Question about Lexmark PhotoJet Z705 InkJet Printer
Not printing after change of ink cartridges
Changed both #20 and #50 cartridges and then it never printed another page since. No flashing light from the power button. The red LED light that is on the bottom left side of the ink cartridges holder is flashing once every 3 to 5 seconds. I checked all the troubleshooting sections in the manual and still no solution. Please advise. Thank you. Tony
    Master:
  • 416 Answers
It looks like the cartriges are not tight enough. Try to reinsert them and restart the printer (unplug and plug back). The blinking LED just indicates that cartriges are not inserted or not properly inserted
Good Luck
Posted on Jan 11, 2009
    President:
  • 846 Answers
Try opening it again taking them out shut the door, unplug the printers power cord and wait a minute. Plug it back in and power it on the red blinking light should have stopped now and you can try reinstalling the cartridges. Make sure you have installed them properly if you have any more problems post back.
    Genius:
  • 2,035 Answers
Did you remove the protective tape from the cart and then installed ...If then please follow these steps :
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
  • Anand Kumar
    Anand Kumar Jan 11, 2009
    Then try to print ....
New ink catriges, ink is not flowing
This issue can be caused by several different reasons.
  • First, verify the tab protecting the ink from dispersing is not still on the cartridge.
  • Verify the the ink cartridges have been inserted properly.
  • If a lever has been changed from its original position allowing the ink cartridges to be added or removed, ensure it is back into its original position.
  • Perform a head cleaning on printer if available.
  • Verify no software errors are occurring abd print a test page.
  • If you are installing non manufacturer authorized ink, attempt to use the manufacturer's ink instead.
  • If any indication lights are flashing or are different, refer to your printer documentation or printer manufacturer's web page for additional information on what the lights are indicating.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Jan 02, 2013 | Canon PIXMA iP90 Mobile Printer
I was printing several pages & it just stopped working. the ink button & on button flash. Changed the ink cartridges but still get the same blinking with no printing. Turned both the computer...
Press the Ink Cartridge Replacement button and check the flash pattern of the control panel lights:
ERROR and POWER lights flash at the same speed = replace black cartridge
ERROR light flashes twice as fast as the POWER light = replace color cartridge
Jun 04, 2010 | Epson Stylus Photo 1280 InkJet Printer
Canon i250, black text won't print, but ok with nozzle check
Canon i250. Instructions on this website solved the problem of flashing green and orange lights, but now the black won't print. Changed ink cartridges, but still no print. Did a diagnostic nozzle check, and the black DID print. What do I do now?
Oct 21, 2009 | Canon i250 InkJet Printer
Red light on after changing ink
Perform the following procedure:
n Press the ink cartridge replacement button until the print head has moved to the change cartridge position
n Lift the lid that holds the cartridge (do NOT remove cartridge) and press down immediately. Then press the ink cartridge replacement button and allow the cartridge to charge the print head. Do NOT switch the printer off until the printer has finished charging.
Does this solve the problem?
Yes: Solved
No: Go to Checkpoint 2
2. If you have printed between 100 and 300 pages, and it is your first ink cartridge, or it has been installed for at least 6 months, replace the ink cartridge.
Yes: Solved
No: Go to Checkpoint 3
3. If you have printed more than 300 pages, and it is your first ink cartridge, or it has been installed for at least 6 months, replace the ink cartridge.
Yes: Solved
No: Further help required
If red light again you must download resetter software from internet to reset your printer.
Aug 21, 2009 | Epson Stylus Photo 1290 InkJet Printer
I have changed all the ink cartridges on my Brother MFC5440CN it
Light/faint prints usually are a result from clogged ink or air bubbles between the cartridge and print head (thus changing cartridge wont fix problem). Try printing the test page print from the machine (Ink Management -> set/ok twice). Answer the question(s) in the display and repeat this up to five times. The colors should be improved after 1-3 test prints usually.
Jun 03, 2009 | Brother MFC-5440CN All-In-One InkJet...
Kodak EasyShare 5100 won't print
I have had the same frustrating problem.
I cntacted the Kodak live web chat help line and after removing the print head,switching the machine off for 1 min and reconnecting.Clean heads and recalibrate.
.....Still the same.
They then told me the print head was faulty and to contact Kodak for free repalcement.
Sep 15, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Epson Stylus CX 4800
actually, all you did was correct.
if it´s not the unit - hopefully the cartridges
call EPSON - prepare the date of purchase / place of purchase of the inks
Dec 28, 2007 | Epson Stylus Pro 4800 InkJet Printer
Lexmark PhotoJet Z705 InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
