My HITACHI LCD TV(32SO2A) is not turning ON.Standby led only glowing
    Top Expert:
  • Televison & ... Master
  • 75,404 Answers
The main digital board should be suspected. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to see the latest updates. It will make search easy. There are more than 1350 posts to different brand TVs now. Pull up older posts there.
Posted on Dec 01, 2012
freetek
  • 5568 Answers
SOURCE: TV & Tuner stays in Standby mode
Assuming you have tried changing batteries in your remote and any front panel power switch your set has, the main power supply is probably at fault and without some technical background and a couple of test instruments, you will not be able to do the repair yourself.  What you can do though is; unplug the set, let it stand overnight or at least several hours, remove the back panel and look for a separate board with mostly larger components on it; it will have a ferrite core transformer on it and several larger capacitors which are cylindrical and mounted vertically to the board.
Before touching anything inside, especially on that board, allow several hours to be safe since the larger capacitors can hold a painful voltage charge for some hours.
If you see signs of overheating such as discoloration of the board material, it may not be repairable but if you can find a part number on the board, you might be able to buy the power supply and install it yourself.
If there are no signs of heat damage to the board, there may be companies offering to repair it as a subassembly instead of repairing the whole set which could be much more expensive.
If you choose to replace or have it done, the power supply still may not be at fault since most are capable of switching on and off if a downstream problem is causing an overload.
Posted on Oct 29, 2008
SvenBosch
  • 3 Answers
SOURCE: my power light on hitachi lcd is flashing red and
Sadly to the end I can now explain the "problem" of my question by myself ...
Because I'm was not sure if I can handle the "problem" by myself I gave the Screen to a technican at our City with all the Information I found until this point (By the way my suspicion was the defect of something at the power supply unit). Two days later he gave me a call with the information about the error: An error at the power supply unit - spare parts => 50€, Work => 200€).
Unhappily im not yet got at soldering on screens, but for 250€ i would have made a good course for this (and if I can establish i will learn it).
So now again a bit more objectively:
Error / Problem:
TV - Step 1: Power Off
TV - Step 2: Stand-By
TV - Step 3: Power-On
TV - Step 4: Short flashing picture
TV - Step 5: Reverse to Step 1
Solution:
1. Find the defect Fuse/Safe/...
2. Buy the Spare part at eshop2.euras.com
3. Change the parts -> et voilá
Hopefully I could have been a little help for someone.
With kind regards,
NatureOneFreak
Posted on May 30, 2009
  • 3 Answers
SOURCE: dead set,flashing standby led
Have ordered new electrolytics for psu and will overhaul this when parts arrive.
Any further comments thro your site would be welcomed.
Posted on Jun 20, 2009
  • 1632 Answers
SOURCE: New Samsung LCD TV won't turn on or off
This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires. Vitally
Posted on Apr 15, 2010
budmrtn
  • 11361 Answers
SOURCE: LCD TV TYPE GOODMANS GTVL32W8HD STUCK IN STANDBY
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Posted on Jun 27, 2010
Tv will not turn on after being left on standby
capacitor wearing out on 5v side of the power board, this or these will need changing look for the tops of the capacitors blown up or leaking brown stuff around them and change them for same type ie 10v 487uf dont buy blue type they only 85c temp rating buy 105c rating.
Mar 30, 2015 | RCA Hitachi Le22s314 22" Led 1080p Full...
I have a hitachi television L32HP04U A that won't come out of standby. When switched on it the LED will light blue and then blink blue and red.
Probably you should just disable the Standby feature, though it also depends on why it's in Standby. On some TVs, it's when it's been left on and idle for a certain period of time- basically the TV will turn itself off, or go into a lower powered state. It's possible it will not come out of it because the TV could be overheated, and needs time to go back to normal. Without know the specifics as to why the Standby happens I couldn't say, and it's also hard to say what the issue is with it coming out of it.
Go into the TV Menu and find Power Options. Set Power to Normal, or Quick Start (or whatever Hitachi calls it). If this is separate from the Standby Options, then disable the Standby option on its own.
Jun 06, 2014 | Hitachi 32LD8700 32 in. LCD Television
Tda9380ps /n3/3/1664 using in sharp tv power supply ok ,but no EHT ,the power LED are glowing red light press program key to change green light to return in few miniutes to standby in red light position...
tda9380ps /n3/3/1664 using in sharp tv power supply ok ,but no EHT ,the power LED are glowing red light press program key to change green light to return in few miniutes to standby in red light
Aug 30, 2011 | Sharp 21" Multi System Stereo TV
Hitachi 42LDF30U LCD TV stuck in standby mode
Hi there mine has started doing the same thing today, on other hitachi models it is a serious fault warning, i will come back when i find out more.
Jul 07, 2010 | Hitachi Televison & Video
Hisense tv turns on and off
STOP!
The unit has a fault on its power board and sustain board.
It turns off because the sensor is preventing some component from bacoming overheated and catching fire or damaging further components. Seel professional repair.
Please rate my help++++Thanks for using FIXYA
May 13, 2010 | Hisense TL1700 17 in. LCD Television
Hitachi CLE984
The code you need is 0145
1) Switch on the TV set
2) Press the TV button on the Sky Remote
3) Hold down the select and red buttons for 2-3 seconds until the LED blinks twice
4) Press the TV button on the Sky Remote again
5) Enter the 4 digit code for your make of TV
6) The LED should blink twice, if not recheck the 4 digit code used and go back to 1
7) Press the standby button on the Sky Remote (The TV should go to standby)
8) Press select to store this setting
If the TV does not go into standby press the TV button then the standby button, then TV then standby, keep repeating this until successful. This will scan the codes used for a particular make of TV.
Jul 01, 2008 | Hitachi CLU-5713TSI Remote Control
Hitachi 32LD8700 - TV won't turn on although has power
The general problem with LCD type TV's is that the power supply fails. They are very sophisticated designs that are difficult to troubleshoot and generally best to just replace the module, but sometimes there is visible damage in some of the electrolytic capacitors (visibly bulged) and high voltage rated parts can be substituted.
Hope Ya Fix It
Feb 10, 2008 | Hitachi 32LD8700 32 in. LCD Television
Unit will not turn on from standby
I had a similar problem and it was caused by my cable box being in scart 1 as soon as I changed over to scart 2 the problems went away,
Nov 04, 2007 | Hitachi 42HDS69 42 in. Plasma Television
Televison & Video Logo
Top Televison & Video Experts
