Question about Sega Dreamcast Console
Dreamcast powers on blackscreen after logo - Sega Dreamcast Console
My dreamcast will power on for a moment that shuts off.
Sounds like your dreamcast is getting cut of from its power, the dreamcast sometimes gets a build of of dirt around the power connector pins that supplies the entire unit with power, try this youtube guide here for cleaning http://www.youtube.com/watch?v=3rizeLEQyzs&feature=related you don't need to do the bending section of the pins. just clean them and the actually plastic socket section where the pins go in.
Regards,
Omeil
Dec 25, 2010 | Sega Dreamcast Console
Dreamcast shows logo then goes blank
Definately the DC. Try ensuring that the connections are properly made first, and if that fails, try wiping the laser lens (very carefully) and the disc with a smooth cloth.
Jul 18, 2009 | Video Game Consoles & Games
Dreamcast wont read games more detailed problem
you need to replace the hdd[hard drive]
Jun 20, 2009 | Sega Dreamcast Console
My dreamcast power wont come on
Be sure to check that your power outlet is supplying enough power by plugging in another game console or even something like a DVD player into the same outlet.
Also try finding another power cable and try that.
Cables can be worn out through time and cable failure can be common.
Dreamcast power cables are a standard type and can be found on other machines like boom boxs, DVD players or simply sold as generic replcament power cables.
If your outlet works fine for other machines and the Dreamcast continues this problem with other power cables then it is safe to assume that the power unit in the dreamcast is damaged somehow.
In most cases this would warrent a replacment.
Used Dreamcasts are cheap and not hard to find.
I do not suggest salvaging another power unit from another machine as this can be harder than its worth overall.
Feb 22, 2009 | Sega Video Game Consoles & Games
Sega Dreamcast console problem
First off, NEVER store a game console on top of a subwoofer. It is like a giant magnet, and electronic devices do not handle magnetics. I don't think i've ever heard of a VGA box, Sega brand or not, killing a console. Millions use aftermarket AV cables and adaptors on all consoles without problem. I think it likely died from being on top of the sub. Relocate it and you should be fine. Running it for a few hours isnt likely either unless you had the vents entirely blocked.
To the guest who's drive isnt spinning, I would say your drive motor has burnt out. This doesn't indicate a defect in Dreamcasts, per se, it just means bad luck or excessive dust which killed it. Either buy a different Dreamcast or see if you can find a drive replacement.
Hope this helps.
Feb 28, 2008 | Sega Dreamcast Console
Dreamcast Loading problem
you can get disks relayered at game stores.
there was a long period where this happened to me.
some games worked for a while, some didnt.
its the dreamcast.
you might wanna get anew power cable or just clear out the dust because that is the main problem with the dreamcast.
try playing with the console upside down
it sounds crazy but it worked for me.
Dec 18, 2007 | Sega Dreamcast Console
Black Screen On Start Up!
Please post pictures, and where did it fall out from, and did you put a game in and the turn it on? Maybe it could be the main board being faulty, and might be fried. Please add more details.
Nov 01, 2007 | Sega Dreamcast Console
Will not continue to play
Have you tried cleaning the disc or laser "or both"?
Oct 12, 2007 | Sega Dreamcast Console
Dreamcast Randomly Resetting
this the best solution it work for me
Jun 11, 2007 | Sega Dreamcast Console
Console powers up but no picture on screen
try this link sir! http://www.sega.com/support/supportsys.php?item=support_systems_dcperipherals
Apr 05, 2007 | Sega Dreamcast Console
Sega Dreamcast Console Logo
Top Sega Video Game Consoles & Games Experts
DROPNDEAL
DROPNDEAL
Reggie brown
Are you a Sega Video Game Console and Game Expert? Answer questions, earn points and help others
