Question about Sony ICD-BX800 2 GB Digital Voice IC Recorder, ICDBX800, SY-ICD-BX800, SYICD-BX800 , SYICDBX800,ICDBX700
How do I convert a recording from my Sony ICD-BX800 Recorder to a sound file on my computer?
I have a jack that can go into my Laptop
  • 3 Answers
SOURCE: transfer recording from tape recorder to computer
Use a cable running from the headphone jack on the recorder into your PC microphone jack. Then you can capture the audio using Windows MovieMaker software that comes with Windows XP. I have done this and it worked perfectly.
Posted on Jun 10, 2008
SOURCE: problem with memory/erasing discrepancy
I did erase all from the device main menue after having copied them to my computer, that cleared the remaining files and recovered part of the memory. Then I did reformat from the same menu and recovered the entire memory! ;)
Posted on Jan 29, 2009
hasan mahmud
  • 35 Answers
SOURCE: I accidenlty erased files from Sony ICD-P320
dear sir,
sorry you can't recover it. because, it contains flash memory that's why it's not possible.
thanks
Posted on Oct 22, 2009
SOURCE: Sony ICD-UX70/UX80 digital recorder...memory full problem
If you press and hold down the "menu" button scroll down to the FORMAT selection and press enter. This will reformat the device.
I had the same problem - I think it arose after disconnecting the IC Recorder when it became unresponsive with the computer.
Make sure you transfer all your files first to a computer or back up source.
Posted on Dec 02, 2009
I solved the problem by connecting my Sony IC Recorder to the USB port on my McBook Pro computer and then emptying the trash can on the Mac computer. Visually (flashing red indicator light) and audibly (the recorder's sound that indicates something being erased), it was clear that mp3 files were finally, really being erased on the Sony recorder even though the recorder's own screen display had previously shown only empty folders and no files. Dragging files to the trash can doesn't really erase them unless you also empty the trash. All dragging to the trash can does is somehow mark the files in a way that, unfortunately, makes them invisible to Sony's file detection system.
Chuck in Omaha
Posted on Dec 19, 2009
I have a sony icd bx800 I have recordings I need to stay on there but I need to change the battery. If I change the battery will I loose those recordings once I take the old batteries out?
Nothing to worry about.
Your recorder has what is called a "Flash Memory" 2 GB I believe, which will retain whatever you recorded pretty much indefinitely.
Jun 29, 2011 | Sony ICD-B200 Digital Voice Recorder
I have a Sony ICD-BX800 IC Recorder. I have purchased and hooked up the Audio Cable to transfer the recordings to my computer (I need to email them to someone.) However, I did a test recording, and the...
Sony IC RECORDER ICD BX-800 (!without USB connection!)
What you need:
- newests audio drivers in Windows 7 (updated audio-drivers)
- audio cable 3,5 M (male) both ends M-M (male-male)
- freeware application Audacity for Windows (with LAME)
Howto step by step:
- one end of audio cable connect to dictaphon's headset (earphones) jack in recorder Sony IC RECORDER ICD BX-800
- other end of audio cable connect to PC/notebook microphone (or LINE IN)
- nothing special setup (adjust) regarding Audio in Windows 7, the device for record Audio keep Microphone (default)
- in Audacity set very little volume "Input Volume Slider" and "Output Volume Slider" (for example both 0,1)
- in Audacity like Input Device set "Input (Audio device High Definition Audio)": !Don't set in Audacity like Input Device "Microphone"!
- Audio Host: MME
- Output Device set "Speakers (Audio device)"
- Input Channels set "2 (Stereo) Input"
- Sampling (Hz) set 44100
Dec 26, 2010 | Audio Players & Recorders
I have a sony ic recorder icd-p110 but cannot download the files cause i have a mac, what can i do?
Well, I assume your computer has a Microphone plug. You can purchase or make a cable that would allow you to connect the recorder headset connector to the Computer Microphone jack and do it that way through media player.
Aug 08, 2010 | Sony ICD-P110 Handheld Digital Voice...
I have a Sony ICD-B7 Handheld Digital Voice Recorder. How do I upload to my computer?
You need an audio cable with 1/8" connection on each end. Plug intot eh earphone jack on the B7 and then to your audio in of your computer. Use a sound recording program to record it. Its primitive but works fine. AUDACITY is a free program you can use.
Apr 01, 2010 | Sony ICD-B7 Digital Voice Recorder
Transfer digital recording to computer to make CD
As there is no USB port on this IC Recorder, you can connect the Headphone OUT of the IC Recorder to the LINE IN of the Computer. Then, use any Sound Recorder Software to capture the files. You can also use the Sound Recorder Software preinstalled in the Computer. After transferring the recordings to the Computer, you can use any CD Burning Software to burn the files to a CD.
Feb 19, 2010 | Sony ICD-B5 Digital Voice Recorder
Chuck in Omaha
Apr 21, 2009 | Sony ICD-UX80 Handheld Digital...
I have a Sony ICD-SX35 recorder which my iMac will not recognize. Any clues out there???? I need to convert the dvf files into MP3 or WMA format but that can't happen before my Mac recognizes the...
I took the advice of one of your correspondents by connecting my Sony ICD-SX365 recorder to my iMac with a simple audio cable by inserting the output jack in the recorder's slot for headphones and the input jack in the iMac's slot for microphones. I used the freeware program Audacity to import the track onto the computer and Switch to convert the file to mp3.
Apr 15, 2009 | Sony ICD-P28 Digital Voice Recorder
ICD-B500 Recorder
An adapter will not fix the problem. The files cannot be transferred to a computer using a USB port. The files must be transferred analog using the recorder's headphone cord. The files are then recorded to the computer from the Sony recorder using a program such as Windows Recorder. The ICD-B500 has many great features but archiving to a computer is not one of them.
Jul 09, 2008 | Sony ICD-B7 Digital Voice Recorder
Sony IC Recorder ICD B600
To transfer recordings from the Sony ICD-B600 to Windows first buy a Radio Shack #42-2497 cable. Connect the cable from the recorder headphone jack to the computer microphone jack. In Windows XP follow the path: start, All Programs, Accessories, Entertainment, Sound Recorder. This small window will allow you to record 60 seconds of sound to a file. Get Article #82215 from the Microsoft web site. It will tell you how to make extended recordings. I was able to record 45 minutes continuously. The recorder is turned on by moving the 'HOLD' switch down. The recorder is turned off by moving the 'HOLD' switch up and waiting 2.5 seconds. Have fun.
May 08, 2008 | Sony ICD-B200 Digital Voice Recorder
Transfer recording from tape recorder to computer
Nov 28, 2007 | Sony ICD-B200 Digital Voice Recorder
Sony ICD-BX800 2 GB Digital Voice IC Recorder, ICDBX800, SY-ICD-BX800, SYICD-BX800 , SYICDBX800,ICDBX700 Logo
79 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
