DVR-520H DVD Recorder Picture is Yellow
If running component or RGB try replacement lead set. Otherwise is TV issue.
Oct 12, 2007 | Pioneer DVR-520H DVD Recorder
DVR-310
These are from the instruction manual:
If the recorder is on, switch it to standby
Press and hold STOP on the front panel for 3 seconds until the fron display shows unlock.
Aug 18, 2007 | Pioneer DVR-3100 DVD DVD Recorder
Pioneer DVR-3100 DVD DVD Recorder Logo
215 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
