Question about Samsung 225BW Monitor
I have a Samsung 225BW. It turns on very dim then goes black. I know it's the backlight because I can see the screen if I shine a flashlight across the display. What do I need to repair it?
  • SoCal_Scorpio Dec 01, 2012
    @Buddy Mcsaprrin You were correct. I pulled the monitor apart and 3 of the 5 Capacitors were blown.. Easy fix. Thank You.. I will be ordering them from your link.
  • 119 Answers
SOURCE: dim lcd screen samsung 732n
sorry its a defective unit
Posted on Oct 20, 2009
  • 1684 Answers
SOURCE: After you turned it on and the screen blacked out
It sounds like you just have a bad backlight power supply. Go to our web site at: www.ccl-la.com We have repair guides for many models of LCD monitors and the 204B guide should also work for your unit.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Posted on Nov 14, 2009
  • 732 Answers
SOURCE: Prior to this past week my Samsung SyncMaster
kmzwolski, NO, NO, NO!!!! Do NOT wait. Use your warranty NOW!!! Do not let them off the hook. Could be any of the things you mentioned, plus "cold", intermittant solder joint, thermally/vibration fracture of solder joint on printed circuit board (SMPS/inverter circuit) Let me know how you fair with SAMSUNG. lmistyrel on aim.com or 12fixlouie on fixya.
Posted on Dec 17, 2009
Testimonial: "Thanks for the advice. I wasn't sure if I had to wait for the monitor to fail completely. I called Samsung to get the process going."
  • 1684 Answers
SOURCE: I bought monitor in 2006 up until now the screen
You should be able to repair the backlight power supply. That model monitor uses 2 different versions of the power supply. If you can open the unit and take a few pictures of the power supply and send them to us at:
tech@ccl-la.com also include any model numbers from the power supply. We will cross reference the board and get right back with you about what you need to do for the repair.You can also check out our web site at: www.ccl-la.com. If you need parts we carry them in stock.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Dec 31, 2009
  • 5 Answers
SOURCE: samsung B931 black screen, but blue lights turn on
This problem may be caused by defective capacitors on the power board. This fix requires techical skills and should not be attempted by anyone not familiar with such work. If you still want to attempt it, here are some instructions. You will need soldering skills and equipment. 1. Remove the back half of the case. It does not connect to anything inside the monitor, so it can be removed completely. Remove the pedestal by unscrewing the wing-screw on the bottom, This allows good access to the slots on the bottom of the case between the two halves. Use a screwdriver about the same size as the 2 slost, insert and twist at each. You may want to wrap some tape around the blade to protect the plastic. Work your way around the case using a second screwdriver to keep separation. Use the corners especially because the plastic is stronger there. Remove the back. 2. Unplug all cables for the metal pcb chassis. The 4 small ones have 2 plastic covers that unsnap. 3. Lift the metal chassis and flip it over. 4. Remove the 4 screws holding the main pcb and lift the board and flip it over on top of the smaller board so you can see the capacitors. 5. Examine the caps for bulges, replace any that do not look flat on the top. Try Radio Shack for replacements. 6. Reassemble by following these steps in reverse. Note: the metal chassis is resting on but not fastened to the panel, and is restrained by tabs in the back cover, so keep that in mind while snapping the cover back on. Some photos are attached here:
Posted on Jun 03, 2010
Ideas on parts to replace?
Here's the test. With the TV on shine a flashlight on the screen. If you can see a dim picture the backlight circuits are bad. If you cannot see a picture the T-Con board is bad. You can get parts from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Oct 12, 2016 | Samsung Televison & Video
Tip
Diagnosing a LCD blank screen problem.
Recently a 3 year old VIzio TV I bought started having problems. The set would turn on normally for a few seconds then the picture would go dark with everything else operating normally including sound. Remembering a similar laptop computer problem I diagnosed previously, I immediately suspected a defective TV screen backlight. To verify this in your own TV, get a very bright flashlight and with the TV operating in the failed blank screen mode, shine the flash light into the blank screen from various angles and distance (including touching the screen). If the LCD is still operating, you'll see a dim motion in the flashlight's reflection, thus proving it is indeed a failed backlight.
on Jan 27, 2015 | Televison & Video
Samsung lcd Backlight Failure
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Oct 26, 2014 | Samsung LN40B630 40 in. LCD TV
Replaced the 4 power capacitors now tv runs for 15min. then picture turns black and volume stays on
when the picture goes black, dim the light in the room and shine a bright flashlight on the screen. If you see a faint picture, you have a backlight problem. If this issue came about after you installed the capacitors, double check the installation of your caps. Ensure that you don't have cold solder joints or broken joints!
Oct 10, 2013 | Samsung LN46A750 45.9 in. HD-Ready LCD TV
Dp32648 picture goes black, tv stays on with sound.
Dim the lights in the room, turn on the set and shine a bright flashlight on the screen. Do you see a faint picture? If you see a faint picture, you have a backlight fault. Could be several things, you could have a bad backlamp, defective inverter, defective 24vdc power supply, or a faulty main board. I would highly recommend you get a diagnosis
Apr 05, 2013 | Vizio Televison & Video
My samsung turns on, audio is okay but black screen
dim the lights in the room, turn on the set and shine a bright flashlight on the screen. Do you see a faint picture?
Mar 28, 2013 | Samsung LN52B750 52 in. LCD TV
Black screen with sound
Turn on the set, dim the lights in the room, shine a bright flashlight on the screen. If you see a faint picture, you most likely have a fault in the backlight circuit. Are you wanting to repair this yourself?
Mar 07, 2013 | Vizio VO47L 47 in. LCD TV
46 rca model 46la45rq comes on for just a second then the screen goes black and it only plays sound! what needs to be replaced
Sounds like you have a backlight problem. To verify this, turn on the set and dim the lights in the room. Take a bright flashlight and shine it on the screen. Do you see a faint picture?
Jan 14, 2013 | RCA 46 46LA45RQ LCD TV
My Samsung LN32D450 has sound no pix. it's only 1.5 years old
it could be a backlight problem. Try this, dim the lights in the room, turn the set on. Take a bright flashlight and shine it on the screen. If you see a faint image on the panel, you have a backlight fault.
Jan 10, 2013 | Samsung 32 LN32D450 32 LCD TV
Samsung 225BW Monitor Logo
73 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
