Blower on our house heater will not shut off
The blower on our gas heater turns on when we plug it in but does not shut off at all until we unplug the unit. Is there anything I can do to fix it or does the control need to be replaced.
thanks,
Steve
  • 3 Answers
Check the limit switch.most look like box with a switch or button.Next to the switch or button it will say auto - on .The button style will run the fan if the button is pulled out.Common problem is the button breaks fans stays on all the time.
Unplug the unit before replacement, fairly straightforward repair, if you question your ability call a professional, as this is a safety device.
Posted on Jan 11, 2009
Bradford-white water heater wont heat water.the blower motor hums but wont blow.also,pilot light wont light,is this just a safety feature?
Water heater is not identified and gas valve is not known.
Review options below:
1) Add a comment and describe what gas control valve is on the water heater, and model number from label on side of unit. Include what you have tried so far.
2) Try unplugging water heater and see if water heater resets.
Disconnect blower from gas valve, then plug blower in to see it it operates.
This will eliminate or include blower as suspect.
3) Open following link to download service and product manuals to help troubleshoot exact model.
http://www.bradfordwhite.com/documentation/residential/gas.asp
4) Open following link to identify gas valve.
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html#intelli
Oct 04, 2011 | Fasco Bradford White Hot Water Heater...
How to change blower motor in. 99 grand Cherokee
Check this procedure...Blower Motor Resistor and Controller Replacement
REMOVAL
1. Disconnect and isolate the batten' negative cable.
2. Depress locking tab and unplug the wire harness connector from the blower motor
resistor or controller (power module).
3. Depress locking tab and unplug the resistor or controller connector from the blower
motor.
4. Remove the 2 screws that secure the blower motor resistor or controller to the
heater-AC housing.
5. Remove the blower motor resistor or controller from the heater AC housing.
INSTALLATION
1. Install the blower motor resistor or controller to the heater AC housing. The
housing is indexed to allow (controller power module) mounting in only one
position. Tighten the mounting screws to 2.2 Nm(20 in. Lbs.).
2. Plug in the wire harness connector to the blower motor resistor or controller.
3. Plug in the connector from the blower motor resistor or controller to the blower
motor.
4. Connect the batten' negative cable.
Hope this helps (rerember to rating this and leave a testiomonial).
Sep 30, 2011 | 1999 Jeep Grand Cherokee
Have model MD300TGA with blower.Blower is set on auto but doesnt kick on.When should blower start up after room has reached desired temp. and heater has shut off?
There should be a limit switch and once the heater reaches the set temperature the blower gets signal from the limit and that turns on the blower. If you are not getting the blower until after the room is up to temp then it is coming on it may be the low limit is bad and it is cooling itself down on the high limit. If you are unsure of this please consult a heating service person, this is a serious problem that a trained service person should deal with. This can lead to a house fire!
Dec 10, 2010 | Procom Heating & Cooling
How do i change blower motor resistor on 99 jeep grand cherokee
Welcome to FIxYa.com
Image Blower Motor Resistor Or Controller/Power Module Remove/Install
REMOVAL
motor.
heater-AC housing.
INSTALLATION
motor.
Thank you for using FixYa.com
Regards, Lee Davidian
Nov 22, 2010 | 1999 Jeep Grand Cherokee
Blower motor resistor, where is it located/
It will be up under the dash on the passenger side near the blower motor. It will have 5 or six wires in its connector
Nov 10, 2010 | 2000 Jeep Grand Cherokee
How do you change a heater blower moter in a 1998 Dodge grand caravan
Removal & Installation
The blower motor is located behind the glovebox, behind the blower motor cover
  1. Disconnect and isolate the negative battery cable, then wait 2 minutes before proceeding with the removal. This will effectively disable the air bag system preventing possible personal injury.
