Question about AOC Computers & Internet
E2752vm the vga will work but when I try to connect my hdmi for my inspiron 1525 dell laptop to the hdmi port on my monitor i get no signal
  • 22 Answers
Did you tell the laptop that you wanted to use the external monitor instead or in addition to the built-in display? There's a hot-key sequence you have to hit to engage the external display. In addition you may need to update the drivers for the HDMI. Some computers you can right-click on the desktop and select "Graphics Properties" and tell Windows which display port to use. Basically it sounds like a configuration issue where you're going to have to figure out how to tell Windows to use the HDMI port.
Posted on Dec 01, 2012
  • 108 Answers
SOURCE: I hooked up my new acer p191w to my dell laptop 1525.HELP!
Not sure what the problem is, but I would suggest pressing the Fn+F5? There is a function key that toggles from dual screen, just the laptop screen or just the monitor. Hope that helps..
G'luck
Posted on Nov 11, 2008
tomhar
  • 20 Answers
SOURCE: How can I make fonts look good in an LCD monitor ?
The VGA connection should be fine; I have DVI and when I switched from analog, the difference was pretty minimal, to my eyes.
Is it just the fonts that are blurry, or everything? If fonts only, then this almost certainly suggests that running the ClearType tuner again would solve the problem. But this applies to all displays, so if one is good and the other is not, then this isn't it.
If everything is a little blurry, then this suggests one of two problems -- the first, you report trying, which is that the display adapter is set to a different resolution than the native resolution of the LCD monitor itself. Your display adapter should probably be able to drive 2 monitors (the built-in laptop monitor and the external monitor) at once. You should be able to set their resolutions separately.
Assuming Windows XP: Start > Control Panel > Display > Settings > at which point, you should see two monitors listed in a dropdown. Set them to their native resolutions there (using the slider bar, usually all the way to the right), and save.
If you do have the display resolutions set to their native resolutions for both monitors, then it's possible that your external monitor is messed up. A quick test would be to run the on-screen settings, usually from a button on the monitor itself. If what is displayed there is sharp and what is displayed from Windows is not, then this points to a problem with the display driver. If everything, even the on-screen display is blurry, then perhaps the monitor settings are messed up -- usually there's an option to restore to factory settings -- try that.
If that doesn't work, I'm probably out of ideas, unless you have further information.
Posted on Mar 08, 2009
skotkolr
  • 558 Answers
SOURCE: I only get power saving mode on my screen then screen goes black
inside the power pack is a pulse IC chip they fail and cause all kinds of havoc also caps can cause issues unaccounted for, I would start at replacement of the IC about 2 dollars on E bay, and replace any bad capacitors you can see, they look domed or are leaking color from the top creases. after that get back with me and we can either proceed or you can rate me fixya, have a great weekend
Posted on Apr 05, 2009
michael_grey
  • 365 Answers
SOURCE: Nothing on the screen at startup
If you cant get into the setup menu then I would think the monitor is defective,you did not state if you hooked up the monitor to a computer that has a vga port that works.
Posted on Jul 21, 2009
budmrtn
  • 11361 Answers
SOURCE: I have a Dell 2208WFP Monitor. When it poweres up
The problem can be the lamp assemblies also, it will be hard to verify unless you have test lamps to find out if it is the lamps or the inverter problem, that is one of the first thing I check first if the board has no sign of damage. I save a lot of lamp assemblies for testing purpose.
http://s807.photobucket.com/albums/yy352/budm/Inverter%20test%20lamps/
http://s807.photobucket.com/albums/yy352/budm/Bad%20backlight%20lamp/
Inverter tester: http://lcdparts.net/IT01.aspx
Posted on May 11, 2010
I need to connect a VGA dell monitor my Toshiba Laptop
HDMI is digital
VGA (the 15 pin connector) is analog.
If your connector has the digital to analog interface it should work, but likely it does not have that chip and thus will not work.
Your description of the problem tells me it may never work as you have it connected. Possibly it might be that the monitor is required to be powered on before the laptop is booted, but that only works in some cases.
I have also seen some work if a 2-step connector is used.
VGA to DVI connector, followed by DVI to HDMI connector.
DVI was the step toward digital that came before the HDMI standard was implemented and was only partially digital. DVI and VGA do not carry control signals nor audio. HDMI carries both those as well as the video.
YMMV but I think it would be cheaper and more efficient to actually purchase a monitor with a digital input (HDMI or DVI).
Without the digital/analog converter interface a digital output device (your laptop with HDMI out) can never operate an analog device (your Dell monitor with VGA input).
Mar 12, 2017 | Dell E193FPp 19" TFT LCD Flat Panel...
Suddenly lost Laptop to Mitsubishi 60c9 connection using HDMI
never plug in hdmi when comp.is on you may burn your hdmi port
Aug 03, 2012 | Mitsubishi WD-60C9 60" DLP HDTV
How can i connect my dell inspiron 640m laptop to my sony bravia lcd tv?
Your tv should have vga port. if not you can buy a vga to hdmi adapter
Feb 19, 2012 | Sony Televison & Video
I Have a Dell Inspiron 1525 and tried to add a 21.5" Dell Monitor. The color on the monitor was purplish, and even talking with the service techs, couldn't resolve the problem. They sent a second...
Your laptop's video circuit is integrated into the system board (motherboard). There is no VGA card. Try using a different VGA cable, if no go, then your motherboard has a problem.
May 20, 2011 | Dell Inspiron 1525 Notebook
I want to connect my dell inspiron 1525 to my lcd hd ready tv but have no idea how to? Does anyone have any advice?
The 1525has a a hdmi port which you can plug a hdmi cord into. This may not support the audio. the tv and pc should detect the new monitor automatically or you may have to toggle it by hitting F4 key.
Apr 22, 2011 | Dell Computers & Internet
In my dell inspiron 1525 laptop function key not working and i want to attached LCD TV with this. so how can i enable function key
only if your Fn key is not working then may be its not a hardware but a software problem. then you just have to replace the keyboard.
And to connect your LCD, you just need a VGA cabel or HDMI cabel. this laptop has got both the port use either of them to connect your LCD.
Dec 31, 2010 | Dell Inspiron 1525 Notebook
Connect Dell Mini with HDMI to VGA PC flat monitor
hi,
you would need an HDMI to VGA adapter. sometimes it would come in a form of a separate cable or just a regular adapter which would convert the HDMI end to VGA (the blue one that has 15 pins)
you can purchase these cables from your local computer store.
hope this helps
Jul 12, 2010 | Dell Inspiron Mini 10 Notebook
Connecting dell mini inspiron with LCD with HDMI cable on both si
You just need a HDMI cable to go from the laptop to the TV. It is refered to as a patch cable. You then go into the TV menu and set it to component or in some cases it will say computer. The VGA on the TV just allows both style interfaces to be connected.
Jun 20, 2010 | Dell Inspiron Mini 10 Notebook
How can i plug the hdmi cord to my dell inspiron 1525 laptop
There is a hdmi port on the left hand side of your dell laptop. Get a hdmi cord and plug it in.
Thats It!
Mar 22, 2010 | Dell Inspiron 1525 Laptop
Cannot link from my laptop to hdtv via hdmi cable
1. have you connected whilst tv and laptop r switched off.
2. have you set your display setting for secondary monitor
3. also need to send signal to tv by pressing fn key and f5,f6, or f7 depending on laptop model.
hope this helps
Feb 13, 2009 | Olevia LT27HVX 27 in. LCD Television
Computers & Internet Logo
225 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
