Question about Dryers
Correct wiring for maytag electric dryer mde 4600 timer
Double black wire with one conncetor where does it connect?
    Top Expert:
  • Dryers Master
  • 9,472 Answers
What is the model number of the unit?
Posted on Dec 01, 2012
  • skipby5
    skipby5 Dec 01, 2012
    It looks like this went twice. But the model # is MDE4806AYW
  • Richard Roth
    Richard Roth Dec 01, 2012
    wiring diagram --> http://bit.ly/Tz82wO
Jimster
  • 240 Answers
SOURCE: Maytag Dryer Tstat wiring
I believe that this part is a thermostat. If im not mistaken, it shouldnt matter which wire goes on which prong. Think this is a reversable thermostat. It should have just 2 prongs correct? Jim
Posted on Sep 09, 2007
docjohn174
  • 943 Answers
SOURCE: Maytag dryer MDE4000AYW change 3 prong to a 4 prong
HI thanks for your question. the red to red black to black white to white green goes to the fram of the dryer. thanks hope i was helpful. please rate my answer.
Posted on Oct 12, 2008
aborcass
  • 2651 Answers
SOURCE: Maytag De4000 Electric Dryer Wire Hookup
black and red wire, will hook to either end of terminal posts, as long as the white wire connects to the center post. the green wirewill then atach to the cabinet of the unit,( usually a green ground screw just outside the termoal box anyhow!
Posted on Apr 22, 2009
  • 180 Answers
SOURCE: wires for the maytag dryer are black, yellow, blue
The red and black wires of the cord go to the outside two terminals. The white on the cord goes in the middle. The green goes to the frame. Red and Black on the cord are L1 and L2, White is Nuetral, and green is ground
Posted on Nov 27, 2009
SOURCE: MAYTAG DRYER ELECTRICAL CONNECTION
how do you change a 3 prong plug to a 4 prong plug when the colors dont match on the wires to the dryer?colors on the wires are red white black and green. colors on the terminal of the dryer are a black and yellow tied together a white in the middle and 2 blues tied together. this is a maytag atlantis dryer. thankyou chad....
Posted on Apr 28, 2010
I am installing a ge #15070 basic timer and there are 3 wires. Which wire do I attach to the ground?
GE 15070 timer does not have ground wire.
I assume this timer is double insulated, just like some power tools and electronics only have two prong plug.
Leave bare ground wire attached to other bare grounds in the box, and shove grounds to back of box.
I have one of these timers installed.
Timer has red, black and white wires
http://waterheatertimer.org/GE-timers-and-manuals.html#15070
How to wire GE 15070 timer:
1) Switch has 2 insulated wires. Take switch wires and connect them to timer-black-wire and timer-red-wire. Choose either one for now.
2) In back of electric box are white wires twisted together and covered with wire nut. Connect timer-white to these wires.
3) If electric box does not have white wires described above, then connect timer-white to bare ground, along with timer-green wire.
4) Turn on electricity, and slide switch to ON-or-OFF. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires.
5) Add a comment for more free help.
6) Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer or any do-it-yourself project.
Jan 13, 2011 | GE Vacuums
Timer was connected with all wires correctly. On/Off button is lighting up red, but does not turn light on or off. Directions said try switching switch from off to timer, but unable to locate switch. ...
Woods timers:
http://waterheatertimer.org/Woods-timers-and-manuals.html
Scroll down page to make sure your timer is shown.
You posted under Woods 59018-59028
GE 15086 timer has OFF-Timer switch
http://waterheatertimer.org/images/GE-15086-programmable.jpg
http://waterheatertimer.org/Programmable.html#Aube
Add a comment to identify timer, and I can help more
Double-check wiring:
1) Timer-green-wire connects to bare ground wire.
2) Switch has 2 wires. Take switch wires and connect them to timer-black-wire and timer-red-wire. Choose either one for now.
3) In back of electric box are white wires twisted together and covered with wire nut. Connect timer-white to these wires.
4) If electric box does not have white wires described above, then connect timer-white to bare ground.
5) Turn on electricity, and push ON-OFF button. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires.
Nov 22, 2010 | Woods InWall 7 Day Digital Programmable...
Dryer won't heat maytag neptune mde 5500 ayw
Hi
If the dryer is not drying the clothes then you would need to check for the following things-
Electric Dryer---
1. Inspect the fuses and circuit breakers they may have burned out or tripped. Usually, dryer will still tumble but not create heat if a fuse or a circuit breaker is not working.
2. Check for the amp reading at 240 V, it should have reading of 24, 21 and 3 amp (approx.) for 2 lines and neutral respectively.
3. Heating element may have turned or the connection to the element might be loose. Sometimes a shorted circuit element will keep on blowing the fuse or circuit breaker.
4. Motor wiring shorting to ground.
Hope this helps...
Daniel
Sep 20, 2010 | Maytag Neptune MDE5500AY Electric Dryer
I have model #MDE6400AYW - my dryer does not turn on. I have confirmed the power source works, the vent is clear, I have replaced the timer, and even confirmed that both thermal fuses work yet my dryer...
Hello, I will assume this is a electric dryer where the drum turns but no heat, your problem most likely is the centrifigal switch. this is built into the motor. Basically its operation is to not switch the heater2.gif on unless the motor is turning. By the sound of things you are compitent with electrical side of appliances. Remove the wire harness for the motor. Make up a wire bypass using 2 male connectors and some heavy duty wire. plug each end of this bypass into the wire harness where you see the 2 thick wires. Next making sure the harness is not touching anything metal plug her in and hit the start button, check to see if the heater starts to glow or you can smell it heating up...if it does heat up your going to need to change the motor. If this is not your problem please don't down rate me, feel free to comment again and I will give you further help. Mike
Sep 22, 2009 | Dryers
Maytag Atlantis MDE7400AYW timer has been replaced but the dryer won't stop drying on it's own. What is the reason? I have the same problem... the timer on mine doesn't seem to work. Any ideas?
The wire connections to the timer may have not been made correctly when it was replaced bypassing the OFF contact in the control circuit.  There should be a wiring diagram inside the front or back panel that you can check.
Jun 02, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Oct 12, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Jul 30, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag coin op dryer timer programming for mde-16cs
The maximum run time on this machine's timer is 54 min. There is an adjustable peg on the white plastic index wheel which you can adjust anywhere from 30 to 54 min. For example peg in position E is 30min, D is 36min, C is 42min, B is 48min or for 54 min you have to remove the adjustable peg completely, but don't lose it in case you want to change the time in the future. If it is already in the Max "A" position and shuting off early you might have to change your torsion return spring. Hope this helps
Jan 06, 2008 | Maytag MDE16CS Electric Dryer
Dryers Logo
59 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
