Question about Candy Washing Machines
CANDY FRONT LOAD WASHER (8KG) GO108DFUK error E02
5 Suggested Answers
tunde007
  • 2382 Answers
SOURCE: I have a Midea 8kg Top Load washer, Model number:
Hi, the E2 error means you are having a problem with the lid swiych. If the washer fills normally, runs through the wash cycle, then stops at the spin cycle and won't drain, then you need to check your lid switch and/or lid strike.
This is the most common cause of the problem you just described. Symptoms may include, filling and stopping on the intial fill cycle, stopping right after the wash cycle, not advancing to rinse or spin cycles, and a wash tub that will not drain.
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike" or "Actuator") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug.
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because It does not have a lid strike and the small hole on the right hand side of the wash tub will not be present. This switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator by bending it slightly.
Posted on Feb 06, 2011
  • 27 Answers
SOURCE: Bosch Nexxt Washer Error Code E02
Check that water inlet tap is open and hose is not kinked....the error is for water inlet taking too long.... Oshie
Posted on Jun 26, 2007
barkencoa
  • 3463 Answers
SOURCE: I have a Bosch washer wfc5301uc it is showing error code E02
Could be a faulty inlet valve, or not enough pressure to operate valve,
Remove hose onto valve, and check the water is getting to it o/k,turning off the water to the valve before you undo the hose.
Hope this helps.
Posted on Jan 10, 2010
KevinWhite
  • 1902 Answers
SOURCE: Candy Grand 1600 AAA class
Hello & Welcome to FixYa
You can start with cleaning the drain filter pump assembly located inside the front bottom panel of the washer. After it's cleaned and the problem is back then replacing the control board is recommended repair. Please get back to me if you have any other questions.
Kevin
Posted on Jun 19, 2011
My may tag washer has codes F06 & E02 , what does this mean?
I beleive e02 is something to do with ur drain pump set up clogged or damaged water pump and hoses
Jun 15, 2015 | Maytag MHW6000XG Maxima High-Efficiency...
Washer will not run
f06 OR e02 error code means you have an interface communication error. the main control board isn't communicating with the front interface control board. if you pull the washer out and remove the 3 screws coming in from the back of the top panel. the top panel will pull straight back, up, and off. check all the wire connections between the two control board and make sure they are all secure. if everything looks good, then the interface control board may need to be replaced.
f01 e02 means that your motor control board is not reading the tachometer on your motor when it tries to turn the motor. it thinks that the motor is struggling. open the door and turn the basket to make sure it spins freely.
Sep 28, 2014 | Maytag MHW6000XG Maxima High-Efficiency...
F06, E02
I think these problems are related to water inlet, take off the hoses from the back of washer and you will find a screen in the outlets clean with old tooth brush until clear.
Feb 19, 2014 | Whirlpool WFW95HEXW Duet 5.0 cu. ft....
Getting E02 and F09 error codes on my Maytag Maxima MHW6000XW front load washer
Here is the manual. Hope it helps: http://www.applianceblog.com/mainforums/attachment.php?s=001fc13abc99c02a4aa812a23c01ac7e&attachmentid=13030&d=1381289434
Jan 05, 2014 | Maytag MHW6000XW - MaximaTM...
Error code F01 E02
For how long did you unplug the power cord? If it was under 5 minutes, unplug it for longer. Check if that clears the error code. If it doesn't, the motor control unit needs to be replaced.
Please double check your model number to get the correct part. Most of the Whirlpool washers have model numbers that start with 3 letters.
I hope this helps.
Dec 20, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Whirlepool duet front load washer error codes F01 and E02
Whirlpool Duet Washer model number WFW94HEW2
My wife put a bunch of wet towels in the washer after this we got Codes F01 E02. I freaked out.
Under the top(roof) panel of machine there is was a service technicians manual that explain how to enter Service Diagnostic mode and explained fault/error codes and their possible causes. This isnt for the faint among us. But if you can solder and work with electronics you can diagnose the problem. The technician manual tells you check this, then this and if that doesn't work/ or does work go to 'C', then go to 'D' etc. Either way I ended up diagnosing that it was my MCU (motor control Unit), you did have to use my multi-meter, for ohms and resistance, but it wasn't rocket science. Upon close observation there was a burnt connection solder point on the board. I looked up the part online and ordered, wasn't cheap. $225.00. But just to come diagnose the machine Whirlpool was going to charge $100.00 + parts and whatever else. The moral of the story is if you can tinker and be careful you can totally do this.
Jul 23, 2012 | Whirlpool Duet 3.8 cu. ft. Front Load...
I have 2 error codes on my front loading Whirlpool washer...F08 and E02...What do they mean?
well I'll just say it's the kaputnick gate valve located at the whirlpool headquarters since no-one else seems to have the same explanation for a single error code
Apr 30, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Flashing lights on my candy washing machine
Hello Mikana, i have a brand new one and it also flashes the 90 and stain removel had the Candy eng out and it needs a new heater...all the electric goes throught this heater and if it detects a problem then it shuts down...the ones they fit at the company are not vrey good so the replacement is going to be better....ring Candy ........also if it has a large load capacity like 8kg don't under fill it it may send the drum of centre and this will stop the machine....self protection built in...hope this helps...cheers Dave
May 25, 2009 | Candy CNW156 Front Load Washer / Dryer
E02 message
Error relates to water taking to long to get into machine. Check tap is open fully, water pressure is ok, hoses are not kinked. also check the small filters either end of the inlet hoses (inlet valves as well) as quite often they can clog up especialy on a new install. Regards
Jul 22, 2007 | Bosch WFMC 3200 Front Load Washer
Washing Machines Logo
1,042 people viewed this question
Top Candy Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
