Question about Akai LCT3201TD 32 in. LCD Television
No picture no signal
TV says no main signal
  • 362 Answers
Hi troberson58,
Try pressing the input button on the remote control until it finds the right input. Also if there is a PIP (Picture in Picture ) button try pressing it. Let me know if this helps and please rate this solution. lone99star
Posted on Jan 11, 2009
  • David chandler
    David chandler Jul 27, 2014
    what is the input button on remote control
While watching tv the picture went blank and then displayed wide black and gray columns. The only way to power down is to unplug the tv. Any suggestions?
Ur tv main Tuner signal board it some how got shorted and dead to causes this problems.That the board where the tv incomming broacasting signal cable wire plug into it.U have some basic mechanical skills like take aparts and putting it back together again?Yes.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish main tv Tuner signal for the replacement.
Aug 03, 2011 | Vizio VX37L Television
When we 1st turn on the tv the left half of the screen is black right down the middle of the screen,,,,then 15 mins or so it starts to slowly regain strips of color and finally it has a full picture! Then...
When tv it does have a full picture,the tv it work ok?Yes,tv it is repairable.This tv problems are only have two possible electronic boards causes.1 the tv board that call the T-CON decoders board it is dying,this board sit in the middle of the bottom of the LCD screen panel,it control and decoding all the picture dots pixels before it gose into the LCD screen panel.2 worst cases the main board the tv Tuner signal board is it dying,this board control everythings.Like it take in the outside incomming signals sources,like the tv incomming broadcasting signal cable wire and all the external electronic unit divices plug it into the tv.80-90% this tv problems it is the causes by the tv T-CON decoders board only.Tries websites like Shopjimmy.com,Ebay.com to buy a reburbish T-CON decorders board and the tv main board Tuner signal board for the replacement.
May 07, 2011 | LG 42LC2D 42 in. LCD HDTV
WHITE DISTORTED SCREEN
U Main Tuner signal board is dead.Replaced the Main Tuner board will solved this problems.Picture was white distorts,he should of replaced the Main Tuner board.The T-con control board only replaced when u have power to tv,but no video.When have any kind of video on the tv all it way cause by Main Tuner signal board.
Mar 17, 2010 | Televison & Video
Tv screen is green
Ur Main Tuner Signal board is the cause.Replaced this Main Tuner Signal board will solved this problems.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish Main Tuner Signal board for replacement.
Mar 02, 2010 | Maxent MX-42HPM20 42 in. Plasma HDTV
No Signal through on my main TV input.
This may be the tuner or IF module that is failing. It may also be a voltage supply fault to these modules. It is impossible to accurately speculate without actualy troubleshooting the set.
Jerry G.
Nov 10, 2007 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
No color
does the tv use Svideo as an input from whatever device you're using on the main screen? if so , try changing out the cable for a new one, svideo carries 2 signals, color and brightness (ie color and black signals) if your cable is bad or broken, you may only be getting one of those signals ( the black one) try a new cable if it's s-video. if it's not, get back to us.
Sep 13, 2007 | Hitachi 50SBX78B 50" Rear Projection...
PICTURE IN PICTURE TV RCA
The PIP puts a smaller picture on your main picture. Usually, the smaller picture is generated by a second source, such as a VCR. The VCR must be connected to the main cable signal and connected to the TV through the red, white, yellow RCA jacks. The VCR picks the smaller picture whilt the tuner in the TV picks the main pucture. The PIP circuits digitally add the smaller picture to the larger picture. The PIP cannot be used to veiw 2 different channels at once on satellite systems because the satellite receiver sends only one channel to the set at a time.
Aug 22, 2007 | RCA F32665 32" TV
No color, only black and white
There are no bulbs inside this set to replace. This TV set is all solid state. That means it uses transistors and IC's to work. If the color is not there you could have a bad tuner assembly in this TV set and to replace that would cost you more then the TV set is worth. Sorry. Good Luck
Jul 18, 2007 | RCA BD20TF10 20 in. TV/DVD Combo
No pic/sound on main screen
I will recommend replacement of the main tuner
Dec 10, 2006 | Toshiba CN35F95 35" TV
Akai LCT3201TD 32 in. LCD Television Logo
123 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
