Question about Vtech V.Smile Pocket
V-smile quite working
V-smile will not come back on at all this is our second one and both have stopped working
  • thegreek1 Jan 12, 2009
    My Granddaughter V. Smile Pocket Learning System will not turn on. Who do we send this product back to for repairs or replacement.
Try taking off the battery cover and poking a pin in the tiny hole under the lid with a straight pin, it will reset it.
Posted on Jan 24, 2009
How can i delete the memos i recorded?
A.To ERASE
1st select the folder of deleting file(by pressing FOLDER button).
2nd press and hold " ERASE" button,
3rd within 10 second select the item you want to erase by rotating "PLAY/STOP SEL" wheel,
4th within 10 second press "ERASE" button. selected item is erased.
if this method will not work, then , the item is locked. To remove the lock folow below step B
B.TO UNLOCK
1st select the folder containg the item ( by pressing FOLDER button)
2nd press MODE button until " LOCK" or " UNLOCK" flashes
3rd within 10 seconds select the item by turning "PLAY/STOP SEL" wheel
4th within 10 seconds press the same " PLAY/STOP SEL ' wheel
item will unlock
then for deleting folow method A
below link is user manual
user manual panasonic RR-QR240
best of luck keep smiling
Jan 14, 2011 | Panasonic RR-QR240 Handheld Digital Voice...
It just stopped working one day. We put new
ur best bet would be call the company who sold it to u and ask them to explain why it wont work
Mar 04, 2010 | Vtech V.Smile Pocket
My childs vsmile switched on but then switched itselfs off,changed the batteries & it worked for a few seconds then switched off again & will not switch on.
Try this: press and hold the ON button for 45+ seconds WITHOUT the batteries. Then put new batteries in. It worked for me. I bought a second unit at the thrift store and thought it was broken until I tried that. Works just fine now.
Jan 06, 2010 | Vtech V.Smile TV Learning System
My daughters v. smile will not turn on
The ac adaptor has to be set to the correct voltage , there should be a small adjuster on the mains plug.
1.5v for each battery ( regardless of battery size ); so 6v for a 4 battery , 9v for 6 battery , etc.
Oct 15, 2009 | Vtech V.Smile TV Learning System (Pink)
V-smile stopped turning on
unplug everything take out the batteries and hold down the reset butten in back and if that does'nt work call v.tech help line at this number 1-800-521-2010. hope this helps
Jul 30, 2009 | Vtech V.Smile Adapter
Various Smartridges stopped working
You may need to inspect the inside of the cartridge slot for dust/dirt - swab it with a tiny amount of cleaning alcohol and see if you get better results.
Jan 03, 2009 | Vtech V.Smile TV Learning System
My V.Smile powers on for a split second then goes blank no power
I has the same problem. I went to Walmart and baught the power plug for it for $10 and now I have no problems with it. So we can don't have to use batteries anymore. I totally recommend it.
Dec 26, 2008 | Vtech V.Smile TV Learning System
Dropping out of drive when stopping.
This is not a common problem, but It seemed to find you. (Smile) This is not a serious problem, Look under your floorboard, do you have gears or cable? and i'm assuming your car is dated 2002 or before. Listen, it doesn;t matter, you need two people, One Under, One Upper. (Smile)
Dec 10, 2008 | 1998 Mercury Sable
V-smile crashed
Our daughter got one last christmas, after 6 months or so, it has stopped working. It was a present from grandama and I don't think it has a warranty, certainly no receipt can be found. It's very dissapointing and I have heard from other parents who bought this V-Smile that theirs just stopped working too for no reason. We thought it was the batteries, so kept buying more, then we got the adaptor, still won't work. Now and then it works, but not often.
Jun 11, 2008 | Vtech V.Smile Adapter
V SMILE NOT WORKING
There is a defect in there line of manfacture alot of there v smiles had to be sent back . there is no way of fixing them it will have to be repalced and not promissing it will fix the problem as it will probably happen again as there line is faulty i would box it back up return it back to the shop with your docket and get a refund and buy your daughter some thing else.
Jun 10, 2008 | Vtech V.Smile Adapter
Vtech V.Smile Pocket Logo
304 people viewed this question
Top Vtech Toys Experts
Stephan Reichert
Stephan Reichert
Are you a Vtech Toy Expert? Answer questions, earn points and help others
