How to put an Aladdin B331 kerosene heater back together
2 Suggested Answers
SOURCE: I TOOK ME KEROSENE HEATER MODEL (2304)
The link below will take you to the manual for your heater.
http://www.yourheater.com/DH-2304(Eng).pdf
Posted on Feb 28, 2009
I am looking for a Owners Manuel for my Aladdin Kerosene Heater c581u
http://www.milesstair.com/Tropic_Owner%27s_Manual.pdf
Mar 15, 2015 | Heating & Cooling
Where are the filters on a Handy master forced air heater- our smells very bad
Pretty much every kerosene heater I've seen has the filters in the same place. You have to take the cover off, then locate the pump at the back of the motor. Take 2 or 4 screws out of the pump to remove the pump cover, and you'll see the filters in there.
There are some kind of generic directions here: http://www.desatech.com/techDocs/Kerosene%20Heater%20Filter%20Replacement.pdf
I'm sure they apply to your heater too.
Be careful putting it back together, it's reeeeally easy to crack the plastic pump by overtightening the screws, and it will never work right again if you do.
Dec 31, 2010 | Master Heaters Master B115DT 115,000BTU...
I have a all pro R60A that turns on but shuts right off and blows tons of smoke out after shutting off.
These heaters have several things that happen to them while in storage. I do a yearly check on mine and it goes like this. Open the fuel tank and tilt the heater to see fuel at the filler hole, look at the fuel and tank you are looking for any water in the tank. Condensation is usually the culprit, what I do is drain the tank in to a clean five gallon bucket and the fuel floats on top of the water. If you see water use a rag and try to dry out the tank as best as you can. You can also siphon off the fuel for reuse just be careful not to siphon to much and get the water again. Next remove the top section of the heater tube, this exposes all of the internal burner parts. Locate the burner tray and remove it so you can access the fuel nozzle. Remove the nozzle, they say you cannot clean these but I say different. You need a Q-tip, tooth pick and carb cleaner and clean it up carefully so you do not damage the nozzle. Behind the nozzle is a screen these like to corrode so clean it real good too. Put the nozzle assembly back together, inspect your fuel lines for cracks, dry rot or holes and replace if necessary. At the bottom of the assembly there is a sensor for flame these collect carbon deposits,dirt and the occasional homeless insect. Clean this with windex and a soft terry cloth rag. Put the burner tray back together. Trace the fuel lines back to where they come thru the heater tube and now remove the side cover. You will find the fuel line and an in line filter remove the filter and clean this with a compressor and blow gun by blowing air backwards thru the filter. This instantly cleans the filter, now put it back together after inspecting the fuel lines,and replacing it if necessary. Put the side cover back on and go to the fuel/ air pump on the back of this there should be an air filter usually foam, clean this with dawn dish soap and dry really good before putting it back in.Inspect and clean igniter while you are inside the heater, then put the top section back together. Now you are ready to plug your heater back in and test it. If all went well you should be heating like it did when it was new. Just a tip for you is to look at the fuel coming out the nozzle it should be a fog not droplets, if droplets your nozzle needs changed. Pay attention to spray angle and GPH rating very very important.
Dec 29, 2010 | All-Pro Kerosene Garage Shop Heaters - All...
Pump put together wrong
Here is a link to the owners manual included is a parts list... http://12.153.20.74/manuals/123919-01A.PDF. If you need a part you may want to try www.masterparts.net. They seem to be the only guys who have any.
Hope this help ...
Mar 05, 2009 | All-Pro Kerosene Garage Shop Heaters - All...
Pro-Temp forced air kerosene heater
my heater had a filter made out of copper that looked like a bubble stone for a fish tank. I forced compressed air through it and put it back together and it worked great
Jan 15, 2009 | Heating & Cooling
R155 and unburnt Kerosene
Check plug gap and depth of the tip. The spark may be to far into the fuel spray flooding it out. DESA says use a standard spark plug washer or two for shims if needed.
Jan 30, 2008 | Reddy R155D Utility Heater
Heating & Cooling Logo
113 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
