Question about Viper Security and Remote Start System (basic install included)
Battery Died, now remote start wont work at all
My battery in my car died when I left the keys in the ignition. I got the battery recharge, car is working fine. Remote start won't work at all. Is there something I need to do to reset the Remote Start?
  • 905 Answers
There is a reset button stuffed under the dash ( drivers side ) , it has two wires from it to the alarm box ( not the switch )
Posted on Jan 28, 2009
  • 1 more comment
  • jason Jan 29, 2009
    the reset is also known as "valet mode" on and off( to activate put ignition in on position then press the button) then try to remote start , repeat to exit "valet mode"
    also if the toggle switch has been switched to the off position the remote start will not work( depending on
    or also you can try to resync the communication between the remote and module by repeatedly pressing the lock button
    you can look for your models manual here http://www.viper.com/support/
    under the guides tab
New battery In mercedes no power
I'm not a car mechanic, but, it sounds like you might want to check the fuse to the ignition switch, and, if that fails, it might be a problem with the Start Safety Switch on the transmission. Good luck.
May 02, 2017 | Mercedes-Benz S-Class Cars & Trucks
Battery died and was recharged but jeep will not start
sounds like the battery was nearing the end anyway and might never get back to working order
Sep 26, 2012 | 1996 Jeep Cherokee Country
Battery died now wont start
the security system need to be reset, plug your charger back on the battery then turn the ignition switch on and leave it on untill the security warning light turns off (about 10 to 20 Min) then turn the key to off wait 5sec then turn the car on it should be good to go, this solves this kind of problem 9 out of 10. good luck
Apr 07, 2012 | 2006 Saturn ION 2
I left my trunk door open all night and my battery died. I thought the key I use for the ignition would be the same key to unlock the door if the battery died? How do I enter my 2006 Dodge stratus with the...
Thank you for contacting fixya.com.
The key lock/unlock for doors are powered by the batteries in the remote, while the ignition key draws its energy from the vehicle via induction. Since the battery is dead you are having this problem. You need to call assistance from the nearby auto shop or a locksmith. I guess you don't have any other option.
Jun 27, 2011 | 2006 Dodge Stratus
Battery died, Recharged, car still won't start
sounds like the anti-theft system, try this, turn key on and walk away for 30 mins, after 30 mins turn key off, wait 15 secs, the try starting, this should reset the anti-theft system
Jul 03, 2009 | 2001 Chevrolet Malibu
1997 Honda Civic: Battery died and the Alarm won't disable
If you hook up the jumper cables can you disable the alarm with the remote?
Jun 24, 2009 | 1997 Honda Civic
Left key in ignition overnight, now car wont start
try checking the main relay under the dash
Mar 15, 2009 | 2004 Honda Odyssey
95 buick lesabre wont start
98 buick lesabre wont crank with key. When I cross the starter it runs great for 10 seconds and dies.
Nov 08, 2008 | 1998 Buick LeSabre
Battery died
what i would do would be to try and jump the car by popping the hood and connecting the jumper cables to the jumping post under the hood. there is a positive , and what you need to do is just ground the negative to something metal(not engine block). this is located close to the front left corner. email me if you dont understand. i will try to explain better. Aggie2292@yahoo.com
Sep 17, 2008 | 2008 Chevrolet Cobalt
Electronic immobilizer
i recently had the problem with the immobilizer after mo 03 jetta battery had died after speaking with the dealer they said i would have to tow it to them. yeah a 160 miles after reading several blogs i put the battery charger back on put the key in the ignition and turned it to the on position and left it for @ 20 minutes when i returned the immobilizer light was out i then cycled the key off and back on the light came on then went out as it should then proceeded to crank the engine over and it fired without problems and seems to be fin now......curse greedy dealers
Aug 17, 2008 | 2002 Volkswagen Jetta TDI
Open Questions:
