Question about LG WD-1280FHD Front Load Washer
Dead power button
The on button does not work, therfore I can not start the machine
    Sniper:
  • 88 Answers
Most likely cause; dead main board.
A technician should check the following to confirm:
1. Check that the AC outlet has 110V
2. Check that 100V is going from the power cord to the AC filter.
3. Check that 100V is exiting the AC filter to the main board.
If all this checks out then it is definitely a bad main board that will need replaced. Hope this helps, please rate my solution.
Posted on Jan 11, 2009
  • Derrel Stratton
    Derrel Stratton Jan 11, 2009
    Sorry for my bad typing, all of the voltages should have been 110V.
Completely dead acer chromebook..working fine on battery when plugged in died
So did you unplug the power supply and try to restart it? When you plugged the power supply in did the power light come on on the power supply showing it was working? Blue light usually.
Sep 23, 2016 | Acer Computers & Internet
Push button switch does not work
Sounds like a really dead machine. You have to start at the outlet, with something to see if it's working.
If the outlet is good, are any lights or indication of power on the machine working?
If no indication of power shows, a technician needs to open the machine to see what's wrong.
Nov 27, 2013 | Electrolux Washing Machines
Power button beeps three times. Lock button works. Nothing else works.Technician diagnosed microcomputer control board. Replaced board control 8183258. Still dead!- he never called back.......help
Try to unplug power cord for 10 minutes and plug in. If you have manual on hand, follow instruction to find error code on your machine. Please tell problems before it went dead. Thanks.
Aug 10, 2010 | Whirlpool GHW9200L Front Load Washer
Washer will not run power to the outlet but buttons do not work
Sounds like your motor controller is faulty Does your machine light up any buttons or if you have the display model, does the LCD display turn on? Is you machine completely dead, no lights no sounds? If it is first check the power point with a toaster or hairdryer just to be 100% sure it is not the power point.Now the two things that cause the machine not to power up are --1-- the motor controller is faulty or the drain pump is faulty.If you have an electrical test meter or can borrow one I can guide you throe to isolate the faulty part.Please reply for further assistance .
Jun 05, 2010 | Fisher Paykel EcoSmart GWL15
Tries to start but wont
I wonder if you may have a loose power connection,either at machine or at disconnect box,or breaker.sometimes you can have voltage,but poor amphrage when a poor connection is present therfore a motor may not be able to hold it's load.
Oct 16, 2009 | Dryers
After a power breakdown in the neigbourhood is my PCdesktop dead: it will not start. Do I have to push a button or is my pc waisted.
Check your power supply. If the power supply works but your computer does not work then yea...it's history. Next time get a surge protector.
(search google on how to test the power supply out of your machine).
Hank
Jul 28, 2009 | Computers & Internet
Dc 50 doesn't start
THE PROBLEM YOU ARE GETTING IS A BAD CONNECTION BETWEEN THE IOT-NVM RAM BOARD AND IOT-SYS BOARD (MAIN BOARD) , JUST UNPLUG IT AND PLUG IT BACK. IF DOES NOT WORK THE BATTERY WENT DEAD , YOU NEED TO REPROGRAM ALL 3 BOARDS NVM , IOT-SYS AND HALFTONE. I HAVE THE PWS STATION FOR REPROGRAMMING AND FIRMWARE UPDATES. THE P.C. BOARDS ARE LOCATED IN THE BACK OF THE MACHINE , JUST BELOW THE SCSII CONECTORS FOR THE FIERY OR SPLASH. HOPE THIS HELPS YOU. diesco_cxl@hotmail.com
Mar 15, 2009 | Xerox DocuColor 12 Printer
Changing the language
Turn on your machine. The SET tab is the fifth from the left (or second from the right). Touch that.
You now need to touch the More button, which is on the bottom row and is the button on the left hand side (there are two buttons at the bottom - More and OK).
On the next page that comes up, the LANGUAGE select button is the single orange button at the bottom of the list. The two buttons at the very bottom are once again More and OK, so go above them to the single orange button. Each time you press this, the language changes. There are quite a lot to scroll through, but keep pushing it until English comes up again.
That should fix your machine for you. No suggestions on how to fix your husband, though!
Pamsquilt
Oct 16, 2008 | Husqvarna Designer I
Dyson showing fault no 70 600 2701
hi
the support number for Dyson is 0870 600 2701
this is when the code was obtained, therfor you should have an Fxx code.
Try this:
  1. Switch off the power using the 'MAINS ON/OFF' button
  2. Press and hold the 'Temperature' button
  3. Carry out the next three steps within 3 seconds;
  4. Switch on the power
  5. Release the 'Temperature' button
  6. Press the 'Soil type' button
  7. Check that a message similar to "DIAGNOSTIC MODE 123F7F2F5V127" is displayed. If it is not, repeat from the beginning
  8. Switch off the power
  9. Switch on the power. The fault code should have cleared
Mar 07, 2008 | Washing Machines
My dryer doens't start up
Depends on if you can hear any noise when you hit the start button or turn the knob. If there is a hum or some sound then could be belt or motor problems. If there is no sound dead, then you are checking the right area, there are kill switches in different places on dryers. one is like you checked the door switch, and another may be in back when you open the cover to check. Maybe fallen out of place. These sw. are for your safety and sometimes they malfunction. Hope this help!
Aug 12, 2007 | AEG T57800 Electric Dryer
LG WD-1280FHD Front Load Washer Logo
115 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