  2. Remove the glove box from the instrument panel.
  3. Remove the A/C-heater blower motor cover.
  4. Disconnect the blower motor wiring connector.
  5. Remove the blower motor wiring grommet and feed the wiring through the blower motor housing.
  6. Remove the blower motor mounting screws.
Once the cover is removed, unplug the electrical connector and push it through the opening in the housing
The blower motor is secured to the housing with three small screws
  1. Allow the blower motor assembly to drop downward to clear the instrument panel and remove from vehicle.
To install:
  1. Place the blower motor assembly into position on the A/C-heater unit and tighten the mounting screws.
  2. Route the blower motor wiring through the blower motor housing and seat the wiring grommet in the hole of the blower motor housing.
  3. Reconnect the blower motor electrical connector.
  4. Install the A/C-heater blower motor cover.
  5. Install the glove box into the instrument panel.
  6. Reconnect the negative battery cable. Check blower motor operation.
May 24, 2010 | 1998 Dodge Caravan
Spa heater will not ignite. Shows "AO" code.
You need to check and see if you have enough gas supply to run the heater. Older heaters would run on a small gas supply but forced draft are hinkey about how much gas they get. Sometimes this is a gas line size problem but more often than not it will be a gas meter problem. On the face plate of your meter their is a number that tells the size. With a 250 and other appliences in the house you will want a 350 or bigger. The good news is the gas company will upsize this for nothing. If they are supplying more gas your buying more gas. It could be other things but this is the first thing to look into.
May 17, 2010 | Hayward 250kbtu Ng Pool Heater - Inground
Fireplace will not stay lit and pilot light is on
This sounds like the high temperature switch has failed and is telling the unit to shut down after it gets started, the pilot has to be lit for the main gas valve to turn on when the thermostat calls for heat, The main burner comes on and stays on until the thermostat is satisfied and tells it to shut off, you dont say if there is a blower in this unit, if there is a blower after the main flame comes on the unit heats up it turns on the blower if equiped. If the blower fails to turn on the unit would be shut down on overtemp as the firebox would get to hot and be in danger of causeing a fire. if no blower there still is an overtemp switch that shuts the unit down if it gets to hot or the switch is bad, it could be a bad overtemp switch or if equiped a bad blower motor or even a plugged chimney as this would also cause a overheat ing condition. Hope This Helps Don
Dec 01, 2009 | Napoleon 36" Zero Clearance Top/Rear Vent...
Heater Burner ignites but main blower motor will not turn on.
it sound like the blower motor may be seizing up. try spining the blade by hand to see if it feels free or not. the motor could be trying to turn but can then tripping itself out on overload. (most motors have built in safety overloads which will trip during an overcurrant event. aka too many amps.) you may have to replace blower motor
Mar 16, 2009 | Mr. Heater Natural Gas Garage Heater -...
2002 Buick Century Heater Doesn't Turn On
replace the blower motor speed control resistor 1st then the blower motor if the resistor doesn't fix the problem. Below are instructions to replace the resistor.
The blower motor resistor is located on the back of the blower motor housing under the dash on the passenger side. It can be difficult to get at, but it is doable. Be ready with the ibuprofen the next day for your sore back. Remove the cover panel from beneath the dash on the passenger side. Unplug the power 'ribbon' wires leading to the resitor. Unplug the wires that lead from the resitor to the blower motor housing. There are usually two, one black and one purple that share the same plug. Remove the short hose that leads from the blower motor housing to the ventilation system ducts. Remove the blower motor by removing the three hex screws that hold it in place. Remove the resistor by removing the three hex screws that hold it in place. The resistor is right against the firewall so two of the screws are very difficult to reach. A slender flexible socket extension will make the job easier. Attach the new resistor in place using the same hex screws. Only 1 or 2 of the original three are needed (the part is very light) if you do not feel like fighting with the ones next to the firewall. Reatach the blower motor and reconnect the hose. Plug the power cable wires back into the resitor and the wire from the resistor back into the blower motor.
Feb 06, 2009 | 2002 Buick Century
Heating & Cooling Logo
70 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
