Question about Sony VAIO EB Series Notebook
Have a sony vaio the wont turn on, nor will any lights come on.
I turned it off on dayand it wouldnt come back on. no lightd light up even when pluged in, even tryed taking the batterry out and visa versa. please can some on help me...thanks rick
  • Sony Master
  • 32,281 Answers
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Posted on Dec 01, 2012
  • 10 Answers
SOURCE: sony vaio pcg-grt170 when I push the power button,
Perform these steps and the issue will be resolved if the issue is with the Static charges on the Mother board.
I recommend you use Power Drain procedure by following these steps:
1. Disconnect the AC Adapter.
2. Remove the Battery.
3. Hold the Power button down for 30 seconds to 1 minute.
4. Reconnect the AC adapter and do NOT connect the battery now.
5. Turn on the Notebook power.
Posted on Feb 18, 2009
  • 253 Answers
SOURCE: VAio VGN-FS742 Screen does not display
Try to remove the battery, remove AC adapter, and press and hold power button for 45 sec. reinsert battery, and Plug and try again, if that doesn't solve it, you may need to try to change memory first, (cheapest) or the motherboard or CPU.
Please give good rating if this helps your issue, Thanks
Posted on Apr 12, 2009
rulds2008
  • 3866 Answers
SOURCE: sony vaio cr35 power problem
You might have a hardware failure here. Specially the part when you said you had the same result when removing the battery and just had the AC in. This machine has NO POST this mean Hardware failure specially the blinking light concerns me on the machine health as far as a tech. I would say bring it into the geek squad to confirm my theory it will not hurt for them to take a few secounds to confirm this if there is any warranties I cannot stress this enought use the warranty this is your secure ticket to a fix if its not warrantied I would seriously recommend having the motherboard evaluated it should at least beep but if you do not get a beep this is NO POST hard ware failure. Thanks and please rate you experience with me postivly
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Nov 17, 2009
Testimonial: "thanks for the advise. I will send it to the service center for evaluation. Thanks very much"
  • 6 Answers
SOURCE: sony vaio pcg-r505el won't turn on
These are know to have issues with the cpacitors on the mother board, you can try to replace the caps or just buy a new motherboard. I'm fixing one right now as I type...
Posted on Jan 15, 2010
Comp-U-Doc
  • 148 Answers
SOURCE: Sony VAIO Laptop won't turn on. The power lights
Unplug from A/C adapter & remove battery and let sit fo a while..
Put battery back and plug in the A/C adapter, then turn back on.
Posted on Mar 31, 2010
My sony vaio PGC-3E2L wont turn on, not even when i plug the charger. The only thing it does is turn on the battery and power lights only when i press the power button but turn off when i release it
Take out the battery and try with just the charger, Batteries for computers have regulators in them and when the batteries die, the computer wont boot.
Dec 08, 2016 | Sony Computers & Internet
Car wont start
check the battery cable for a good connection then make sure its in park move the gear shifter around and place back in park. check the head lights for full power. last thing is jump it with cables to make sure the battery is strong.
Jan 05, 2013 | 1998 Pontiac Sunfire
My vaio wont turn on and the green light in the back keeps blinki
The green light blinking in the back indicates that the power supply went bad and is not turning on, go ahead and get the power supply replaced. Normally that light is supposed to be fully lit and green.
Apr 28, 2010 | Sony VAIO VGC-RB53 PC Desktop
Mar 31, 2010 | Sony VAIO Notebook
Wont turn on every thing is hooked up right pluged
A PLYE AMP IS NO GOOD AND ITS PROBABLY BLOWN SORRY FOR THE BAD NEWS
Feb 09, 2010 | Pyle PLA985R Car Audio Amplifier
When ps2 is pluged in it shows red light but wont come on
try this:
unplug the AC from the PS2 and the wall.
wait a couple minutes before plugging back in and playing.
hope this helps :p
Nov 15, 2009 | Sony PlayStation 2 (PS2) Console
Sony WEGA LCD TV Model KFE50A10 wont turn on
It turns out that the number of red lights flashing, relates to a partiuclar error problem. My TV was flashing 4 red lights, pausing , then flashing again etc etc. This particular error meant that one of the five fans within the TV box had stopped funtioning. So the TV has gone to the repairman today. I was advised by an operator at the SONY STYLE CENTRE that such a repair would be considered as a genuine fault and that SONY would pick up the tab. I live in hope
Apr 01, 2008 | Televison & Video
PSP WONT TURN ON
Hi Aflory08,
Best thing to do is Contact SONY Support at 1-800-345-7669 and get into the exchange program.  If Sony want help you due to Warranty Issues, The Playstation Clinic will help you.  Contact Repairtech@PlaystationClinic.com
Oct 21, 2007 | Sony PlayStation Portable (PSP) Console
Open Questions:
Sony VAIO EB Series Notebook Logo
87 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
