HP PhotoSmart 130 InkJet Printer Logo
Posted on Jan 11, 2009
Photosmart 130 I was recently in contact with you concerning my Photosmart 130. I heard from several HP personnel but was unable to resolve the problem.The printer serial number is TH263210KW and it was purchased about 4 years ago.The paper goes into the printer to the rear, but will jnot return through and print. When the paper gets to the rear of the printer the PRINT light starts flashing. I have installed a new cartidge but the problem persists.Can you help?Caryll Forbes. My e-mail address is [email protected]
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Sep 29, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
146
Points
Mine just had this error and I fixed it by cleaning the big front black roller and the small Grey rollers in the back with q-tips and rubbing alcohol
2answers
I have an hp c4580 all in one printer. Previously all worked fine on windows vista. Now with new laptop hp pavilion windows 7, it will not scan from printer to pc, for example, I can not scan a photo. I...
Check to make sure you have the correct driver for your operating syytem; are you running Windows 7 (32-bit) or Windows (64-bit)?
Go to Start > Device and Printers > System Check under System type to confirm your operating system.
If you do not have the correct driver you can download from here. Make sure you also download the three (3) Utility- Diagnostic Tools. These may be able to help resolve your problem if you do not already have them.
Please note that HP has posted several alerts for this products concerning Windows 7. You should review; Resolving HP Solution Center Scan and Product Status Issues After Upgrading Windows Vista to Windows 7 and Scanned Files Disappear after Scanning with HP Solution Center
If you feel you have the correct driver properly installed try running the Scan Diagnostic Tool. If you are unsure about the driver I would start there with an uninstall of the current driver and download of an updated driver for the installed operating system.
If this does not resolve problems work through the advice provided in the on-line resources linked above.
Good luck in resolving your problem.
HP photosmart 130 operating manual please
Hi
You can download the manual for your HP Photosmart 130 from this link:
HP Photosmart User Manual
Thanks
Rylee
Unable to receive faxes on HP Photosmart Premium
Check the configuration set for incoming FAX and rectify the settings may resolve your problem.
Thank you for using Fixya.
2answers
HP Photosmart c7180 unable to scan since Windows 7 computer
go to following location and try to scan and tell me if it is scanning fine or same issue.
c:\program files\hp\digital imaging\bin in bin folder locate following files. /* in 64bit operating system inspite of program files look into programe files(x86).*/
1.> hpqscnvw
2.> hpqscnappi
3.> hpqdstcp.
4.> hpqgrpky.
double click on any of these it will start scanning.
New Black cartridge installed. Only part of page prints.
I understand your concern and to resolve the issue you need to download and install HP smart web printing software. Click Here for HP Smart Web Printing software and select your operating system and download & install the software.
2answers
User / owner manual = HP Photosmart 130
Please click the link below to go to the manual download page for your printer:
HP Photosmart 130 manuals
37helpful
2answers
HP Photosmart C7280 Ink System Failure
Hello rjjgraphics.
This is a serious hardware issue in the unit and in most cases , the unit needs to be replaced, so there is a less chance of the issue getting resolved.
Thx
All the best
Hp photosmart 3313 all in one
If you are getting inksystem failure along with Error 0xc18a0106 then contact HP support. If you need their contact info I can give it to you.
Thanks,
Lee
k24674
Grand Canyon Tech
Grand Canyon Tech
