Question about Radio Shack Pro-2096 Base Scanner
Back light works but no read out pro-2096 - Radio Shack Pro-2096 Base Scanner
3 Suggested Answers
TOLhamRadio
  • 509 Answers
SOURCE: I HAVE A PRO-2096 DIGITAL TRUNKING BASE SCANNER.
need to do a RESET. Then try your local WX frequency to verify it works. The RESET will wipe out all existing programming, just to warn you. Check your manual, or RadioShack.com for details.
Posted on Jan 16, 2010
BillB-SA
  • 2761 Answers
SOURCE: my pro-2096 does not display any letters or
If all else fails, you can RESET or INITIALIZE the scanner to bring it back to normal operation.
To RESET:
- Power the scanner OFF
- Power the scanner back ON
- Insert a pointed object (paper clip, penpoint, etc.) into the RESET hole on the back of the scanner
- Gently press and then release the RESET button inside the hole.
NOTE: RESET will NOT erase the data that you've programmed into the scanner.
If RESET doesn't clear the problem, you can carry out the more drastic INITIALIZE process.
- Press 0 after the scanner completes its boot routine
- Press 1 after the menu appears
- Press ENT
DO NOT power the scanner OFF until the INITIALIZE process is complete (M000 and Bank 0 Ch 00 appear on the display). The INITIALIZE procedure will reset the scanner to original factory settings and erase all data that you have programmed.
BillB
Posted on Feb 14, 2010
How to re-set to original programming ?
To RESET your PRO-2096:
- Power the scanner OFF.
- Power the scanner back ON.
- Insert a pointed object (paper clip end, ballpoint tip, etc.) into the RESET opening on the back of the scanner and gently press the button inside.
If the RESET does not clear your problems you may need to INITIALIZE the scanner. Instructions for this procedure are on page 77 of the scanner operating manual. If you need a copy of the manual, you can download and print it, at no cost, here:
http://support.radioshack.com/manuals/ome20-496.pdf
Bill B.
Listening in since the 60's
Jan 25, 2011 | Radio Shack Pro-2096 Base Scanner
Pro-2096 Digital trunking mobile/ base scanner
hello,
Open the mobile and the refix all the connection inside maybe some loss connection make it faulty.
best ,
melnavz
Apr 29, 2008 | Radio Shack Pro-2096 Base Scanner
Pro-2096 have static no talk
Hi dh, my name is John. Welcome to FixYa. Turn the SQUELCH until the static stops, then press the SCAN button. Thanks for choosing FixYa....John
Dec 05, 2010 | Radio Shack Pro-2096 Base Scanner
I need help with programming my Pro 2096 scanner
You can get the manual on the link below. Starting on page 56 tells you how to program.
Good luck
Nov 30, 2010 | Radio Shack Pro-2096 Base Scanner
MY PR0-2096 READS ALL CHANNELS LOCKED OUT TRIED MANY THINGS AND NOTHING WORKS PLEAE HELP ME. ITS BEEN LIKE THIS FOR NEARLY 2 YEARS
If all else fails, I suggest that you RESET or INITIALIZE the scanner to return it to original factory settings. These procedures are outlined on page 71 of your owner's manual. Need the manual? You can download and print it, at no cost, here:
Bill B.
Oct 27, 2010 | Radio Shack Pro-2096 Base Scanner
Unlock code all frequencies for pro 2096 digital scanner
Sorry, but there is no magic code that will "unlock" your Pro-2096 or any other modern scanner. If you want a scanner with wider frequency coverage, you'll need to purchase one that comes that way from the factory.
Bill B.
Oct 07, 2010 | Radio Shack Pro-2096 Base Scanner
Display keeps going out of the pro 2096, it was repaired once,,,, is there any simple fixes to this?
Unfortunately there is not. This is one of the "gremlins" that plagued the 2096. From what I have been told by other 2096 owners, the problem comes from a fault where the ribbon cable (or flex) joins to the LCD display. You may want to try opening the scanner and checking the connection. Sometimes gently pressing on the joint with a pencil eraser can re-establish the connection.
Sorry I don't have a "quick fix" for you, but hopefully this will help steer you in the right direction for troubleshooting.
Feb 22, 2010 | Radio Shack Pro-2096 Base Scanner
My pro-2096 does not display any letters or
To RESET:
- Press ENT
BillB
Jan 22, 2010 | Radio Shack Pro-2096 Base Scanner
I HAVE A PRO-2096 DIGITAL TRUNKING BASE SCANNER. IT HAS WORKED FINE BUT NOW IT READS " ALL CHANNELS LOCKED OUT " NEED HELP
Jan 12, 2010 | Radio Shack Pro-2096 Base Scanner
This is happing to most of the units and radioshack wont admit it.
Apr 18, 2008 | Radio Shack Pro-2096 Base Scanner
Radio Shack Pro-2096 Base Scanner Logo
43 people viewed this question
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