Viper 4806v won't program I am trying to install a viper 4806v two-way remote start/keyless entry in my automatic 2004 toyota camry LE 4cyl. I got the lock/unlock, horn, lights to work, and trunk pop to work. I can't seem to get the remote start to work. When I press the remote start button on the remote keypad, the car does not start and the headlights flash 7 times. Troubleshooting says 7 flashes mean a manual transmission mode error. This means I have to enter programming menu 3 and change the starter to automatic mode. When I follow the directions to get to menu 3, nothing happens because I cannot get to menu 3 when I hold down the control button after turning the ignition off. In other words, the control button is not working. The neutral switch is on like it is supposed to be. Kind of bummed about this. Could use some guidance. My wiring goes accordingly and this car does not have an immobilizer because I used a regular metal key to start it. This car has no alarm, just a stock keyless entry, trunk release, and panic button. Again, the problem is :The remote start comes in default manual transmission mode so I have to switch it to automatic transmission mode but I can't seem to enter programming. When I try to enter programming with the procedure followed using the control button, nothing happens. It does not chirp and the LED does not blink. I also cannot enter valet mode using the control button. When the car is locked, the LED blinks and stop blinking if car is unlocked ignition is turned on. I do not understand what is going on. VIPER 4806V Wires --->Camry Wires Main Harness 6pin connector H1/1 Red 12volt input (+) --> (+) White/Red at ignition Harness H1/2 Black Chassis Ground (-) --> Car Frame (-) H1/3 Brown 200mA Horn Output (-) --> Green/Black (-) at steering column H1/4 White/Brown Light Flash Isolation Wire --> NOT USED H1/5 White Light Flash --> Hazard Light Flash Relay Lt. Green Black wire (-) H1/6 Orange Ground when armed --> NOT USED Door Lock 3 pin connector 1 Blue 500mA Unlock Output (-) --> Blue Wire (-) white connector at driver kick panel 2 Empty --> NOT USED 3 Green 500mA Lock Output (-) --> Blue/Yellow wire (-) blue connector at driver kick panel Auxillary/Harness 24 Pin Connector 1 Pink/white 200mA Ignition 2 output/ Flex output (not used) --> NOT USED 2 Blue/White 2nd Status/Rear defogger output (-) --> NOT USED 3 Red/White 200mA Trunk Release Output (-) --> 5pin Relay Pin 85 (86 & 87 to +12V, 87a White/blue trunk wire toward dash, 30 white/blue trunk wire toward trunk) 4 Black/yellow 200mA Dome light Output (-) --> NOT USED 5 Dark Blue 200mA Status Output (-) ---> NOT USED 6 White/Black 200mA Aux 3 Output (-) ---> NOT USED 7 White/Violet 200mA Aux 1 Output (-) ---> NOT USED 8 Orange/Black 200mA Aux 4 Output (-) --> NOT USED 9 Gray Hood Pin input (-) ---> Installed at hood and Switch is open when hood is closed 10 Blue Horn input (Jumper set (-)) --> Green/Black (-) at steering column 11 White/Blue Activation Input --> NOT USED 12 Violet/White Tachometer Input --> Black/Orange wire on the Datalink Connector 13 Black Neutral safety/Parking Brake Input (-) ---> (-) Ground to metal frame of car. 14 Green/Black 200mA Factory Alarm Disarm Output --> NOT USED 15 Green Door Input (-) --> Red/Black Wire (-) (Door open indicator on dashboard) 16 Empty --> NOT USED 17 Pink 200mA Ignition 1 Output (-) --> NOT USED 18 Violet Door Input (+) ---> NOT USED 19 Violet/Black 200mA Aux 2 Output --> NOT USED 20 Brown Brake Shutdown input (+) --> Green/White Wire (+) at brake switch above brake pedal 21 Violet/yellow 200mA Starter Output (-) ---> 5 pin Relay pin 85 (Pin 86 & 87 is +12volts, Pin 30 black/yellow starter wire (+) at pin 8 in ignition harness) 22 Gray/Black Diesel wait to start Input (-) --> NOT USED 23 Orange 200mA Accessory Output (-) --> NOT USED 24 Green/White 200mA Factory Alarm arm output (-) --> NOT USED Remote start 8 pin Connector 1 Red/black 12v Constant Input for Acc and starter relay (+) ---> White/Red wire 12v (+) at ignition harness 2 Pink/black Flex relay input 87A key side (+) --> NOT USED 3 Pink/white Ignition 2/ Flex Relay output (+) --> Black/yellow pin 4 at ignition harness 4 Red 12V constant input for ignition 1 Relay (+) -->White/Red wire 12v (+) at ignition harness 5 Violet Starter Output (+) --> Black/White wire (+) at ignition harness 6 Accessory Output (+) --> Blue/Red (+) at ignition harness 7 12v Constant input for ignition 2 and flex relay (+) ---> White/Red wire 12v (+) at ignition harness 8 Pink Ignition 1 input/output (+) --> Black/Red wire (+) at ignition harness.
Oct 20, 2014 | Viper Security and Remote Start System...
See all Viper Security and Remote Start System (basic Questions
Viper Security and Remote Start System (basic install included) Logo
1,679 people viewed this question
Top Viper Home Security Experts
Will Halftowaite
jason
Kevin Daniels
Are you a Viper Home Security Expert? Answer questions, earn points and help others
