Question about Canon Pixma iP6600D InkJet Photo Printer
Photo printing quality is poor
The printer has been tested, and everything tested fine. When we go to print a picture, vertical lines form down the matted paper.
    Problem Solver:
  • 18 Answers
Dont mix colored with photo. we had the same problem and i bought black and color and it worked fine after that
Posted on Jan 11, 2009
When I print on regular paper, the color prints look fine. When I print on photo paper, I get a consistent quarter-inch vertical orange line on the prints and the colors look washed out. Time for new...
Hi
Basics first (which you may have already considered).
Explore the Canon Printer software settings.
You need to adjust the Printing Preferences when switching from paper printing to photo paper printing.
Also look at the Print quality and colour saturation settings and try to print in Fine or High Quality when printing on photo paper
If none of the solve the problem, check if something is not stuck in the paper input tray and pressing the photo paper to close agasinst the scanner.
Make sure the paper is properly centered and cradled with the addjusble paper guide on the In Tray.
If tall new none of this works, install new cartridges and conduct Nozzle Check and Print Head Cleaning maintenance and then test print again.
I hope this helps.
Aug 24, 2011 | Canon PIXMA MP510 All-In-One InkJet...
Poor photo printing quality with new color cartridge
Shaking these cartridges does nothing except give you a little exercise. If this is a brand new HP cartridge you are having problems with I would return it to the store you purchased it from. HP brand cartridges should not give you these problems right out of the box. The print defects you are seeing are due to a dried up or clogged print head. If you like you can try hydrating the print head on a water soaked paper towel until the ink starts flowing, but there's a risk you will cross contaminate the colors.
Oct 08, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Epson r300 - banding problems on print out
Nozzle check is fine? I am not sure. Check again. There is transverse and vertical lines. Is it perfect? Turn off printer, move head to center, put wet tissue with hot water at head cleaning mech. (pad). move head to parking position, wait for 15 minutes, repeat for 3 times. Check nozzle.
Jun 11, 2009 | Epson Stylus Photo R300 InkJet Printer
Vertical and horizontal lines when printing photos - HP Photosmar
it sounds as if you may have the picture quality set to draft, its worth a check, especially if printing is ok. Does it print colour writing well too or just black, one of the colour inks may have a block or be low, go into printer settings menu and check what print quality its set for.
Apr 25, 2009 | Canon PIXMA MP780 All-In-One InkJet...
When I print photos, they have uniform vertical streaks.
Issue: Banded or streaked prints
Solution: Change the Print Quality Settings (Windows)
Change the Print Quality Settings (Windows) The Quality setting controls how finely ink droplets are placed on the printed page. Depending on the type of paper being used a higher Print Quality setting does not always insure a better print. Print speed will decrease as the Print Quality setting is increased. Follow the instructions below to change the print quality settings in the Canon printer driver for the Windows operating system through a printing application.
  1. Click 'Properties' in the Print dialog box.
    Note: Depending on the Application software, 'Properties' may be displayed as 'Preferences'.
  2. Set the desired print quality in the 'Print Quality' section.
  3. Select 'High', 'Standard', or 'Draft / Fast'.
To set more detailed print quality settings, follow this procedure:
  1. Select 'Custom' and click 'Set'.
  2. In the Set Print Quality dialog drag the slide bar from 'Fast' to 'Fine' to select the print quality.
    Note: There are five options in 'Quality'. However, selectable options are limited depending on the media type.
  3. Select 'Auto', 'Dither', or 'Diffusion' from the 'Halftoning' section.
Apr 22, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
I have an HP 6180 that works fine except the colors are WAY off -- everything is muted and dull and the blacks are very weak. I've tried everything in the print dialogue box -- switching to application...
Bugger! HP wants your printer to work, so you buy more ink! Mine works beautiful
Scan a good photo and print it out or insert SD card and print photo on PHOTO paper GLOSSY SIDE DOWN Inkypete
Apr 09, 2009 | HP Photosmart C6180 All-In-One InkJet...
Vertical lines through my text and photos
Either clean the print head nozzles or select a higher print quality and turn off High Speed mode.
Jan 04, 2009 | Epson Stylus Photo R300 InkJet Printer
Verticlel lines appear when colorprinting photos
There may be multiple reasons why your pictures and printed pages have unexpected vertical or horizontal lines. To resolve this problem,
http://www.kodak.com/global/en/service/repair/troubleshooting/aio-troubleshooting.jhtml?pq-path=10355
Within the Link, select Print quality, then Unexpected vertical or horizontal lines (banding).
Nov 11, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Canon Pixma iP6600D InkJet Photo Printer Logo
110 people viewed this question
old marine
old marine
