Question about Singer CE-200 Quantum Futura Computerized Sewing Machine
Centering the starting point
Hello all....is there a way to center the starting point?(so needle starts in center of hoop)or to move the starting point to a new one?thank you
    Problem Solver:
  • 7 Answers
Unfortunately you can't. It is imposible to move the neddle because of the machine limitation. It will only move to the starting point according to your design.
Posted on Aug 01, 2007
SOURCE:
The embroidery hoop is not moving to the right to needle position
I will need more information on what kind of machine you are using, make and model will help tons. First instinct is your embroidery arm needs to be calibrated to it's center or "home position". Some machines allow this to happen every time you are finished using the embroidery arm, it's the "storage position".
Cheers,
Embroidery Services
San Diego, CA
Sep 20, 2017 | Sewing Machines
My mb4 is stitching designs off centered and when i started the machine it hit the hoop and broke the needle. i replaced the needle but now the thread keeps breaking?
Remove the thread and rethread. Usually, thread breakage occurs when the thread is not following the thread path. However, there could be other reasons:
Sewing Machine Problem 1 Thread Breakage
Nov 14, 2016 | Sewing Machines
Ready to stitch embroidery letters but nothing happens. The start/stop button and the number 10 design on the machine blinks. What is wrong?
Make sure the machine is on a solid, level surface. Also, it may not work if you don't have the correct foot on the machine.
Mar 12, 2015 | Singer Futura Xl-400 All-In-One Sewing And...
Centering needle on Baby Lock Ellure
Make sure the needle is at its highest point. Use the flywheel/ hand wheel on the right side of the machine to move the needle.
Aug 19, 2014 | Baby Lock Ellure
My Elna 8200's needle does not allign with the starting point, how do I fis it?
it could be a sensor in the computer is not doing it's not responding to the command since the machine jammed
if turning the machine off & on again doesn't clear the problem then the
machine may have to be checked
Apr 11, 2012 | Sewing Machines
My needle goes too far right when starting up. It actually hits off the hoop and breaks. I have made the design smaller and centered but it still lines up too far to the right. I have changed the hoop...
This is common problem' is your machine under warrenty ? if so take it back to the place you got it. if not you will have to take i to a repair shop this is a computer board issue
Aug 08, 2011 | Singer CE-200 Quantum Futura Computerized...
I'm using the Mega Single Hoop for the Viking Designer SE embroidery machine, because my design is too long for any other hoop. When I try to embroider, however, I get the message "Design outside hoop...
1. If the design came from the internet or a design package, it's possible that it's "center" has not been centered properly. To correct this you need to open the design in the Husqvarna Viking software and click on the "Center in Hoop" icon. That function redefines the center of the design so it will align properly in any hoop that it fits within. If you have 3d software, after clicking on that icon you physically have to put the black crosshair that designates the center in the design, in the very middle of the hoop and then save the design to your computer, then send it to the machine. The 4d software automatically centers the design in the hoop when you click on the icon.
If you have the software and you "combine" any designs together you must always click on the center design icon to recalculate or redefine the center position and then move the design's center to the middle of the hoop before saving the design. This way you center the designs center positoin around the needle position. Meaning that when you hit the start button on the machine, where ever the needle is, is where the center of your design is.
I hope this helps
Oct 15, 2009 | Husqvarna Designer I
My needle keeps moving while I try to wind my bobbin
hi there,
the hand wheel and clutch should be disengage so that needle will not move also w/ the bobbins,doing this is hold the hand wheel then grip hold also at the center hand wheel.rotate center counter clockwise to release clutch.other type is push and pull hand wheel.any of them,try to run machine if needle is move again.cheers have a nice day don't forget to rate me.
Apr 07, 2009 | Singer 7436 - INGENUITY
Pr600 shunts over on big designs
You can try to calibrate the hoops by having the machine turned off and the largest hoop and smallest hoop ready hold down the start/stop button and the needle theader button and turn the machine on while holding those in, you should get a different screen that say a/d test in the upper left corner, put the largest hoop on the machine being shure the screws are tight and hit the l button on the upper right side the numbers next to the button will change, then put the smallest hoop on and hit the ss button once the thats done turn off the machine and on again and it will start normally and try your designs again if that doesnt work take it to a brother service center/ dealer and tell them to check your x-axis position
Mar 18, 2009 | Sewing Machines
Needle sticking on hoop
When you switch the machine on with the embroidery unit on, it is suppose to calibrate itself and move the bottom left position. If not, the problem lies with the embroidery unit. If the machine is still under warranty your dealer should fix it free of charge.
Jan 17, 2008 | Singer CE-200 Quantum Futura Computerized...
Singer CE-200 Quantum Futura Computerized Sewing Machine Logo
85 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
