Question about Garden
Tension arm on a john deere 717a mower deck - Garden
5 Suggested Answers
SOURCE: replace blades on a john deere L120 mower deck
First make sure you have the tools, metric that is. The deck must be removed and turned over. To do this you must put the deck in the lowest position. Using a 15mm socket pull the belt tension spring pulley forward to detach from clutch. Next remove retaining pins located at the five deck brackets. This will allow the arms to slide off and the deck can be dragged out from under the mower. Turn deck over. Use a 18 inch 2x4 to block blades while removing the two 15mm bolts. The bolt heads will need to be cleaned so the socket can seat on bolt head. I use my torque wrench to get more leverage and i can use it to reset blade bolts to 64 ft lbs. While blades are of it is a god time to thoroughly clean underside of deck.
Posted on May 25, 2009
SOURCE: john deere 111 mower deck. Lift is in stuck in highest position
Looked up detailed isometric diagram w/ parts denoted on John Deere website. FixYa website was a litele misleading. I did not realize that accessing a question posted "for free" would cost me something to get the answer. It's kind of like askin a neighbor as a neighbor to give you a hand and then he sends a bill.
Thanks but no thanks
Posted on Jun 26, 2009
  • 5 Answers
SOURCE: need john deere stx38 mower deck belt diagram
Go to http://outdoorpowerinfo.com/repairs/deere_stx38_gear_drive_belt.asp
for pictures and descriptions of drive belt and deck belt on John Deere STX38 and STX46 tractor with black deck
Posted on Oct 22, 2009
farmerbear
  • 490 Answers
SOURCE: need mower deck belt diagram for L-130 John Deere
I have found the manual at JD's website. Click the link and scroll down in the left column until you find the heading for replacing the belt. I contains big, clear photos. Here is the link:
http://manuals.deere.com/cceomview/OMGX21647_K3/Output/Index.html?tM=HO
You can copy it into your browser window or type it in. I sure hope this helps you out. If I can be of any further assistance, please let me know:)
Posted on Aug 21, 2010
How to level the mowing deck on 2002 John Deere (Scotts) 42 " mower. Mower deck drags on right side. Mower height adjuster doesnt work seems jammed.
Have a look underneath while someone operates the height adjustment. There's probably a link arm come off which does deck height. Go to google images for this machine, type height adjustment and look at the pictures if you don't have a handbook. Google JD handbooks and see if you can find a free download.
Aug 13, 2016 | John Deere Garden
I need a diagram showing how to route a mower deck belt on a John Deere model 240 mower deck. My spring has fallen off and I need to know where it goes to put the tension on the belt.
Here's a link to an online John Deere parts store. When you land on the page, look at the top sub categories for the size of deck your mower has. You should be able to access a parts diagram with pictures of your belt's proper placement.
http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt
Mar 07, 2016 | John Deere Garden
John Deere 320 Lawn Mower will not move
You have many switches in the safety circuit. turn off the blades, try to start again.
Jul 15, 2015 | John Deere Garden
How to adjust tension on belt of John Deere Ride On D140
How to adjusted Cutting Deck Belt Tension
You do not say which size cutting deck you have. I will be writing about the 48", 3 blade cutting deck
The belt on this deck is self tensioned. The tension is provided by a spring attached to a moveable pulley on the deck. When the belt is in place you can manually force this pulley forward/backward and it will release the tension.
If the belt is off track, place the belt back around all the pulleys in the correct path, lastly force this spring loaded pulley forward/backward (depending on your deck, the direction is not important, the tension is) to get the belt around the pulley. If the belt is placed correctly, when you release the spring loaded pulley it will properly tension the belt.
Typically, these belts should not be jumping off. If yours is coming off frequently the belt may be worn. When they wear they get quite a bit longer, then the tension pulley cannot apply the correct tension. Rarely does the tension spring have to be replaced.
The other problem that causes belt jumping is worn spindles and stationary pulleys. The spindles are the most likely to need replacement. You can buy excellent replacements for JD spindles on Amazon for very reasonable prices. The following spindles are super replacement spindles for the 48" deck. They may very well be the same for smaller and larger decks; I have not researched that. Just search Amazon for Silver Streak # 285851.
Silver Streak # 285851 Spindle Assembly for JOHN DEERE GY21098, JOHN DEERE GY20962,
Product description:
Spindle Assembly / John Deere GY21098 Pack Size:1 JOHN DEERE GY21098, JOHN DEERE GY20962, JOHN DEERE GY20867, JOHN DEERE GY20454 OREGON 82-359, ROTARY 12910, ROTARY 11964 JOHN DEERE D100, D110, D130, D140,D150,D160, LA100, LA105, LA110, LA115, LA120, LA125, LA130,LA135, LA140, LA145, LA155, LA165, X110, X120, X140 Includes grease Zerk, pulley lock nut, blade lock nut, and washer , Height: 7 ", OD: 5 "
You can also find replacements for the flat pulleys on Amazon. If you cannot find what you need there, go to http://www.greenpartstore.com//
Mar 08, 2015 | John Deere D140 48 in. 22 HP Front-Engine...
John deere 717a shut-off while mowing
Mine took a Poo this evening. It's a 717A Z turn and it's run just fine for 4 years but tonight it kinda Popped (like something broke) while under a slight load and then shut off. Oil level was slightly low and curious if I blew the engine. It still cranks just fine but won't fire off? Acts like it's not getting fuel but the filters are all clear and fuel flows. It's my Church's mower and the Blue hairs are gonna kill me if I blew the engine.............I'm toast!
Jul 30, 2012 | John Deere Garden
Need to know how to adjust deck belt on a 54
I would need the model # of the deck and tractor, but all newer mowers use a spring to maintain constant belt tension. I can get you a diagram if you need one.
Dec 03, 2011 | John Deere Garden
INSTALLING THE MOWER DECK ON JOHN DEERE 345
Can't help you completely but I believe the brass colored bar coming from deck towards front should be on top of the black bar that puts the tension on. I had it on the bottom and the both bars ended up under the deck.
Apr 16, 2010 | Garden
John deere mower deck belt
try this. unhook the tensioning spring so you can get the belt on and the get some vise-grips on the spring and re-connect it. hope this helps
Oct 07, 2009 | Garden
Noise, idler pully rubbing against middle blade
Unless there is some other means of placing tension on the deck belt, I would say that the idler pulley does. If the idler pulley is on a pivot arm, there is a spring that typically is attached to the pivot arm, near the pulley, that attaches to a post or some other part of the deck, that creates the tension on the belt. Check the belt for proper tension.
Aug 01, 2009 | John Deere Garden
Garden Logo
78 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
