Question about Sharp Office Equipment & Supplies
Sharp ar-122e n F2 error 04 subcode - Sharp Office Equipment & Supplies
marsrover
  • 682 Answers
SOURCE: request service manual for sharp AR-5316
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=7b292ec58f421b3b3b442c1437984770&q=Sharp+AR-5316
Posted on Apr 19, 2008
  • 190 Answers
SOURCE: error code Sharp AR-M 257
The F2-04 error code you are getting is that you are using the wrong toner.It may be form sharp,but it toner chips is different.Only the chips swapping at the toner back can help you.
Posted on Jan 27, 2009
SOURCE: sharp ar 5320 error code f2
Dear sir.
I have a sharp copier machine AR-5320 when i switched on it shows U2 .Please help me ;
With beast regards
sayed Masood Osmani
Posted on Mar 10, 2009
  • 16 Answers
SOURCE: SHARP ARM 207 ERROR F2 04
Incorrect toner cartridge or has been refilled and gone past its life.
Replace toner
Posted on Jul 07, 2009
  • 30 Answers
SOURCE: Error code F2-04. Have replaced cartridge but to no avail
Try this solution I found on an other site.
In a Sharp MX-M450N copier this is due to improper cartridge.
The reason for the error code is of course due to an incorrect toner cartridge being used on the copier. You can turn the copier off, but it will not flush from memory. in order to correct the issue perform the following:
1. Turn the printer off
2. Remove the incorrect toner cartridge
2. Unplug the power cable from the wall outlet.
4. Plug the Printer back on
5 Turn the printer back on
You will see the message change to another message requesting to insert the toner cartridge.
6. Insert the old or new correct toner cartridge into the copier.
Posted on Dec 29, 2009
Sharp ar 5620 photocopy error f2
F2 errors means problem with toner supply or toner cartridge itself. For better understanding it is necessary to obtain a subcode by pressing START key. Clean toner cartridge CRUM chip contacts and check if cartridge destination is proper for your area.
Apr 15, 2013 | Sharp AR-M237 Copier
How to fix Sharp Copier AR-5731 Error code
good day, my Sharp AR 5731 showing the message Call for Service . Code : H4-00 can you help me to fixed my problem. thanks and God Bless
Mar 11, 2013 | Sharp AR-BC260 Color Copier
System error (f2-04) for Sharp Copier, model AR-M201
It is copy lamp error.
1- check the copy lamp on with sim.
2- replace the power unit.
3- replace the inverter.
4- replace the mcu pwb.
Jul 01, 2012 | Sharp Office Equipment & Supplies
Error code F2-04 and E7-10 on AR-168D
F2-04 is an improper cartridge code and the E7-10 is a shading/lamp brightness issue. I would say the F2-04 is causing both coded, Change the toner cartridge. I have seen those chips on the back of the cartridges cause weird problems. That or the developer unit has failed.
I strongly suspest that once you resolve the F2 issue the E7 will simply go away.
Aug 03, 2010 | Sharp AR-168D Copier
System error (f2-04) for model #AR 168S
f2 codes all have to do with the drum. have you replced the drum lately?
Dec 28, 2009 | Sharp Office Equipment & Supplies
F2-04 Error code - How do I clear?
Improper cartridge (destination error,life cycle error)
Dec 02, 2009 | Sharp Office Equipment & Supplies
Error code Sharp AR-M 257
Jan 15, 2009 | Sharp AR-5316 Advanced Digital Imager...
F2 ERROR CODE
WHEN F2 FLASHES JUST PRESS START KEY U WILL RECEIVE A SUB CODE.IF SUB CODE IS 02 THIS IS TONER SUPPLY PROBLEM IF 04 THIS IS DATA PROBLEM LIKE AS IDENTIFICATION PROBLEM MODEL ERROR TYPE ERROR.BYMIAN AKHLAQ
Oct 22, 2008 | Sharp AR-C160 Color Copier
Sharp AR-285 reporting code F2 and smeared copies
to find the sub code press start key,if it shows 04,then ic chip present in it gone bad,replace the toner ic chip.
Apr 20, 2008 | Office Equipment & Supplies
50 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
