Question about GE Spacemaker JVM1640SJ Microwave Oven
Microwave oven stays on continuously and won't heat food.
GE Profile Spacemaker II microwave oven stays on continuously if front door is closed, won't shut off, won't heat food. Have to unplug it and plug it in again, then it operates normally. Two days later, it did the same thing.
  • Anonymous Feb 18, 2009
    Cancel button doesn't work. The microwave turns on after the door is closed.
  • 52 Answers
Spacemakers have had problems with there magnatron, part is around 170.00. Depending on the year it is covered under a warranty however the labor is not. I have replaced 3 spacesavers for people already due to this issue. Unit runs but will not heat.
Posted on Jan 11, 2009
GE Profile Spacemaker 2004 JVM3670BF02 doesn't Heat up
Ensure that you have select the correct range of temperature.
Sep 11, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
GE profile mirowave JVM1350WW002 - won't heat
There three area's of concern, magnetron, "heats food" the high voltage diode, "sometimes crack" the high voltage capacitor, "usually shorts"
Mar 24, 2012 | GE Profile Spacemaker Over-the-Range...
After I microwave the light stays on and the turn table stays turning whats wrong?
From the description the problem is in one of the door switches, usually caused by food partical build up, or ware. Each switch will need to be disconnected and tested.
Mar 07, 2012 | GE Profile Spacemaker II PEM31 Microwave...
Jvm1870sk04 GE profile microwave will not shut off unless the door is open. Unplugged , pushed off/cancel continues to run with door closed. Any solutions?
Hi, Main control board bad...
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 19, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE spacesaver II making loud noise and is not heating up food
heatman101
Jun 04, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Spacemaker LX1800 that is not heating up the food. It acts like it was working normal but is not heating the food.
Basic Microwave Oven TroubleshootingTips
heatman101==]---=]
May 11, 2010 | GE Profile Spacemaker Over-the-Range...
When microwave finishes light doesn't come on when door open; display keeps reading "food ready" after food is taken out--have to push the "clear/off" button to make "food ready" display go away; counter...
Shorted switch in the door latch assembly.wihout the full model number I can't tell how to get to it, but usually one needs to remove top grille, remove screw holding the control panel, remove control panel. Good luck.
Nov 26, 2009 | GE Profile Spacemaker II PEM31 Microwave...
It is making a lound noise and no longer heats
heatman101
dgh
Oct 24, 2009 | GE Profile Spacemaker II PEM31 Microwave...
My spacemaker just stopped heating food. What do
This is a microwave, correct?
I suspect the door lock interface switch(es) are burned out. Unplug it, be mindful of the 25,000 volts in the silver thing. Check the micro switches (look where the door closes on the top right side, probably) two positions, normally open or normally closed. check them for proper operation.
Micro switches are the most common of microwave failures because most of us open the door while the machine is running causing arc at the switch and burning up the little contacts.
Sep 07, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
MIcrowave doesn't heat up food
heatman101
fdyjhd
Jul 18, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
349 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
