Question about Cooktops
LGHOBX12 gas hob fixing instructions
I don't appear to have instructions for the brackets and they are not that obvious on how to fit.
4 Suggested Answers
Eddie Rentas
  • 59 Answers
SOURCE: operating manual
Hello
To get a manual for that stove go to this link:
http://www.technika.com.au/
I hope that help...Good luck
Eddie Rentas
Tupper Lake NY
Posted on Jul 19, 2008
  • 222 Answers
SOURCE: No gas to hobs
use mactches for ur gas burner if the ignition not really work.put all gas in off position b4 cleaning by using a vacium in the place of the control knob,turn off the power b4 try to clean,tnx
Posted on Dec 02, 2008
SOURCE: Trying to get hold of a fitting instruction
Why do you need a fitting manual ? Any competent gas engineer should know the contents of BS6172 / BS6891 which both apply to the fitting of domestic gas cookers / hobs. What spares do you need. You can get a spares inventory from Neff. Ensure that it is the correct appliance for the fuel gas you are connecting to. The jet sizes for LPG & Natural Gas are very different.
Posted on Apr 16, 2009
Flame leaking under lower ring. Common?
no it is a problem with the hob
consider this
as it is a rental property it is the responsibility of the land lord to get a gas fitter in to fix / replace the problem
If you do not ask him to fix it , if there is a problem and the thing explodes, catches fire or gases some one to death, there is every possibility that he will try to blame you for not reporting it
if he refuses to fix it or tries to fix it himself then I would advise that you seek alternative rental accommodation as the problem is for an accredited gas fitter and not a landlord.
Sep 23, 2015 | Smeg 23 in. SE64 Gas Cooktop
Cleaned my gas hob but now when you turn the gas on the automatic ignition doesn't switch on. Model candy pl 40 ax. I have checked the fuse on the plug but that's ok is there another fuse I should kno
Is it pluged in. Check to see if the plug Still works behind the stove It might be on a GFI plug needs to be reset somewhere along the backsplash counter
Jul 19, 2013 | Cooktops
Im trying to install this cooktop maytag mgc7430ws, there are two brackets in it and there is absolutely nothing in the instructions about how to attach it to the cabinet
I just put one of these in. You're right, there is nothing in the instructions about this, I had to figure it out for myself.
Your kit includes two brackety-shaped steel brackets and two long screws. Look on the bottom of your cooktop, halfway between the front and back on the left and right edges and you'll see a hole on each side. They are the only holes on the bottom.
Manipulate the brackets until you see that the hole in the bracket matches the hole in the bottom AND the bracket fits upward along the side of the cooktop. The flange on the top end of the bracket goes against the bottom of the countertop.
It's useful to have another person lift each end of the cooktop while you insert the bracket from below.
Once the brackets are in lace, center the cooktop so it's straight on the countertop, then screw the brackets to the bottom of the cooktop. They will tighten against the countertop and make the cooktop stop wiggling.
May 31, 2011 | Maytag MGC7430WS Stainless Steel Gas...
Want a narrow ceramic cook top / hob
Look at Baumatic 90cm Slimline 4 Hyperspeed Zone Ceramic Hob. Dimensions are 350mm x 880mm
Apr 26, 2010 | DeLonghi Cooktops
Trying to get hold of a fitting instruction leaflet plus list of spare parts for a gas hob code no. E4NE T2484SOEU/01
Apr 16, 2009 | Neff T2346 Gas Cooktop
No gas to hobs
Nov 24, 2008 | Dacor Preference SGM466 Gas Cooktop
Gas Hob Flame
Hello
Tha sounds to me like the air mixture nedds to be adjusted on the stove, It's not difficult to do, just rotate it until the flames loose the yellow or your pans will be stained with soot.
The should be by the fittings (convertion fittings), you know?
LP Gas to Natural Gas or Natural Gas to LP Gas.
Hope this help
Eddie Rentas
Tupper Lake NY
Jul 30, 2008 | Cooktops
Operating manual
Hello
Eddie Rentas
Tupper Lake NY
Jul 18, 2008 | Tecnik Cooktops
Ignis Gas Hob AKL700
no. not in the uk. a fixed appliance must have a rigid pipe connection with a means of disconnecting/isolating. you must not use a flexible pipe.
pete
Jun 02, 2008 | Cooktops
Burner/Flame
Hiya .. this could be due to a number of problems...... has the burner ever worked correctly?
Is the behaviour with only one ring?
1. If not... then it could be that the pipework to the hob itself has not been recuced sufficiently enough in pipe diameter to the regulator far enough back ...
2.The regulator is faulty... in which case it can be replaced... however consider the cost of a new regulator and labour to fix it .. against the cost of a whole new hob... which should include a regulator. Is the hob still under warranty... if so use that .. but you will normally have to provide some proof it has been fitted by someone suitably qualified.
3.the regulator may never have been fitted, which is dangerous and bad practice.
Either of these scenarios... please ensure that you use a suitably qualified gas engineeer... I dont wish to be alarmist... but gas leaks and faulty gas appliances do cause unnecessary deaths...and is a silent killer.
Regards Faggly
Mar 26, 2008 | Maytag MGC5430 Gas Cooktop
Cooktops Logo
112 people viewed this question
Top Cooktops Experts
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
