Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Lsq7030lq whirlpool washerf capacity - Whirlpool Ultimate Care II LSQ9564J Top Load Washer
2 Suggested Answers
  • 85 Answers
SOURCE: whirlpool washer does not spin dry clothes
It doesn't spin If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Posted on Mar 02, 2009
Need to know how many cubic feet my frig is so I can compare when shopping for another.
This is the information I could find.
Refrigerator Type Side-by-Side Total Capacity Cu. Ft. 21.7 Cu. Ft. Refrigerator Capacity Cu. Ft. 14.40 Cu. Ft. Freezer Capacity Cu. Ft. 7.30 Cu. Ft. Energy StarĀ® Qualified Yes
for more information try this link.
Whirlpool Appliances for the Home Kitchen and Laundry Room
Bob
Mar 16, 2015 | Whirlpool Refrigerators
What is the rated capacity for a Whirlpool Duet Sport Washing Model WFW8300SW02 Type 831
Capacity = 3.3 Cu Ft
Whirlpoolcorp.com download manual:
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=WFW8300SW0&siteCd=WHRCOM&userType=Consumer#
The breakdown for Whirlpool Serial Numbers is:
1st Alpha Character = Manufacturing Division Code.
2nd Alpha Character = Year Manufactured (See Tables).
1st and 2nd Digit = Week of Year Manufactured.
3rd though 7th Digit = Order of Manufacturing that Week.
http://www.electrical-forensics.com/MajorAppliances/WhirlpoolDateCodes.html
If this was helpful, please rate post
Sep 13, 2014 | Whirlpool duet Washing Machines
Whirlpool Super Capacity 465 oven won't turn on
My Whirlpool Super Capacity 465 oven
Mar 15, 2010 | Ovens
What is capacity of my whirlpool LEQ9858LW0 dryer?
try whirlpool.com should be able to find your model and info
Mar 26, 2009 | Whirlpool LEQ9858L Electric Dryer
Whirlpool duet washerf
Failure
Code
Condition
Check/Repair
F/H
No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
  • If there is no water in the unit:
    1. Make sure that both valves at the water source(s) are turned on all the way.
    2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
    3. Verify inlet valve operation
  • If there is water in the unit:
    1. Verify Drain pump operation
    2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
  • Verify there is not a siphon problem
  • Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
  • Check all hoses for possible leaks
  • Verify pressure switch operation
  • Verify flow meter operation
  • Verify CCU operational
Nov 29, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
51 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
